Outbound calls using Grandstream GXW4104 gateway
chind
13
Hi all!!
Having a problem here configuring this tel line gateway to work with fusionpbx. Incoming appears to be working. We have the gateway registered and an extension set up with the extension account settings saved on the gateway. Inbound call hits the extension on the pbx and forwards to our desired ring group. This issue we have is dialing out. We have a dial plan for North America (we are in Canada) and the outbound route has the gateway selected. But when we make a call we are getting a 404 not found error on the IP phone. Any ideas what we may be doing wrong? Also I see people posting logs on here but I’m not sure where to find these logs. Help with this would be appreciated as well. Thanks in advance,
A fusionpbx newbie!!!
1. Place a call which fails on 404.
2. Status > Log Viewer
3. Search for the number you called and logically copy the "start of the call" all the way down to where it says "terminated" (you may need to "increase" the log size in the top right corner to view more)
4. Paste it in a reply inside a text box for readability
Thank for your help there James.
So what I have now is a fresh install pf FusionPBX, an extension created for the Grandstream gateway which is forwarding to a ring group. Once again, incoming is working no problems. Here is the log I get when trying to make an outgoing call. I no longer get the 404 message but I just get "Unavailable" on the screen. If you guys can decode this code, I would be very grateful. I have a lot to learn here but I hope there is a glaringly obvious fix that someone can enlighten me into!!! Thank you.
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/anonymous@anonymous.invalid) State DESTROY going to sleep
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [DEBUG] switch_core_state_machine.c:181 sofia/internal/anonymous@anonymous.invalid Standard DESTROY
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [DEBUG] mod_sofia.c:354 sofia/internal/anonymous@anonymous.invalid SOFIA DESTROY
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_DESTROY (Cur 0 Tot 12)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/anonymous@anonymous.invalid [CS_DESTROY]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [NOTICE] switch_core_session.c:1733 Session 11 (sofia/internal/anonymous@anonymous.invalid) Ended
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [DEBUG] switch_core_session.c:1715 Session 11 (sofia/internal/anonymous@anonymous.invalid) Locked, Waiting on external entities
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/anonymous@anonymous.invalid) State Change CS_REPORTING -> CS_DESTROY
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/anonymous@anonymous.invalid) State REPORTING going to sleep
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.150503 [DEBUG] switch_core_state_machine.c:174 sofia/internal/anonymous@anonymous.invalid Standard REPORTING, cause: NORMAL_CLEARING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/anonymous@anonymous.invalid) State REPORTING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_REPORTING (Cur 1 Tot 12)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/anonymous@anonymous.invalid) State Change CS_HANGUP -> CS_REPORTING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/anonymous@anonymous.invalid) State HANGUP going to sleep
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:60 sofia/internal/anonymous@anonymous.invalid Standard HANGUP, cause: NORMAL_CLEARING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 480
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_sofia.c:449 Channel sofia/internal/anonymous@anonymous.invalid hanging up, cause: NORMAL_CLEARING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/anonymous@anonymous.invalid) Callstate Change RINGING -> HANGUP
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_HANGUP (Cur 1 Tot 12)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/anonymous@anonymous.invalid) State EXECUTE going to sleep
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/anonymous@anonymous.invalid [CS_EXECUTE] [NORMAL_CLEARING]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [NOTICE] switch_core_state_machine.c:385 sofia/internal/anonymous@anonymous.invalid has executed the last dialplan instruction, hanging up.
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [INFO] mod_dptools.c:3518 Originate Failed. Cause: GATEWAY_DOWN
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 609 [GATEWAY_DOWN]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [NOTICE] switch_ivr_originate.c:2944 Cannot create outgoing channel of type [sofia] cause: [GATEWAY_DOWN]
e20c0804-d58f-11e9-a008-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:748 (N/A) State DESTROY going to sleep
e20c0804-d58f-11e9-a008-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_sofia.c:354 N/A SOFIA DESTROY
e20c0804-d58f-11e9-a008-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:738 () Running State Change CS_DESTROY (Cur 1 Tot 12)
e20c0804-d58f-11e9-a008-213a7b2c3076 2019-09-12 12:02:36.090492 [NOTICE] mod_sofia.c:5117 Close Channel N/A [CS_NEW]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [ERR] mod_sofia.c:4708 Gateway b955fd2d-1ec6-4e51-b154-ac15f9cf90dd is down!
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_channel.c:1250 sofia/internal/anonymous@anonymous.invalid EXPORTING[export_vars] [call_direction]=[outbound] to event
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_channel.c:1250 sofia/internal/anonymous@anonymous.invalid EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_channel.c:1250 sofia/internal/anonymous@anonymous.invalid EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid bridge(sofia/gateway/b955fd2d-1ec6-4e51-b154-ac15f9cf90dd/6046812011)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [continue_on_fail]=[true]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(continue_on_fail=true)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [callee_id_number]=[6046812011]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(callee_id_number=6046812011)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [ignore_display_updates]=[true]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(ignore_display_updates=true)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [inherit_codec]=[true]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(inherit_codec=true)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [effective_caller_id_number]=[UNDEF]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(effective_caller_id_number=)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [effective_caller_id_name]=[UNDEF]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(effective_caller_id_name=)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [hangup_after_bridge]=[true]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(hangup_after_bridge=true)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid unset(call_timeout)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid export(call_direction=outbound)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [sip_h_X-accountcode]=[UNDEF]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(sip_h_X-accountcode=)
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid hash(insert/192.168.1.83-last_dial/500/6046812011)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [RFC2822_DATE]=[Thu, 12 Sep 2019 12:02:36 -0700]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(RFC2822_DATE=Thu, 12 Sep 2019 12:02:36 -0700)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid export(origination_callee_id_name=6046812011)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [caller_id_number]=[500]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(caller_id_number=500)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:328 sofia/internal/anonymous@anonymous.invalid Standard EXECUTE
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_sofia.c:209 sofia/internal/anonymous@anonymous.invalid SOFIA EXECUTE
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_EXECUTE (Cur 1 Tot 11)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/anonymous@anonymous.invalid) State ROUTING going to sleep
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/anonymous@anonymous.invalid) State Change CS_ROUTING -> CS_EXECUTE
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action bridge(sofia/gateway/b955fd2d-1ec6-4e51-b154-ac15f9cf90dd/6046812011)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(continue_on_fail=true)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(callee_id_number=6046812011)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(ignore_display_updates=true)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(inherit_codec=true)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(effective_caller_id_number=${outbound_caller_id_number})
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(effective_caller_id_name=${outbound_caller_id_name})
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(hangup_after_bridge=true)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action unset(call_timeout)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action export(call_direction=outbound)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(sip_h_X-accountcode=${accountcode})
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->Grandstream FXO.10d] continue=false
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [outbound_caller_id_number]=[UNDEF]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(outbound_caller_id_number=)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [outbound_caller_id_name]=[UNDEF]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(outbound_caller_id_name=)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [emergency_caller_id_number]=[UNDEF]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(emergency_caller_id_number=)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [emergency_caller_id_name]=[UNDEF]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(emergency_caller_id_name=)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->default_caller_id] continue=true
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->speed_dial] continue=false
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [redial] () =~ // break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->redial] continue=true
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_exists}(false) =~ /^true$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [from_user_exists]=[false]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(from_user_exists=false)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [user_record] () =~ // break=on-false
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->user_record] continue=true
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action export(origination_callee_id_name=${destination_number})
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [variables] () =~ // break=on-false
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->variables] continue=true
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid export(call_direction=local)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid ANTI-Action export(call_direction=local) INLINE
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->call-direction] continue=true
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(caller_id_number=${caller_id_number})
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [caller_id_name]=[500]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(caller_id_name=500)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(caller_id_name=${caller_id_name}) INLINE
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [caller_destination]=[6046812011]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(caller_destination=6046812011)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(caller_destination=${destination_number}) INLINE
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->caller-details] continue=true
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.090492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [user_exists]=[false]
e202e454-d58f-11e9-9fea-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(user_exists=false)
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [user_exists] () =~ // break=on-false
e202e454-d58f-11e9-9fea-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->user_exists] continue=true
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_state_machine.c:236 sofia/internal/anonymous@anonymous.invalid Standard ROUTING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] mod_sofia.c:154 sofia/internal/anonymous@anonymous.invalid SOFIA ROUTING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/anonymous@anonymous.invalid) State ROUTING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_channel.c:2249 (sofia/internal/anonymous@anonymous.invalid) Callstate Change DOWN -> RINGING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_ROUTING (Cur 1 Tot 11)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/anonymous@anonymous.invalid) State INIT going to sleep
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/anonymous@anonymous.invalid) State Change CS_INIT -> CS_ROUTING
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_state_machine.c:40 sofia/internal/anonymous@anonymous.invalid Standard INIT
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] mod_sofia.c:93 sofia/internal/anonymous@anonymous.invalid SOFIA INIT
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_INIT (Cur 1 Tot 11)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] sofia.c:7716 (sofia/internal/anonymous@anonymous.invalid) State Change CS_NEW -> CS_INIT
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5795 sofia/internal/anonymous@anonymous.invalid Set 2833 dtmf send payload to 101 recv payload to 101
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_codec.c:111 sofia/internal/anonymous@anonymous.invalid Original read codec set to PCMU:0
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/anonymous@anonymous.invalid PCMU/8000 20 ms 160 samples 64000 bits 1 channels
