SOLVED Outbound call from bridge softswitch is not working
Saif
19
Hi, i am new in fusionpbx and trying to get familiar with different functions. I am having issues in routing outbound call in my fusionpbx. Here is the scenario i have setup fusionpbx with a static IP with a gateway to make outbound long distance calls. I have created few extensions to make test call one of the extension i have added in my softswitch as gateway to bridge fusioinpbx and my softswitch. When i try to make long distance call from softswitch extension i can not make outbound long distance call from fusionpbx as i wanted to route all long distance call terminate from fusionpbx.
can you please guide me how to solve this issue?
Sorry for my poor english and thanks for your kind help.
Regards,
Saif
here is my log:
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/1003@64.187.222.69:5060) Running State Change CS_NEW (Cur 1 Tot 12)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] sofia.c:9873 sofia/internal/1003@64.187.222.69:5060 receiving invite from 64.187.222.69:5060 version: 1.6.20 -37-987c9b9 64bit
2018-04-16 12:40:05.509931 [DEBUG] sofia.c:9989 IP 64.187.222.69 Approved by acl "domains[]". Access Granted.
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] sofia.c:7084 Channel sofia/internal/1003@64.187.222.69:5060 entering state [received][100]
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] sofia.c:7094 Remote SDP:
4fce17ab-1981-466c-822b-0c29ac17743a v=0
4fce17ab-1981-466c-822b-0c29ac17743a o=iTelSwitchPlus_7.0.1 22469580 22469580 IN IP4 64.187.222.69
4fce17ab-1981-466c-822b-0c29ac17743a s=Sip Session
4fce17ab-1981-466c-822b-0c29ac17743a c=IN IP4 64.187.222.69
4fce17ab-1981-466c-822b-0c29ac17743a t=0 0
4fce17ab-1981-466c-822b-0c29ac17743a m=audio 29512 RTP/AVP 18 101
4fce17ab-1981-466c-822b-0c29ac17743a a=rtpmap:18 G729/8000
4fce17ab-1981-466c-822b-0c29ac17743a a=fmtp:18 annexb=no
4fce17ab-1981-466c-822b-0c29ac17743a a=rtpmap:101 telephone-event/8000
4fce17ab-1981-466c-822b-0c29ac17743a a=fmtp:101 0-15
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [G729:18:8000:20:8000:1]/[G729:18:8000:20:8000:1]
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [G729:18:8000:20:8000:1] ++++ is saved as a match
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_media.c:3061 Set Codec sofia/internal/1003@64.187.222.69:5060 G729/8000 20 ms 160 samples 8000 bits 1 channels
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_codec.c:111 sofia/internal/1003@64.187.222.69:5060 Original read codec set to G729:18
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_media.c:4767 sofia/internal/1003@64.187.222.69:5060 Set 2833 dtmf send payload to 101 recv payload to 101
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] sofia.c:7507 (sofia/internal/1003@64.187.222.69:5060) State Change CS_NEW -> CS_INIT
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/1003@64.187.222.69:5060) State NEW
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/1003@64.187.222.69:5060) Running State Change CS_INIT (Cur 1 Tot 12)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/1003@64.187.222.69:5060) State INIT
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] mod_sofia.c:90 sofia/internal/1003@64.187.222.69:5060 SOFIA INIT
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:40 sofia/internal/1003@64.187.222.69:5060 Standard INIT
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/1003@64.187.222.69:5060) State Change CS_INIT -> CS_ROUTING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/1003@64.187.222.69:5060) State INIT going to sleep
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/1003@64.187.222.69:5060) Running State Change CS_ROUTING (Cur 1 Tot 12)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_channel.c:2249 (sofia/internal/1003@64.187.222.69:5060) Callstate Change DOWN -> RINGING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/1003@64.187.222.69:5060) State ROUTING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] mod_sofia.c:143 sofia/internal/1003@64.187.222.69:5060 SOFIA ROUTING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [DEBUG] switch_core_state_machine.c:236 sofia/internal/1003@64.187.222.69:5060 Standard ROUTING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.509931 [INFO] mod_dialplan_xml.c:637 Processing 945353 <1003>->01670806867 in context public
4fce17ab-1981-466c-822b-0c29ac17743a Dialplan: sofia/internal/1003@64.187.222.69:5060 parsing [public->caller-details] continue=true
4fce17ab-1981-466c-822b-0c29ac17743a Dialplan: sofia/internal/1003@64.187.222.69:5060 Regex (PASS) [caller-details] () =~ // break=never
4fce17ab-1981-466c-822b-0c29ac17743a Dialplan: sofia/internal/1003@64.187.222.69:5060 Action export(call_direction=inbound) INLINE
4fce17ab-1981-466c-822b-0c29ac17743a EXECUTE sofia/internal/1003@64.187.222.69:5060 export(call_direction=inbound)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[inbound]
4fce17ab-1981-466c-822b-0c29ac17743a Dialplan: sofia/internal/1003@64.187.222.69:5060 Action set(caller_destination=${destination_number}) INLINE
