IVR to extrnal number CDR issue
Mikeme
200
Hi friends,
i'm having a problem with CDR when set one of the digits to external number.
once call get in to IVR and customer choose 5 the call going out to external number.
the point is that; this out going call are showed in CDR at the same record of the incoming call which answered by IVR
how can i make a new record for this "Call forward"
i believe that can be done on external number dialplain.
attached dialplan example to dial out.
at the end of the day, i wish to have 2 CDR records, one of the incoming call which answered by IVR and second is the outgoing call of the external number..
You may be looking for b-leg CDR records. There are settings in the default settings for importing b legs, but you also have to enable them in the freeswitch autoload_config xml_cdr.conf.xml
 <param name="log-b-leg" value="true"/>
to create them in the first place.
It also has implications that increase your CDR database size because many of your calls will now have 2 entries in the CDR. They may also be invisible by default, I think it's a permission to view the b-leg CDRs.
all done.
set log-b-leg to "true" at xml_cdr.conf.xml
and set b-leb (local, outbound, inbound) to true in Default Settings.
unfortunately call still show one row record..
i also "reload XML".
do i miss anything?
and also Permissions allow for b-leg...
looking in database, calls are with a-leg, nothing with b-leg
The easiest method would be to add a new extension, click on "Call Routing" from the extension form, enable "Call Forward", and enter the destination number in the appropriate field. Then add this extension number to your IVR.
well, to be more specific, the external dialplan number is transferred from ring group.
the flow -
call get into IVR -> transfer to ring group -> external dialplan number.
i did test it with new extension which is dedicate to call forward.
when putting the CFD extension in IVR I'm able to get two rows of calls with correct billsec.
when putting the CFD extension in ring group I'm able not able to see 2 rows.
so, right now the issue is when call transferred from ring group to the CFD extension.
Make sure you set the ring group strategy to, "Enterprise", otherwise it will not execute the call forwarding or Follow-Me routes.
the call forward working fine.
the only thing i need is to separate between calls(inbound and outbound of the CFD) by a/b-leg in CDR records.
It is a normal call flow - Inbound to Outbound, so it will show as such.
I have a contractor that has some customers that are statistics obsessed; how many calls ended in specific queue from specific numbers; calls answered by follow me and so on, so I pulled that from v_xml_cdr table.
You can use SQL Editor (if you have it installed) and do
copy (select * from v_xml_cdr where direction = 'outbound' and destination_number = 'your_outbound_followme_number') to '/tmp/something.csv';
alternatively you could add
and leg = 'b-leg'
and/or or
 and where domain_name = 'customer_domain'
Or even
delimiter ',' csv header'
if you want better looking csv file. If you do not have SQL Editor, run the
psql --host=127.0.0.1 --username=fusionpbx -c "copy string"
To get the Postgres password run
cat /etc/fusionpbx/config.conf | grep password
Note: it was config.php before.
You can always play around with columns to get desired specific information.
