Match each trunk alias to a destination SOLVED
elderlogan
31
Hi, i have a sip trunk going from xxxx500 to xxx600
I have configured the gateway, the calls get in and out without problems, BUT,
I want to make it so that if i call the 501 it goes to a specific call queue, if i call the 502 another etc.
How can i do that?
Even if i set it up correctly(i have other gateways but they are each with a single enumeration) it always goes in like it's the 500. is this my fault or is this the carrier fault's? please help me ty.
Turns out that the variable that allows the distinction is sip_to_user. once you set up the destination manually it works correctly
