[Newbie:] Dealplan setting problem
leo852
Hi there, I'm new here. And I've got a question about dealplan settings since i've deleted them all without backup. I cannot use the default ones for example. So if I wanted to create something like
** {outbound_caller_id_number} * {outbound_caller_id_number} #
How could I set this up? So I can can easily use different outbound caller id to call with the dial pad.
You create outbound routes under Dialplan -> Outbound Routes then click the "+" icon to add a new route. You will need to create a gateway first and once you create the new route you can setup dialplan expressions.
If you are asking how to spoof caller ID, I doubt anyone will want to help you with that.
