Hi all
I am having major problems getting my first install of FusionPBX to call outside of the PBX via the SIP trunk to the upstream provider (AQL).
I am very new to running a VoIP server of any kind but I have a little hands-on experience with 3CX and old versions of Elastix (prior to the move to 3CX). I have set up 1 domain on Fusion, 1 extension and have inbound calls working fine, I can even call back into the PBX from the extension that has been set up and call other ring groups etc. I however have tried almost everything to get the outbound SIP trunk working over the last 2 weeks and still coming up blank. I thought it may be related to the regular expression but I believe this should now be correct because instead of instantly failing, it now just hangs for 20ish seconds until it times out.
If anyone can help it would be greatly appreciated. If not I will need to find a consultant to unpick the issue. I have reached out to the trunk provider (AQL) who were zero help!
I have uploaded the output of siptrace to pastebin to save space here.
pastebin.com
Thanks in advance
Jon
.=======================================================.| _____ __ - Pastebin.com
Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
Thanks in advance
Jon
