T Tulsa New Member Apr 26, 2018 3 0 1 65 Apr 26, 2018 #1 We have a new FusionPBX and we are unable to get the caller ID to pass through. - I have set it in the outbound routes effective_caller_id_number - I set it in the extension as well Is there something special about a Multi Tenant system? Thanks David
R roger_roger Member Oct 12, 2016 198 19 18 72 Apr 27, 2018 #2 It is probably not being accepted by your carrier. Ask them what they see.
I Incubugs Member Apr 7, 2018 188 11 18 51 Apr 27, 2018 #3 you need to set under gateway, advanced , caller id in from = true, then it will pass cid to gateway.. Reactions: Tulsa
T Tulsa New Member Apr 26, 2018 3 0 1 65 Apr 27, 2018 #4 Incubugs said: you need to set under gateway, advanced , caller id in from = true, then it will pass cid to gateway.. Click to expand... Thank you thank you, it works