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [opus:123:48000:20:0:2]/[PCMA:8:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [opus:123:48000:20:0:2]/[PCMU:0:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [opus:123:48000:20:0:2]/[G722:9:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G726-32:2:8000:20:0:1]/[PCMA:8:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G726-32:2:8000:20:0:1]/[PCMU:0:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G726-32:2:8000:20:0:1]/[G722:9:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [iLBC:97:8000:20:0:1]/[PCMA:8:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [iLBC:97:8000:20:0:1]/[PCMU:0:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [iLBC:97:8000:20:0:1]/[G722:9:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [G722:9:8000:20:64000:1] ++++ is saved as a match
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G722:9:8000:20:64000:1]/[G722:9:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G723:4:8000:20:6300:1]/[PCMA:8:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G723:4:8000:20:6300:1]/[PCMU:0:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G723:4:8000:20:6300:1]/[G722:9:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
e202e454-d58f-11e9-9fea-213a7b2c3076 a=ptime:20
e202e454-d58f-11e9-9fea-213a7b2c3076 a=fmtp:101 0-15
e202e454-d58f-11e9-9fea-213a7b2c3076 a=rtpmap:101 telephone-event/8000
e202e454-d58f-11e9-9fea-213a7b2c3076 a=rtpmap:123 opus/48000/2
e202e454-d58f-11e9-9fea-213a7b2c3076 a=rtpmap:2 G726-32/8000
e202e454-d58f-11e9-9fea-213a7b2c3076 a=fmtp:97 mode=30
e202e454-d58f-11e9-9fea-213a7b2c3076 a=rtpmap:97 iLBC/8000
e202e454-d58f-11e9-9fea-213a7b2c3076 a=rtpmap:9 G722/8000
e202e454-d58f-11e9-9fea-213a7b2c3076 a=fmtp:18 annexb=no
e202e454-d58f-11e9-9fea-213a7b2c3076 a=rtpmap:18 G729/8000
e202e454-d58f-11e9-9fea-213a7b2c3076 a=rtpmap:4 G723/8000
e202e454-d58f-11e9-9fea-213a7b2c3076 a=rtpmap:8 PCMA/8000
e202e454-d58f-11e9-9fea-213a7b2c3076 a=rtpmap:0 PCMU/8000
e202e454-d58f-11e9-9fea-213a7b2c3076 m=audio 5010 RTP/AVP 0 8 4 18 9 97 2 123 101
e202e454-d58f-11e9-9fea-213a7b2c3076 t=0 0
e202e454-d58f-11e9-9fea-213a7b2c3076 c=IN IP4 192.168.1.97
e202e454-d58f-11e9-9fea-213a7b2c3076 s=SIP Call
e202e454-d58f-11e9-9fea-213a7b2c3076 o=500 8001 8000 IN IP4 192.168.1.97
e202e454-d58f-11e9-9fea-213a7b2c3076 v=0
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] sofia.c:7301 Remote SDP:
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.070497 [DEBUG] sofia.c:7291 Channel sofia/internal/anonymous@anonymous.invalid entering state [received][100]
2019-09-12 12:02:36.050499 [DEBUG] sofia.c:10263 IP 192.168.1.97 Rejected by acl "domains". Falling back to Digest auth.
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.050499 [DEBUG] sofia.c:10092 sofia/internal/anonymous@anonymous.invalid receiving invite from 192.168.1.97:5062 version: 1.8.4 64bit
2019-09-12 12:02:36.050499 [DEBUG] sofia.c:2522 Re-attaching to session e202e454-d58f-11e9-9fea-213a7b2c3076
2019-09-12 12:02:36.030500 [DEBUG] sofia.c:2413 detaching session e202e454-d58f-11e9-9fea-213a7b2c3076
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.030500 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/anonymous@anonymous.invalid) State NEW
2019-09-12 12:02:36.030500 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.97
2019-09-12 12:02:36.030500 [DEBUG] sofia.c:10263 IP 192.168.1.97 Rejected by acl "domains". Falling back to Digest auth.
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.030500 [DEBUG] sofia.c:10092 sofia/internal/anonymous@anonymous.invalid receiving invite from 192.168.1.97:5062 version: 1.8.4 64bit
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.030500 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_NEW (Cur 1 Tot 11)
e202e454-d58f-11e9-9fea-213a7b2c3076 2019-09-12 12:02:36.030500 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/anonymous@anonymous.invalid [e202e454-d58f-11e9-9fea-213a7b2c3076]
Issue is here:
Check the outbound gateway to your carrier is registered and if so, delete, and re-create the Outbound Dialplan to reassign the right gateway UUID to the dialplan.
Sorry about that mistake. Ok, so the gateway is to use a pots line so no registration needed with a provider, but you are right, it didn't seem to be registered to the pbx. However, it now is, and I redid the outbound route, but now it appears to be ringing back on itself??!!! When I checked active calls, 17 calls were triggered from me pressing dial on one phone. There is a lot of code associated to this but it is in the text box as you suggested.
Also here is a screen shot of the active calls:
7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/anonymous@anonymous.invalid) State DESTROY going to sleep
2    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:181 sofia/internal/anonymous@anonymous.invalid Standard DESTROY
3    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] mod_sofia.c:354 sofia/internal/anonymous@anonymous.invalid SOFIA DESTROY
4    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/anonymous@anonymous.invalid) State DESTROY
5    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_DESTROY (Cur 0 Tot 276)
6    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/anonymous@anonymous.invalid [CS_DESTROY]
7    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [NOTICE] switch_core_session.c:1733 Session 239 (sofia/internal/anonymous@anonymous.invalid) Ended
8    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_session.c:1715 Session 239 (sofia/internal/anonymous@anonymous.invalid) Locked, Waiting on external entities
9    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/anonymous@anonymous.invalid) State Change CS_REPORTING -> CS_DESTROY
10    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/anonymous@anonymous.invalid) State REPORTING going to sleep
11    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:174 sofia/internal/anonymous@anonymous.invalid Standard REPORTING, cause: NORMAL_CLEARING
12    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
13    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
14    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
15    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
16    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 1 Tot 276)
17    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
18    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [NOTICE] switch_core_session.c:1733 Session 241 (sofia/internal/600@192.168.1.83:5060) Ended
19    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_session.c:1715 Session 241 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
20    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
21    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
22    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:33.010499 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
23    2019-09-12 16:49:33.010499 [CRIT] switch_time.c:1235 Over Session Rate of 30!
24    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
25    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
26    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
27    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
28    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 2 Tot 276)
29    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
30    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [NOTICE] switch_core_session.c:1733 Session 243 (sofia/internal/600@192.168.1.83:5060) Ended
31    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [DEBUG] switch_core_session.c:1715 Session 243 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
32    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
33    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
34    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.990491 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
35    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
36    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
37    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
38    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
39    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 3 Tot 276)
40    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
41    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [NOTICE] switch_core_session.c:1733 Session 245 (sofia/internal/600@192.168.1.83:5060) Ended
42    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [DEBUG] switch_core_session.c:1715 Session 245 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
43    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
44    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
45    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.970495 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
46    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
47    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
48    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
49    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
50    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
51    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
52    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
53    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
54    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 4 Tot 276)
55    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 4 Tot 276)
56    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
57    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [NOTICE] switch_core_session.c:1733 Session 247 (sofia/internal/600@192.168.1.83:5060) Ended
58    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
59    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_session.c:1715 Session 247 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
60    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [NOTICE] switch_core_session.c:1733 Session 249 (sofia/internal/600@192.168.1.83:5060) Ended
61    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
62    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_session.c:1715 Session 249 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
63    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
64    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
65    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
66    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
67    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.950488 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
68    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
69    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
70    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
71    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
72    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 6 Tot 276)
73    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
74    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [NOTICE] switch_core_session.c:1733 Session 251 (sofia/internal/600@192.168.1.83:5060) Ended
75    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [DEBUG] switch_core_session.c:1715 Session 251 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
76    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
77    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
78    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.930498 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
79    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
80    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
81    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
82    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
83    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 7 Tot 276)
84    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
85    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
86    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
87    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
88    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 7 Tot 276)
89    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
90    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [NOTICE] switch_core_session.c:1733 Session 255 (sofia/internal/600@192.168.1.83:5060) Ended
91    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_session.c:1715 Session 255 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
92    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
93    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
94    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [NOTICE] switch_core_session.c:1733 Session 253 (sofia/internal/600@192.168.1.83:5060) Ended
95    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_session.c:1715 Session 253 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
96    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
97    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
98    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
99    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
100    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.910493 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
101    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/anonymous@anonymous.invalid) State REPORTING
102    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_REPORTING (Cur 9 Tot 276)
103    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/anonymous@anonymous.invalid) State Change CS_HANGUP -> CS_REPORTING
104    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/anonymous@anonymous.invalid) State HANGUP going to sleep
105    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:60 sofia/internal/anonymous@anonymous.invalid Standard HANGUP, cause: NORMAL_CLEARING
106    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
107    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:449 Channel sofia/internal/anonymous@anonymous.invalid hanging up, cause: NORMAL_CLEARING
108    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:443 sofia/internal/anonymous@anonymous.invalid Overriding SIP cause 480 with 503 from the other leg
109    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/anonymous@anonymous.invalid) State HANGUP
110    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/anonymous@anonymous.invalid) Callstate Change RINGING -> HANGUP
111    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_HANGUP (Cur 9 Tot 276)
112    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/anonymous@anonymous.invalid) State EXECUTE going to sleep
113    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/anonymous@anonymous.invalid [CS_EXECUTE] [NORMAL_CLEARING]
114    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_state_machine.c:385 sofia/internal/anonymous@anonymous.invalid has executed the last dialplan instruction, hanging up.
