Make conference call with SIPJS & FreeSwitch
asaqer
I am using SIPJS version 0.16.0 with FreeSwitch
So far, I have connected them and make audio/video call successfully using SIPJS (1 to 1 call)
The question is:
How can I make conference call using SIPJS and FreeSwitch?
Which method is the best?
MESH?
FreeSwitch rooms?
Or other way?
Also, I need the code for any way you will suggest.
because I have connected to rooms successfully, but I don't get all the participant video streams,
I only get 1 stream and it switch between callers videos, I guess switching depend on who's talking (not sure).
Also, the event (onaddtrack) is not triggering at all.
This event should trigger when new participant join , but it's not.
I'll provide the code when you accept the task so you can check if something wrong.
Note: I'm using VueJs to build the project