4fce17ab-1981-466c-822b-0c29ac17743a EXECUTE sofia/internal/1003@64.187.222.69:5060 set(caller_destination=01670806867)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] mod_dptools.c:1548 SET sofia/internal/1003@64.187.222.69:5060 [caller_destination]=[01670806867]
4fce17ab-1981-466c-822b-0c29ac17743a Dialplan: sofia/internal/1003@64.187.222.69:5060 Action set(caller_id_name=${caller_id_name}) INLINE
4fce17ab-1981-466c-822b-0c29ac17743a EXECUTE sofia/internal/1003@64.187.222.69:5060 set(caller_id_name=945353)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] mod_dptools.c:1548 SET sofia/internal/1003@64.187.222.69:5060 [caller_id_name]=[945353]
4fce17ab-1981-466c-822b-0c29ac17743a Dialplan: sofia/internal/1003@64.187.222.69:5060 Action set(caller_id_number=${caller_id_number}) INLINE
4fce17ab-1981-466c-822b-0c29ac17743a EXECUTE sofia/internal/1003@64.187.222.69:5060 set(caller_id_number=1003)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] mod_dptools.c:1548 SET sofia/internal/1003@64.187.222.69:5060 [caller_id_number]=[1003]
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/1003@64.187.222.69:5060) State Change CS_ROUTING -> CS_EXECUTE
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/1003@64.187.222.69:5060) State ROUTING going to sleep
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/1003@64.187.222.69:5060) Running State Change CS_EXECUTE (Cur 1 Tot 12)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/1003@64.187.222.69:5060) State EXECUTE
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] mod_sofia.c:198 sofia/internal/1003@64.187.222.69:5060 SOFIA EXECUTE
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:328 sofia/internal/1003@64.187.222.69:5060 Standard EXECUTE
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [NOTICE] switch_core_state_machine.c:385 sofia/internal/1003@64.187.222.69:5060 has executed the last dialplan instruction, hanging up.
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/1003@64.187.222.69:5060 [CS_EXECUTE] [NORMAL_CLEARING]
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/1003@64.187.222.69:5060) State EXECUTE going to sleep
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/1003@64.187.222.69:5060) Running State Change CS_HANGUP (Cur 1 Tot 12)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/1003@64.187.222.69:5060) Callstate Change RINGING -> HANGUP
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/1003@64.187.222.69:5060) State HANGUP
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] mod_sofia.c:438 Channel sofia/internal/1003@64.187.222.69:5060 hanging up, cause: NORMAL_CLEARING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] mod_sofia.c:577 Responding to INVITE with: 480
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:60 sofia/internal/1003@64.187.222.69:5060 Standard HANGUP, cause: NORMAL_CLEARING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:852 (sofia/internal/1003@64.187.222.69:5060) State HANGUP going to sleep
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/1003@64.187.222.69:5060) State Change CS_HANGUP -> CS_REPORTING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/1003@64.187.222.69:5060) Running State Change CS_REPORTING (Cur 1 Tot 12)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.529699 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/1003@64.187.222.69:5060) State REPORTING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [DEBUG] switch_core_state_machine.c:174 sofia/internal/1003@64.187.222.69:5060 Standard REPORTING, cause: NORMAL_CLEARING
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [DEBUG] switch_core_state_machine.c:938 (sofia/internal/1003@64.187.222.69:5060) State REPORTING going to sleep
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/1003@64.187.222.69:5060) State Change CS_REPORTING -> CS_DESTROY
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [DEBUG] switch_core_session.c:1665 Session 12 (sofia/internal/1003@64.187.222.69:5060) Locked, Waiting on external entities
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [NOTICE] switch_core_session.c:1683 Session 12 (sofia/internal/1003@64.187.222.69:5060) Ended
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [NOTICE] switch_core_session.c:1687 Close Channel sofia/internal/1003@64.187.222.69:5060 [CS_DESTROY]
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [DEBUG] switch_core_state_machine.c:741 (sofia/internal/1003@64.187.222.69:5060) Running State Change CS_DESTROY (Cur 0 Tot 12)
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/1003@64.187.222.69:5060) State DESTROY
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [DEBUG] mod_sofia.c:343 sofia/internal/1003@64.187.222.69:5060 SOFIA DESTROY
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [DEBUG] switch_core_state_machine.c:181 sofia/internal/1003@64.187.222.69:5060 Standard DESTROY
4fce17ab-1981-466c-822b-0c29ac17743a 2018-04-16 12:40:05.569903 [DEBUG] switch_core_state_machine.c:751 (sofia/internal/1003@64.187.222.69:5060) State DESTROY going to sleep