115    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
116    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
117    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
118    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
119    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
120    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 9 Tot 276)
121    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
122    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
123    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
124    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
125    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 9 Tot 276)
126    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
127    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_session.c:1733 Session 240 (sofia/external/6046812011) Ended
128    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
129    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
130    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_session.c:1733 Session 257 (sofia/internal/600@192.168.1.83:5060) Ended
131    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_session.c:1715 Session 257 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
132    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
133    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
134    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
135    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_session.c:1715 Session 240 (sofia/external/6046812011) Locked, Waiting on external entities
136    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
137    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
138    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
139    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
140    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 11 Tot 276)
141    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
142    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
143    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
144    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
145    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
146    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
147    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 11 Tot 276)
148    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
149    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
150    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] sofia.c:6462 Remote Reason: 16
151    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
152    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 11 Tot 276)
153    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
154    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
155    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
156    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
157    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
158    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
159    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
160    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
161    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 11 Tot 276)
162    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
163    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
164    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
165    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
166    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
167    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
168    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
169    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
170    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 11 Tot 276)
171    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
172    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.890486 [NOTICE] switch_core_session.c:1733 Session 242 (sofia/external/6046812011) Ended
173    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:32.890486 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
174    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_session.c:1715 Session 242 (sofia/external/6046812011) Locked, Waiting on external entities
175    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
176    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
177    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
178    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
179    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 12 Tot 276)
180    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
181    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
182    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
183    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
184    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
185    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
186    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 12 Tot 276)
187    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
188    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
189    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] sofia.c:6462 Remote Reason: 16
190    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
191    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 12 Tot 276)
192    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
193    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
194    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
195    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
196    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
197    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
198    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
199    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
200    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 12 Tot 276)
201    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
202    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
203    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
204    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
205    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
206    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
207    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
208    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
209    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 12 Tot 276)
210    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
211    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_session.c:1733 Session 244 (sofia/external/6046812011) Ended
212    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
213    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_session.c:1715 Session 244 (sofia/external/6046812011) Locked, Waiting on external entities
214    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
215    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
216    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
217    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
218    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 13 Tot 276)
219    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
220    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
221    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
222    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
223    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
224    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
225    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 13 Tot 276)
226    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
227    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
228    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
229    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
230    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
231    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
232    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 13 Tot 276)
233    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
234    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_session.c:1733 Session 261 (sofia/internal/600@192.168.1.83:5060) Ended
235    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_session.c:1715 Session 261 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
236    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
237    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] sofia.c:6462 Remote Reason: 16
238    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
239    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
240    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
241    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 14 Tot 276)
242    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
243    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
244    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
245    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
246    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
247    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
248    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 14 Tot 276)
249    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
250    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
251    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
252    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_session.c:1733 Session 259 (sofia/internal/600@192.168.1.83:5060) Ended
253    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_session.c:1715 Session 259 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
254    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
255    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
256    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
257    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
258    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
259    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
260    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
261    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 15 Tot 276)
262    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
263    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
264    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
265    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
266    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
267    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
268    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
269    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
270    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 15 Tot 276)
271    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
272    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.870491 [NOTICE] switch_core_session.c:1733 Session 246 (sofia/external/6046812011) Ended
273    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:32.870491 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
274    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
275    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
276    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
277    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
278    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 16 Tot 276)
279    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
280    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [NOTICE] switch_core_session.c:1733 Session 263 (sofia/internal/600@192.168.1.83:5060) Ended
281    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_session.c:1715 Session 263 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
282    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
283    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
284    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
285    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_session.c:1715 Session 246 (sofia/external/6046812011) Locked, Waiting on external entities
286    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
287    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
288    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
289    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
290    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 17 Tot 276)
291    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
292    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
293    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
294    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
295    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
296    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
297    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 17 Tot 276)
298    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
299    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
300    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] sofia.c:6462 Remote Reason: 16
301    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
302    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 17 Tot 276)
303    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
304    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
305    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
306    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
307    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
308    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
309    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
310    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
311    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 17 Tot 276)
312    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
313    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
314    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
315    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
316    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
317    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
318    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
319    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
320    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 17 Tot 276)
321    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.850490 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
322    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.850490 [NOTICE] switch_core_session.c:1733 Session 248 (sofia/external/6046812011) Ended
323    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.850490 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
324    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_session.c:1715 Session 248 (sofia/external/6046812011) Locked, Waiting on external entities
325    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
326    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
327    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
328    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
329    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 18 Tot 276)
330    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
331    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
332    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
333    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
334    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
335    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
336    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 18 Tot 276)
337    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
338    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
339    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] sofia.c:6462 Remote Reason: 16
340    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
341    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 18 Tot 276)
342    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
343    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
344    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
345    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
346    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
347    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
348    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
349    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
350    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 18 Tot 276)
351    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
352    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
353    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
354    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
355    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
356    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
357    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
358    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
359    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 18 Tot 276)
360    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
361    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_session.c:1733 Session 250 (sofia/external/6046812011) Ended
362    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
363    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_session.c:1715 Session 250 (sofia/external/6046812011) Locked, Waiting on external entities
364    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
365    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
366    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
367    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
368    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 19 Tot 276)
369    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
370    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
371    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
372    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
373    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
374    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
375    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 19 Tot 276)
376    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
377    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
378    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] sofia.c:6462 Remote Reason: 16
379    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
380    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 19 Tot 276)
381    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
382    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
383    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
384    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
385    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
386    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
387    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
388    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
389    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 19 Tot 276)
390    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
391    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
392    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
393    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
394    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
395    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
396    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
397    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
398    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 19 Tot 276)
399    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
400    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_session.c:1733 Session 252 (sofia/external/6046812011) Ended
401    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
402    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
403    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
404    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
405    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
406    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
407    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
408    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
409    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
410    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 20 Tot 276)
411    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 20 Tot 276)
412    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
413    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_session.c:1733 Session 265 (sofia/internal/600@192.168.1.83:5060) Ended
414    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
415    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_session.c:1715 Session 265 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
416    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [NOTICE] switch_core_session.c:1733 Session 267 (sofia/internal/600@192.168.1.83:5060) Ended
417    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
418    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_session.c:1715 Session 267 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
419    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
420    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
421    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
422    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
423    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.830493 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
424    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_session.c:1715 Session 252 (sofia/external/6046812011) Locked, Waiting on external entities
425    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
426    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
427    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
428    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
429    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 22 Tot 276)
430    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
431    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
432    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
433    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
434    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
435    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
436    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 22 Tot 276)
437    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
438    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
439    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] sofia.c:6462 Remote Reason: 16
440    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
441    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 22 Tot 276)
442    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
443    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
444    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
445    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
446    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
447    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
448    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
449    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
450    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 22 Tot 276)
451    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
452    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
453    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
454    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
455    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
456    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
457    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
458    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
459    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 22 Tot 276)
460    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
461    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_session.c:1733 Session 254 (sofia/external/6046812011) Ended
462    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
463    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_session.c:1715 Session 254 (sofia/external/6046812011) Locked, Waiting on external entities
464    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
465    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
466    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
467    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
468    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 23 Tot 276)
469    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
470    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
471    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
472    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
473    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
474    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
475    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 23 Tot 276)
476    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
477    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
478    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
479    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
480    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
481    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
482    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 23 Tot 276)
483    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
484    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_session.c:1733 Session 269 (sofia/internal/600@192.168.1.83:5060) Ended
485    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_session.c:1715 Session 269 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
486    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
487    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] sofia.c:6462 Remote Reason: 16
488    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
489    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
490    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
491    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 24 Tot 276)
492    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
493    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
494    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
495    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
496    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
497    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
498    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
499    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
500    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 24 Tot 276)
501    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
502    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
503    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
504    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
505    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
506    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
507    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
508    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
509    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 24 Tot 276)
510    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
511    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.810484 [NOTICE] switch_core_session.c:1733 Session 256 (sofia/external/6046812011) Ended
512    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.810484 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
513    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_session.c:1715 Session 256 (sofia/external/6046812011) Locked, Waiting on external entities
514    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
515    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
516    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
517    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
518    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 25 Tot 276)
519    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
520    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
521    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
522    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
523    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
524    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
525    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 25 Tot 276)
526    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
527    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
528    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] sofia.c:6462 Remote Reason: 16
529    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
530    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 25 Tot 276)
531    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
532    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
533    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
