Multi routes
Incubugs
179
Hi guys,
i have a client with 2 companies on the 1 server using fusionpbx (latest) , they both have their own sip trunks on the system, whats the easiest way to ensure each comapny uses its own trunks without doing multi tenant ?
Kurt
Easiest way is to set outbound callerid per extension. Then the outbound route isn’t important.
if it really matters, you could then add an appropriate condition in outbound route to check the callerid.
but really if they have their own trunks and don’t need to interact with other company extensions, multi tenant makes it easier in the end
