IVR Pin Issue
glennbtn
Hi All
I have a need to use the pin feature on and IVR with Fusionpbx but I guess this may be a bug.
When you call in to the IVR and get asked to enter the pin followed but the # it will actually reject the the pin with the # if I dial in and just enter the pin it's ok
Now is there a way to make sure it accepts the # as requested as this would make it uniform with the other password requirements with the pbx or should I just be thinking about hacking the wav files and if so anyone know if this wav is only used with the ivr function.