534    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
535    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
536    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
537    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
538    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
539    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 25 Tot 276)
540    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
541    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
542    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
543    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
544    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
545    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
546    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
547    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
548    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 25 Tot 276)
549    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
550    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_session.c:1733 Session 258 (sofia/external/6046812011) Ended
551    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
552    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_session.c:1715 Session 258 (sofia/external/6046812011) Locked, Waiting on external entities
553    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
554    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
555    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
556    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
557    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 26 Tot 276)
558    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
559    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
560    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
561    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
562    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
563    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
564    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 26 Tot 276)
565    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
566    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
567    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] sofia.c:6462 Remote Reason: 16
568    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
569    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 26 Tot 276)
570    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
571    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
572    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
573    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
574    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
575    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
576    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
577    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
578    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 26 Tot 276)
579    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
580    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
581    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
582    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
583    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
584    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
585    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
586    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
587    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 26 Tot 276)
588    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
589    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_session.c:1733 Session 260 (sofia/external/6046812011) Ended
590    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
591    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_session.c:1715 Session 260 (sofia/external/6046812011) Locked, Waiting on external entities
592    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
593    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
594    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
595    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
596    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 27 Tot 276)
597    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
598    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
599    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
600    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
601    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
602    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
603    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 27 Tot 276)
604    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
605    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
606    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] sofia.c:6462 Remote Reason: 16
607    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
608    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 27 Tot 276)
609    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
610    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
611    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
612    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
613    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
614    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
615    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
616    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
617    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 27 Tot 276)
618    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
619    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
620    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
621    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.790493 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
622    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
623    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
624    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
625    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
626    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
627    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
628    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
629    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
630    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
631    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
632    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
633    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
634    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 27 Tot 276)
635    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 27 Tot 276)
636    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 27 Tot 276)
637    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
638    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1733 Session 271 (sofia/internal/600@192.168.1.83:5060) Ended
639    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_session.c:1715 Session 271 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
640    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
641    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
642    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1733 Session 262 (sofia/external/6046812011) Ended
643    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
644    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
645    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1733 Session 273 (sofia/internal/600@192.168.1.83:5060) Ended
646    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_session.c:1715 Session 273 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
647    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
648    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
649    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
650    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
651    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
652    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_session.c:1715 Session 262 (sofia/external/6046812011) Locked, Waiting on external entities
653    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
654    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
655    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
656    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
657    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 30 Tot 276)
658    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
659    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
660    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
661    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
662    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
663    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
664    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 30 Tot 276)
665    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
666    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
667    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] sofia.c:6462 Remote Reason: 16
668    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
669    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 30 Tot 276)
670    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
671    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
672    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
673    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
674    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
675    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
676    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
677    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
678    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 30 Tot 276)
679    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
680    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
681    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
682    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
683    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
684    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
685    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
686    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
687    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 30 Tot 276)
688    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
689    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1733 Session 264 (sofia/external/6046812011) Ended
690    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
691    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY going to sleep
692    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:181 sofia/internal/600@192.168.1.83:5060 Standard DESTROY
693    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:354 sofia/internal/600@192.168.1.83:5060 SOFIA DESTROY
694    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:748 (sofia/internal/600@192.168.1.83:5060) State DESTROY
695    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:738 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_DESTROY (Cur 31 Tot 276)
696    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1737 Close Channel sofia/internal/600@192.168.1.83:5060 [CS_DESTROY]
697    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] switch_core_session.c:1733 Session 275 (sofia/internal/600@192.168.1.83:5060) Ended
698    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_session.c:1715 Session 275 (sofia/internal/600@192.168.1.83:5060) Locked, Waiting on external entities
699    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:610 (sofia/internal/600@192.168.1.83:5060) State Change CS_REPORTING -> CS_DESTROY
700    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING going to sleep
701    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:174 sofia/internal/600@192.168.1.83:5060 Standard REPORTING, cause: NORMAL_CLEARING
702    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_session.c:1715 Session 264 (sofia/external/6046812011) Locked, Waiting on external entities
703    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
704    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
705    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
706    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
707    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 32 Tot 276)
708    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
709    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
710    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
711    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
712    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
713    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
714    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 32 Tot 276)
715    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
716    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
717    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] sofia.c:6462 Remote Reason: 16
718    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
719    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 32 Tot 276)
720    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
721    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
722    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
723    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
724    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
725    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
726    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.770495 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
727    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
728    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 32 Tot 276)
729    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
730    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
731    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
732    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.750494 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
733    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
734    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
735    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
736    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
737    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 32 Tot 276)
738    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
739    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] switch_core_session.c:1733 Session 266 (sofia/external/6046812011) Ended
740    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
741    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_session.c:1715 Session 266 (sofia/external/6046812011) Locked, Waiting on external entities
742    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
743    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
744    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
745    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
746    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 33 Tot 276)
747    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
748    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
749    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
750    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
751    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
752    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
753    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 33 Tot 276)
754    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
755    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
756    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] sofia.c:6462 Remote Reason: 16
757    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
758    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 33 Tot 276)
759    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
760    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
761    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
762    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
763    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
764    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
765    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
766    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
767    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 33 Tot 276)
768    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
769    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
770    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
771    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
772    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
773    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
774    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
775    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
776    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 33 Tot 276)
777    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
778    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] switch_core_session.c:1733 Session 268 (sofia/external/6046812011) Ended
779    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
780    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_session.c:1715 Session 268 (sofia/external/6046812011) Locked, Waiting on external entities
781    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
782    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
783    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
784    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
785    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 34 Tot 276)
786    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
787    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
788    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
789    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
790    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
791    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
792    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 34 Tot 276)
793    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
794    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
795    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] sofia.c:6462 Remote Reason: 16
796    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
797    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 34 Tot 276)
798    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
799    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
800    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
801    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
802    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
803    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
804    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.750494 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
805    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
806    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 34 Tot 276)
807    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
808    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.730518 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
809    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.730518 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
810    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.730518 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
811    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
812    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
813    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
814    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
815    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 34 Tot 276)
816    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
817    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [NOTICE] switch_core_session.c:1733 Session 270 (sofia/external/6046812011) Ended
818    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
819    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_session.c:1715 Session 270 (sofia/external/6046812011) Locked, Waiting on external entities
820    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
821    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
822    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
823    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
824    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 35 Tot 276)
825    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
826    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
827    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
828    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
829    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
830    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
831    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 35 Tot 276)
832    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
833    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
834    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] sofia.c:6462 Remote Reason: 16
835    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
836    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 35 Tot 276)
837    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
838    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
839    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
840    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
841    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
842    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
843    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
844    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
845    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 35 Tot 276)
846    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
847    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
848    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
849    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
850    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
851    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
852    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
853    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
854    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 35 Tot 276)
855    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.730518 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
856    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.730518 [NOTICE] switch_core_session.c:1733 Session 272 (sofia/external/6046812011) Ended
857    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.730518 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
858    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_session.c:1715 Session 272 (sofia/external/6046812011) Locked, Waiting on external entities
859    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
860    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
861    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
862    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
863    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 36 Tot 276)
864    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
865    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
866    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
867    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
868    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
869    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
870    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 36 Tot 276)
871    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
872    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
873    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] sofia.c:6462 Remote Reason: 16
874    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
875    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 36 Tot 276)
876    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
877    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
878    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
879    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
880    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
881    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
882    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
883    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
884    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 36 Tot 276)
885    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
886    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
887    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
888    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_CLEARING
889    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
890    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
891    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
892    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
893    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 36 Tot 276)
894    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
895    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] switch_core_session.c:1733 Session 274 (sofia/external/6046812011) Ended
896    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 16 [NORMAL_CLEARING]
897    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_session.c:1715 Session 274 (sofia/external/6046812011) Locked, Waiting on external entities
898    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
899    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
900    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_CLEARING
901    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
902    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 37 Tot 276)
903    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
904    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
905    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_CLEARING
906    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_CLEARING
907    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
908    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
909    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 37 Tot 276)
910    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_CLEARING]
911    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
912    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] sofia.c:6462 Remote Reason: 16
913    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:935 (sofia/internal/600@192.168.1.83:5060) State REPORTING
914    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_REPORTING (Cur 37 Tot 276)
915    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:619 (sofia/internal/600@192.168.1.83:5060) State Change CS_HANGUP -> CS_REPORTING
916    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP going to sleep
917    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:60 sofia/internal/600@192.168.1.83:5060 Standard HANGUP, cause: NORMAL_CLEARING
918    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 503
919    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY going to sleep
920    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:181 sofia/external/6046812011 Standard DESTROY
921    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:354 sofia/external/6046812011 SOFIA DESTROY
922    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:748 (sofia/external/6046812011) State DESTROY
923    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:449 Channel sofia/internal/600@192.168.1.83:5060 hanging up, cause: NORMAL_CLEARING
924    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:443 sofia/internal/600@192.168.1.83:5060 Overriding SIP cause 480 with 503 from the other leg
925    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/internal/600@192.168.1.83:5060) State HANGUP
926    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:738 (sofia/external/6046812011) Running State Change CS_DESTROY (Cur 37 Tot 276)
927    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:847 (sofia/internal/600@192.168.1.83:5060) Callstate Change RINGING -> HANGUP
928    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] switch_core_session.c:1737 Close Channel sofia/external/6046812011 [CS_DESTROY]
929    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] switch_core_session.c:1733 Session 276 (sofia/external/6046812011) Ended
930    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_HANGUP (Cur 38 Tot 276)
931    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE going to sleep
932    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/600@192.168.1.83:5060 [CS_EXECUTE] [NORMAL_CLEARING]
933    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] switch_core_state_machine.c:385 sofia/internal/600@192.168.1.83:5060 has executed the last dialplan instruction, hanging up.
