One way audio outgoing calls
Mikeme
194
I'm facing a problem with outgoing call via SIP TRUNK when there is a one way sound.
when asking ITSP for the reason they told me that FS does not sending - " a=sendrecv" in media sip message of the invite
does some known which settings do i need to change so FS will send this line in the invite SIP message?
can't find anything about this issue in the net.
I try many options like adding early_media in outgoing dialplan and nothing changed.
help
<param name="NDLB-sendrecv-in-session" value="true"/>
What about the above if you added it to the external profile in SIP Profiles?