934    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_session.c:1715 Session 276 (sofia/external/6046812011) Locked, Waiting on external entities
935    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:610 (sofia/external/6046812011) State Change CS_REPORTING -> CS_DESTROY
936    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [INFO] mod_dptools.c:3518 Originate Failed. Cause: NORMAL_TEMPORARY_FAILURE
937    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING going to sleep
938    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:174 sofia/external/6046812011 Standard REPORTING, cause: NORMAL_TEMPORARY_FAILURE
939    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:935 (sofia/external/6046812011) State REPORTING
940    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_REPORTING (Cur 38 Tot 276)
941    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:619 (sofia/external/6046812011) State Change CS_HANGUP -> CS_REPORTING
942    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP going to sleep
943    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:60 sofia/external/6046812011 Standard HANGUP, cause: NORMAL_TEMPORARY_FAILURE
944    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:449 Channel sofia/external/6046812011 hanging up, cause: NORMAL_TEMPORARY_FAILURE
945    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:849 (sofia/external/6046812011) State HANGUP
946    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:847 (sofia/external/6046812011) Callstate Change DOWN -> HANGUP
947    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_ivr_originate.c:3941 Originate Resulted in Error Cause: 41 [NORMAL_TEMPORARY_FAILURE]
948    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_HANGUP (Cur 38 Tot 276)
949    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] sofia.c:8484 Hangup sofia/external/6046812011 [CS_CONSUME_MEDIA] [NORMAL_TEMPORARY_FAILURE]
950    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [terminated][503]
951    2019-09-12 16:49:32.710485 [CRIT] switch_core_session.c:2346 Throttle Error! 38
952    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
953    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
954    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
955    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 38 Tot 276)
956    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
957    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
958    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
959    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
960    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 38 Tot 276)
961    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
962    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
963    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
964    f7f328c8-d5b7-11e9-b30c-213a7b2c3076
965    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 a=sendrecv
966    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 a=ptime:20
967    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 a=rtpmap:13 CN/8000
968    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 a=fmtp:101 0-16
969    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 a=rtpmap:101 telephone-event/8000
970    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 a=rtpmap:8 PCMA/8000
971    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 a=rtpmap:0 PCMU/8000
972    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 m=audio 23052 RTP/AVP 0 8 101 13
973    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 t=0 0
974    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 c=IN IP4 192.168.1.83
975    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 s=FreeSWITCH
976    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 o=FreeSWITCH 1568309120 1568309121 IN IP4 192.168.1.83
977    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 v=0
978    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 Local SDP:
979    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
980    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
981    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
982    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 38 Tot 276)
983    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
984    f7f328c8-d5b7-11e9-b30c-213a7b2c3076 2019-09-12 16:49:32.710485 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7f328c8-d5b7-11e9-b30c-213a7b2c3076]
985    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
986    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
987    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
988    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
989    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
990    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
991    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
992    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
993    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
994    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
995    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
996    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
997    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
998    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
999    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
1000    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
1001    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
1002    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
1003    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
1004    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
1005    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
1006    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
1007    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
1008    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
1009    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
1010    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
1011    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
1012    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
1013    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
1014    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.710485 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
1015    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
1016    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
1017    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
1018    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
1019    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
1020    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
1021    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 37 Tot 275)
1022    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
1023    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
1024    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
1025    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
1026    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
1027    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
1028    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
1029    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
1030    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
1031    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
1032    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
1033    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
1034    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
1035    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
1036    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
1037    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
1038    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
1039    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
1040    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
1041    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
1042    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
1043    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
1044    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
1045    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
1046    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
1047    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
1048    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
1049    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
1050    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
1051    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
1052    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
1053    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
1054    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
1055    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
1056    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
1057    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
1058    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
1059    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
1060    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
1061    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1062    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1063    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
1064    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1065    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1066    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
1067    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1068    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1069    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
1070    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1071    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
1072    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
1073    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
1074    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1075    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
1076    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1077    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1078    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
1079    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1080    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1081    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
1082    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1083    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1084    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
1085    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1086    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
1087    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
1088    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
1089    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
1090    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
1091    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
1092    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
1093    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
1094    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
1095    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
1096    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
1097    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
1098    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
1099    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
1100    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
1101    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
1102    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
1103    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
1104    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
1105    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
1106    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
1107    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
1108    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
1109    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
1110    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
1111    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
1112    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
1113    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
1114    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
1115    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
1116    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
1117    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
1118    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
1119    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
1120    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 37 Tot 275)
1121    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
1122    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
1123    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
1124    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
1125    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
1126    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 37 Tot 275)
1127    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
1128    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
1129    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
1130    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
1131    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
1132    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
1133    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
1134    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1135    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
1136    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
1137    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1138    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
1139    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
1140    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
1141    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076
1142    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 a=ptime:20
1143    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 a=rtpmap:13 CN/8000
1144    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 a=fmtp:101 0-16
1145    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 a=rtpmap:101 telephone-event/8000
1146    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 a=rtpmap:8 PCMA/8000
1147    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 a=rtpmap:0 PCMU/8000
1148    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 m=audio 27092 RTP/AVP 0 8 101 13
1149    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 t=0 0
1150    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 c=IN IP4 192.168.1.83
1151    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 s=FreeSWITCH
1152    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 o=FreeSWITCH 1568305080 1568305081 IN IP4 192.168.1.83
1153    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 v=0
1154    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] sofia.c:7301 Remote SDP:
1155    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.690498 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
1156    2019-09-12 16:49:32.670491 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
1157    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.670491 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
1158    2019-09-12 16:49:32.650495 [DEBUG] sofia.c:2522 Re-attaching to session f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076
1159    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
1160    2019-09-12 16:49:32.650495 [DEBUG] sofia.c:2413 detaching session f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076
1161    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
1162    2019-09-12 16:49:32.650495 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
1163    2019-09-12 16:49:32.650495 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
1164    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
1165    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 37 Tot 275)
1166    f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076 2019-09-12 16:49:32.650495 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7ebd8de-d5b7-11e9-b2ee-213a7b2c3076]
1167    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
1168    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
1169    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
1170    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 36 Tot 274)
1171    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
1172    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
1173    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
1174    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
1175    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 36 Tot 274)
1176    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
1177    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
1178    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
1179    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076
1180    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 a=sendrecv
1181    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 a=ptime:20
1182    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 a=rtpmap:13 CN/8000
1183    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 a=fmtp:101 0-16
1184    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 a=rtpmap:101 telephone-event/8000
1185    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 a=rtpmap:8 PCMA/8000
1186    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 a=rtpmap:0 PCMU/8000
1187    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 m=audio 27092 RTP/AVP 0 8 101 13
1188    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 t=0 0
1189    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 c=IN IP4 192.168.1.83
1190    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 s=FreeSWITCH
1191    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 o=FreeSWITCH 1568305080 1568305081 IN IP4 192.168.1.83
1192    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 v=0
1193    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 Local SDP:
1194    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
1195    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
1196    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
1197    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 36 Tot 274)
1198    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
1199    f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076 2019-09-12 16:49:32.650495 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7ebb1d8-d5b7-11e9-b2ea-213a7b2c3076]
1200    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
1201    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
1202    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
1203    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
1204    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
1205    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
1206    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
1207    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
1208    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
1209    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
1210    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
1211    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
1212    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
1213    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
1214    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
1215    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
1216    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
1217    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
1218    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
1219    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
1220    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
1221    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
1222    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
1223    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
1224    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
1225    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
1226    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
1227    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
1228    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
1229    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
1230    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
1231    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
1232    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
1233    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
1234    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
1235    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
1236    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 35 Tot 273)
1237    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
1238    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
1239    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
1240    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
1241    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
1242    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
1243    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
1244    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
1245    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
1246    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
1247    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
1248    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
1249    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
1250    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
1251    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
1252    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
1253    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
1254    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
1255    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
1256    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
1257    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
1258    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
1259    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
1260    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
1261    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
1262    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
1263    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
1264    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
1265    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
1266    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
1267    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
1268    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
1269    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
1270    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
1271    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
1272    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
1273    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
1274    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
1275    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
1276    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1277    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1278    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
1279    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1280    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1281    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
1282    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1283    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1284    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
1285    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1286    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
1287    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
1288    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
1289    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1290    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
1291    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1292    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1293    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
1294    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1295    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1296    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
1297    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1298    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1299    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
1300    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1301    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
1302    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
1303    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
1304    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
1305    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
1306    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
1307    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
1308    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
1309    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
1310    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
1311    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
1312    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
1313    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
1314    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
1315    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
1316    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
1317    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
1318    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
1319    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
1320    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
1321    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
1322    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
1323    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
1324    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
1325    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.650495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
1326    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
1327    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
1328    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
1329    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
1330    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
1331    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
1332    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
1333    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
1334    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
1335    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 35 Tot 273)
1336    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
1337    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
1338    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
1339    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
1340    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
1341    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 35 Tot 273)
1342    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
1343    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
1344    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
1345    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
1346    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
1347    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
1348    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
1349    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1350    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
1351    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
1352    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1353    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
1354    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
1355    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
1356    f7e455be-d5b7-11e9-b2cc-213a7b2c3076
1357    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 a=ptime:20
1358    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 a=rtpmap:13 CN/8000
1359    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 a=fmtp:101 0-16
1360    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 a=rtpmap:101 telephone-event/8000
1361    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 a=rtpmap:8 PCMA/8000
1362    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 a=rtpmap:0 PCMU/8000
1363    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 m=audio 32498 RTP/AVP 0 8 101 13
1364    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 t=0 0
1365    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 c=IN IP4 192.168.1.83
1366    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 s=FreeSWITCH
1367    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 o=FreeSWITCH 1568299674 1568299675 IN IP4 192.168.1.83
1368    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 v=0
1369    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] sofia.c:7301 Remote SDP:
1370    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
1371    2019-09-12 16:49:32.630491 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
1372    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.630491 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
1373    2019-09-12 16:49:32.610487 [DEBUG] sofia.c:2522 Re-attaching to session f7e455be-d5b7-11e9-b2cc-213a7b2c3076
1374    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
1375    2019-09-12 16:49:32.610487 [DEBUG] sofia.c:2413 detaching session f7e455be-d5b7-11e9-b2cc-213a7b2c3076
1376    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
1377    2019-09-12 16:49:32.610487 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
1378    2019-09-12 16:49:32.610487 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
1379    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
1380    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 35 Tot 273)
1381    f7e455be-d5b7-11e9-b2cc-213a7b2c3076 2019-09-12 16:49:32.610487 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7e455be-d5b7-11e9-b2cc-213a7b2c3076]
1382    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
1383    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
1384    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
1385    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 34 Tot 272)
1386    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
1387    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
1388    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
1389    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
1390    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 34 Tot 272)
1391    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
1392    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
1393    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
1394    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076
1395    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 a=sendrecv
1396    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 a=ptime:20
1397    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 a=rtpmap:13 CN/8000
1398    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 a=fmtp:101 0-16
1399    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 a=rtpmap:101 telephone-event/8000
1400    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 a=rtpmap:8 PCMA/8000
1401    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 a=rtpmap:0 PCMU/8000
1402    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 m=audio 32498 RTP/AVP 0 8 101 13
1403    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 t=0 0
1404    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 c=IN IP4 192.168.1.83
1405    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 s=FreeSWITCH
1406    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 o=FreeSWITCH 1568299674 1568299675 IN IP4 192.168.1.83
1407    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 v=0
1408    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 Local SDP:
1409    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
1410    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
1411    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
1412    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 34 Tot 272)
1413    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
1414    f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076 2019-09-12 16:49:32.610487 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7e42eb8-d5b7-11e9-b2c8-213a7b2c3076]
1415    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
1416    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
1417    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
1418    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
1419    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
1420    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
1421    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
1422    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
1423    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
1424    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
1425    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
1426    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
1427    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
1428    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
1429    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
1430    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
1431    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
1432    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
1433    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
1434    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
1435    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
1436    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
1437    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
1438    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
1439    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
1440    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
1441    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
1442    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
1443    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
1444    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
1445    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
1446    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
1447    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
1448    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
1449    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
1450    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
1451    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 33 Tot 271)
1452    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
1453    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
1454    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
1455    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
1456    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
1457    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
1458    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
1459    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
1460    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
1461    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
1462    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
1463    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
1464    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
1465    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
1466    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
1467    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
1468    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
1469    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
1470    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
1471    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
1472    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
1473    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
1474    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
1475    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
1476    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
1477    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
1478    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
1479    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
1480    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
1481    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
1482    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
1483    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
1484    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
1485    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
1486    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
1487    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
1488    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
1489    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
1490    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
1491    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1492    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1493    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
1494    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1495    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1496    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
1497    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1498    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1499    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
1500    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1501    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.610487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
1502    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
1503    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
1504    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1505    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
1506    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1507    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1508    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
1509    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1510    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1511    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
1512    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1513    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1514    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
1515    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1516    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
1517    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
1518    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
1519    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
1520    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
1521    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
1522    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
1523    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
1524    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
1525    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
1526    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
1527    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
1528    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
1529    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
1530    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
1531    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
1532    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
1533    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
1534    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
1535    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
1536    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
1537    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
1538    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
1539    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
1540    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
1541    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
1542    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
1543    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
1544    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
1545    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
1546    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
1547    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
1548    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
1549    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
1550    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 33 Tot 271)
1551    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
1552    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
1553    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
1554    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
1555    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
1556    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 33 Tot 271)
1557    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
1558    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
1559    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
1560    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
1561    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
1562    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
1563    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
1564    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1565    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
1566    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
1567    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1568    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
1569    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
1570    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
1571    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076
1572    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 a=ptime:20
1573    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 a=rtpmap:13 CN/8000
1574    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 a=fmtp:101 0-16
1575    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 a=rtpmap:101 telephone-event/8000
1576    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 a=rtpmap:8 PCMA/8000
1577    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 a=rtpmap:0 PCMU/8000
1578    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 m=audio 19732 RTP/AVP 0 8 101 13
1579    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 t=0 0
1580    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 c=IN IP4 192.168.1.83
1581    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 s=FreeSWITCH
1582    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 o=FreeSWITCH 1568312440 1568312441 IN IP4 192.168.1.83
1583    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 v=0
1584    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] sofia.c:7301 Remote SDP:
1585    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.590498 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
1586    2019-09-12 16:49:32.570492 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
1587    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.570492 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
1588    2019-09-12 16:49:32.550493 [DEBUG] sofia.c:2522 Re-attaching to session f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076
1589    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
1590    2019-09-12 16:49:32.550493 [DEBUG] sofia.c:2413 detaching session f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076
1591    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
1592    2019-09-12 16:49:32.550493 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
1593    2019-09-12 16:49:32.550493 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
1594    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
1595    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 33 Tot 271)
1596    f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076 2019-09-12 16:49:32.550493 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7dcd9c4-d5b7-11e9-b2aa-213a7b2c3076]
1597    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
1598    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
1599    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
1600    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 32 Tot 270)
1601    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
1602    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
1603    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
1604    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
1605    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 32 Tot 270)
1606    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
1607    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
1608    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
1609    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076
1610    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 a=sendrecv
1611    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 a=ptime:20
1612    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 a=rtpmap:13 CN/8000
1613    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 a=fmtp:101 0-16
1614    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 a=rtpmap:101 telephone-event/8000
1615    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 a=rtpmap:8 PCMA/8000
1616    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 a=rtpmap:0 PCMU/8000
1617    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 m=audio 19732 RTP/AVP 0 8 101 13
1618    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 t=0 0
1619    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 c=IN IP4 192.168.1.83
1620    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 s=FreeSWITCH
1621    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 o=FreeSWITCH 1568312440 1568312441 IN IP4 192.168.1.83
1622    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 v=0
1623    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 Local SDP:
1624    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
1625    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
1626    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
1627    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 32 Tot 270)
1628    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
1629    f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076 2019-09-12 16:49:32.550493 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7dcb50c-d5b7-11e9-b2a6-213a7b2c3076]
1630    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
1631    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
1632    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
1633    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
1634    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
1635    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
1636    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
1637    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
1638    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
1639    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
1640    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
1641    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
1642    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
1643    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
1644    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
1645    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
1646    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
1647    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
1648    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
1649    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
1650    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
1651    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
1652    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
1653    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
1654    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
1655    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
1656    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
1657    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
1658    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
1659    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
1660    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
1661    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
1662    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
1663    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
1664    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
1665    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
1666    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 31 Tot 269)
1667    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
1668    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
1669    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
1670    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
1671    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
1672    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
1673    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
1674    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
1675    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
1676    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
1677    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
1678    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
1679    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
1680    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
1681    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
1682    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
1683    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
1684    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
1685    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
1686    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
1687    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
1688    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
1689    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
1690    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
1691    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
1692    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
1693    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
1694    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
1695    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
1696    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
1697    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
1698    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
1699    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
1700    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
1701    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
1702    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
1703    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
1704    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
1705    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
1706    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1707    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1708    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
1709    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1710    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1711    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
1712    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1713    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1714    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
1715    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1716    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
1717    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
1718    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
1719    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1720    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
1721    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1722    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1723    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
1724    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1725    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1726    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
1727    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1728    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1729    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
1730    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1731    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
1732    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
1733    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
1734    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
1735    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
1736    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
1737    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
1738    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
1739    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
1740    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
1741    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
1742    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
1743    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
1744    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
1745    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
1746    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
1747    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
1748    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
1749    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
1750    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
1751    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
1752    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
1753    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
1754    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
1755    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.550493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
1756    f7d583cc-d5b7-11e9-b288-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
1757    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
1758    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
1759    f7d583cc-d5b7-11e9-b288-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
1760    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
1761    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
1762    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
1763    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
1764    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
1765    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 31 Tot 269)
1766    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
1767    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
1768    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
1769    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
1770    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
1771    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 31 Tot 269)
1772    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
1773    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
1774    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
1775    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
1776    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
1777    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
1778    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
1779    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1780    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
1781    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
1782    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1783    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
1784    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
1785    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
1786    f7d583cc-d5b7-11e9-b288-213a7b2c3076
1787    f7d583cc-d5b7-11e9-b288-213a7b2c3076 a=ptime:20
1788    f7d583cc-d5b7-11e9-b288-213a7b2c3076 a=rtpmap:13 CN/8000
1789    f7d583cc-d5b7-11e9-b288-213a7b2c3076 a=fmtp:101 0-16
1790    f7d583cc-d5b7-11e9-b288-213a7b2c3076 a=rtpmap:101 telephone-event/8000
1791    f7d583cc-d5b7-11e9-b288-213a7b2c3076 a=rtpmap:8 PCMA/8000
1792    f7d583cc-d5b7-11e9-b288-213a7b2c3076 a=rtpmap:0 PCMU/8000
1793    f7d583cc-d5b7-11e9-b288-213a7b2c3076 m=audio 31064 RTP/AVP 0 8 101 13
1794    f7d583cc-d5b7-11e9-b288-213a7b2c3076 t=0 0
1795    f7d583cc-d5b7-11e9-b288-213a7b2c3076 c=IN IP4 192.168.1.83
1796    f7d583cc-d5b7-11e9-b288-213a7b2c3076 s=FreeSWITCH
1797    f7d583cc-d5b7-11e9-b288-213a7b2c3076 o=FreeSWITCH 1568301108 1568301109 IN IP4 192.168.1.83
1798    f7d583cc-d5b7-11e9-b288-213a7b2c3076 v=0
1799    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] sofia.c:7301 Remote SDP:
1800    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
1801    2019-09-12 16:49:32.530491 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
1802    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.530491 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
1803    2019-09-12 16:49:32.510485 [DEBUG] sofia.c:2522 Re-attaching to session f7d583cc-d5b7-11e9-b288-213a7b2c3076
1804    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
1805    2019-09-12 16:49:32.510485 [DEBUG] sofia.c:2413 detaching session f7d583cc-d5b7-11e9-b288-213a7b2c3076
1806    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
1807    2019-09-12 16:49:32.510485 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
1808    2019-09-12 16:49:32.510485 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
1809    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
1810    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 31 Tot 269)
1811    f7d583cc-d5b7-11e9-b288-213a7b2c3076 2019-09-12 16:49:32.510485 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7d583cc-d5b7-11e9-b288-213a7b2c3076]
1812    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
1813    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
1814    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
1815    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 30 Tot 268)
1816    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
1817    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
1818    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
1819    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
1820    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 30 Tot 268)
1821    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
1822    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
1823    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
1824    f7d559ec-d5b7-11e9-b284-213a7b2c3076
1825    f7d559ec-d5b7-11e9-b284-213a7b2c3076 a=sendrecv
1826    f7d559ec-d5b7-11e9-b284-213a7b2c3076 a=ptime:20
1827    f7d559ec-d5b7-11e9-b284-213a7b2c3076 a=rtpmap:13 CN/8000
1828    f7d559ec-d5b7-11e9-b284-213a7b2c3076 a=fmtp:101 0-16
1829    f7d559ec-d5b7-11e9-b284-213a7b2c3076 a=rtpmap:101 telephone-event/8000
1830    f7d559ec-d5b7-11e9-b284-213a7b2c3076 a=rtpmap:8 PCMA/8000
1831    f7d559ec-d5b7-11e9-b284-213a7b2c3076 a=rtpmap:0 PCMU/8000
1832    f7d559ec-d5b7-11e9-b284-213a7b2c3076 m=audio 31064 RTP/AVP 0 8 101 13
1833    f7d559ec-d5b7-11e9-b284-213a7b2c3076 t=0 0
1834    f7d559ec-d5b7-11e9-b284-213a7b2c3076 c=IN IP4 192.168.1.83
1835    f7d559ec-d5b7-11e9-b284-213a7b2c3076 s=FreeSWITCH
1836    f7d559ec-d5b7-11e9-b284-213a7b2c3076 o=FreeSWITCH 1568301108 1568301109 IN IP4 192.168.1.83
1837    f7d559ec-d5b7-11e9-b284-213a7b2c3076 v=0
1838    f7d559ec-d5b7-11e9-b284-213a7b2c3076 Local SDP:
1839    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
1840    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
1841    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
1842    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 30 Tot 268)
1843    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
1844    f7d559ec-d5b7-11e9-b284-213a7b2c3076 2019-09-12 16:49:32.510485 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7d559ec-d5b7-11e9-b284-213a7b2c3076]
1845    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
1846    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
1847    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
1848    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
1849    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
1850    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
1851    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
1852    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
1853    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
1854    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
1855    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
1856    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
1857    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
1858    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
1859    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
1860    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
1861    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
1862    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
1863    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
1864    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
1865    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
1866    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
1867    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
1868    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
1869    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
1870    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
1871    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
1872    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
1873    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
1874    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
1875    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
1876    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
1877    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
1878    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
1879    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
1880    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
1881    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 29 Tot 267)
1882    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
1883    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
1884    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
1885    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
1886    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
1887    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
1888    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
1889    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
1890    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
1891    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
1892    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
1893    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
1894    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
1895    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
1896    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
1897    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
1898    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
1899    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
1900    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
1901    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
1902    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
1903    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
1904    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
1905    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
1906    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
1907    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
1908    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
1909    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
1910    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
1911    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
1912    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
1913    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
1914    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
1915    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
1916    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
1917    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
1918    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
1919    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
1920    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
1921    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1922    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1923    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
1924    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1925    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1926    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
1927    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1928    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1929    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
1930    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1931    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
1932    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
1933    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
1934    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
1935    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
1936    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
1937    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1938    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
1939    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
1940    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1941    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
1942    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
1943    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1944    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
1945    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
1946    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.510485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
1947    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
1948    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
1949    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
1950    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
1951    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
1952    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
1953    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
1954    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
1955    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
1956    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
1957    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
1958    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
1959    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
1960    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
1961    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
1962    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
1963    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
1964    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
1965    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
1966    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
1967    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
1968    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
1969    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
1970    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
1971    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
1972    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
1973    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
1974    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
1975    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
1976    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
1977    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
1978    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
1979    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
1980    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 29 Tot 267)
1981    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
1982    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
1983    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
1984    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
1985    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
1986    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 29 Tot 267)
1987    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
1988    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
1989    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
1990    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
1991    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
1992    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
1993    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
1994    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1995    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
1996    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
1997    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
1998    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
1999    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2000    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2001    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076
2002    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 a=ptime:20
2003    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 a=rtpmap:13 CN/8000
2004    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 a=fmtp:101 0-16
2005    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2006    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 a=rtpmap:8 PCMA/8000
2007    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 a=rtpmap:0 PCMU/8000
2008    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 m=audio 16728 RTP/AVP 0 8 101 13
2009    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 t=0 0
2010    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 c=IN IP4 192.168.1.83
2011    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 s=FreeSWITCH
2012    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 o=FreeSWITCH 1568315444 1568315445 IN IP4 192.168.1.83
2013    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 v=0
2014    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] sofia.c:7301 Remote SDP:
2015    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.490498 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
2016    2019-09-12 16:49:32.470492 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2017    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.470492 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2018    2019-09-12 16:49:32.450493 [DEBUG] sofia.c:2522 Re-attaching to session f7cd8cc6-d5b7-11e9-b266-213a7b2c3076
2019    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2020    2019-09-12 16:49:32.450493 [DEBUG] sofia.c:2413 detaching session f7cd8cc6-d5b7-11e9-b266-213a7b2c3076
2021    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
2022    2019-09-12 16:49:32.450493 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
2023    2019-09-12 16:49:32.450493 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2024    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2025    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 29 Tot 267)
2026    f7cd8cc6-d5b7-11e9-b266-213a7b2c3076 2019-09-12 16:49:32.450493 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7cd8cc6-d5b7-11e9-b266-213a7b2c3076]
2027    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
2028    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
2029    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2030    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 28 Tot 266)
2031    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
2032    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2033    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
2034    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
2035    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 28 Tot 266)
2036    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
2037    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
2038    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
2039    f7cd6836-d5b7-11e9-b262-213a7b2c3076
2040    f7cd6836-d5b7-11e9-b262-213a7b2c3076 a=sendrecv
2041    f7cd6836-d5b7-11e9-b262-213a7b2c3076 a=ptime:20
2042    f7cd6836-d5b7-11e9-b262-213a7b2c3076 a=rtpmap:13 CN/8000
2043    f7cd6836-d5b7-11e9-b262-213a7b2c3076 a=fmtp:101 0-16
2044    f7cd6836-d5b7-11e9-b262-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2045    f7cd6836-d5b7-11e9-b262-213a7b2c3076 a=rtpmap:8 PCMA/8000
2046    f7cd6836-d5b7-11e9-b262-213a7b2c3076 a=rtpmap:0 PCMU/8000
2047    f7cd6836-d5b7-11e9-b262-213a7b2c3076 m=audio 16728 RTP/AVP 0 8 101 13
2048    f7cd6836-d5b7-11e9-b262-213a7b2c3076 t=0 0
2049    f7cd6836-d5b7-11e9-b262-213a7b2c3076 c=IN IP4 192.168.1.83
2050    f7cd6836-d5b7-11e9-b262-213a7b2c3076 s=FreeSWITCH
2051    f7cd6836-d5b7-11e9-b262-213a7b2c3076 o=FreeSWITCH 1568315444 1568315445 IN IP4 192.168.1.83
2052    f7cd6836-d5b7-11e9-b262-213a7b2c3076 v=0
2053    f7cd6836-d5b7-11e9-b262-213a7b2c3076 Local SDP:
2054    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
2055    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
2056    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
2057    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 28 Tot 266)
2058    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
2059    f7cd6836-d5b7-11e9-b262-213a7b2c3076 2019-09-12 16:49:32.450493 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7cd6836-d5b7-11e9-b262-213a7b2c3076]
2060    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
2061    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2062    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
2063    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2064    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
2065    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2066    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
2067    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
2068    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
2069    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
2070    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
2071    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
2072    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
2073    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
2074    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
2075    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
2076    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
2077    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
2078    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
2079    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
2080    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
2081    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
2082    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
2083    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
2084    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
2085    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
2086    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
2087    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
2088    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
2089    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
2090    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
2091    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
2092    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
2093    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
2094    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
2095    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
2096    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 27 Tot 265)
2097    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
2098    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
2099    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2100    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
2101    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
2102    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
2103    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
2104    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
2105    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
2106    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
2107    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
2108    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
2109    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
2110    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
2111    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
2112    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
2113    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
2114    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
2115    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
2116    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
2117    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
2118    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
2119    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
2120    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
2121    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
2122    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
2123    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
2124    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
2125    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
2126    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
2127    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
2128    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
2129    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
2130    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
2131    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
2132    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
2133    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
2134    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
2135    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
2136    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
2137    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2138    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
2139    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
2140    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2141    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
2142    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
2143    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2144    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
2145    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2146    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
2147    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
2148    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
2149    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2150    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
2151    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
2152    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2153    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
2154    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
2155    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2156    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
2157    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
2158    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2159    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
2160    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2161    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
2162    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
2163    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
2164    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
2165    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
2166    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
2167    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
2168    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
2169    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
2170    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
2171    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
2172    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
2173    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
2174    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
2175    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
2176    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
2177    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
2178    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
2179    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
2180    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
2181    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
2182    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
2183    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
2184    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
2185    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.450493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
2186    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
2187    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
2188    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
2189    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
2190    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
2191    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
2192    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
2193    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
2194    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
2195    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 27 Tot 265)
2196    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
2197    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
2198    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
2199    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
2200    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
2201    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 27 Tot 265)
2202    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
2203    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
2204    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
2205    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
2206    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
2207    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
2208    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2209    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2210    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2211    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2212    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2213    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2214    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2215    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2216    f7c63ebc-d5b7-11e9-b244-213a7b2c3076
2217    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 a=ptime:20
2218    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 a=rtpmap:13 CN/8000
2219    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 a=fmtp:101 0-16
2220    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2221    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 a=rtpmap:8 PCMA/8000
2222    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 a=rtpmap:0 PCMU/8000
2223    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 m=audio 28396 RTP/AVP 0 8 101 13
2224    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 t=0 0
2225    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 c=IN IP4 192.168.1.83
2226    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 s=FreeSWITCH
2227    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 o=FreeSWITCH 1568303776 1568303777 IN IP4 192.168.1.83
2228    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 v=0
2229    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] sofia.c:7301 Remote SDP:
2230    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
2231    2019-09-12 16:49:32.430491 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2232    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.430491 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2233    2019-09-12 16:49:32.410485 [DEBUG] sofia.c:2522 Re-attaching to session f7c63ebc-d5b7-11e9-b244-213a7b2c3076
2234    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2235    2019-09-12 16:49:32.410485 [DEBUG] sofia.c:2413 detaching session f7c63ebc-d5b7-11e9-b244-213a7b2c3076
2236    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
2237    2019-09-12 16:49:32.410485 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
2238    2019-09-12 16:49:32.410485 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2239    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2240    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 27 Tot 265)
2241    f7c63ebc-d5b7-11e9-b244-213a7b2c3076 2019-09-12 16:49:32.410485 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7c63ebc-d5b7-11e9-b244-213a7b2c3076]
2242    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
2243    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
2244    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2245    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 26 Tot 264)
2246    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
2247    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2248    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
2249    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
2250    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 26 Tot 264)
2251    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
2252    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
2253    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
2254    f7c6186a-d5b7-11e9-b240-213a7b2c3076
2255    f7c6186a-d5b7-11e9-b240-213a7b2c3076 a=sendrecv
2256    f7c6186a-d5b7-11e9-b240-213a7b2c3076 a=ptime:20
2257    f7c6186a-d5b7-11e9-b240-213a7b2c3076 a=rtpmap:13 CN/8000
2258    f7c6186a-d5b7-11e9-b240-213a7b2c3076 a=fmtp:101 0-16
2259    f7c6186a-d5b7-11e9-b240-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2260    f7c6186a-d5b7-11e9-b240-213a7b2c3076 a=rtpmap:8 PCMA/8000
2261    f7c6186a-d5b7-11e9-b240-213a7b2c3076 a=rtpmap:0 PCMU/8000
2262    f7c6186a-d5b7-11e9-b240-213a7b2c3076 m=audio 28396 RTP/AVP 0 8 101 13
2263    f7c6186a-d5b7-11e9-b240-213a7b2c3076 t=0 0
2264    f7c6186a-d5b7-11e9-b240-213a7b2c3076 c=IN IP4 192.168.1.83
2265    f7c6186a-d5b7-11e9-b240-213a7b2c3076 s=FreeSWITCH
2266    f7c6186a-d5b7-11e9-b240-213a7b2c3076 o=FreeSWITCH 1568303776 1568303777 IN IP4 192.168.1.83
2267    f7c6186a-d5b7-11e9-b240-213a7b2c3076 v=0
2268    f7c6186a-d5b7-11e9-b240-213a7b2c3076 Local SDP:
2269    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
2270    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
2271    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
2272    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 26 Tot 264)
2273    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
2274    f7c6186a-d5b7-11e9-b240-213a7b2c3076 2019-09-12 16:49:32.410485 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7c6186a-d5b7-11e9-b240-213a7b2c3076]
2275    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
2276    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2277    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
2278    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2279    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
2280    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2281    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
2282    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
2283    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
2284    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
2285    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
2286    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
2287    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
2288    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
2289    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
2290    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
2291    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
2292    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
2293    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
2294    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
2295    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
2296    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
2297    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
2298    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
2299    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
2300    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
2301    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
2302    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
2303    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
2304    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
2305    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
2306    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
2307    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
2308    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
2309    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
2310    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
2311    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 25 Tot 263)
2312    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
2313    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
2314    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2315    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
2316    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
2317    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
2318    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
2319    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
2320    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
2321    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
2322    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
2323    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
2324    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
2325    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
2326    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
2327    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
2328    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
2329    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
2330    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
2331    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
2332    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
2333    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
2334    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
2335    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
2336    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
2337    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
2338    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
2339    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
2340    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
2341    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
2342    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
2343    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
2344    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
2345    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
2346    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
2347    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
2348    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
2349    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
2350    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
2351    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
2352    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2353    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
2354    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
2355    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2356    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
2357    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
2358    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2359    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
2360    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2361    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
2362    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
2363    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
2364    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2365    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
2366    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
2367    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2368    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
2369    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
2370    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2371    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
2372    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
2373    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2374    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
2375    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2376    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.410485 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
2377    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
2378    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
2379    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
2380    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
2381    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
2382    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
2383    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
2384    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
2385    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
2386    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
2387    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
2388    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
2389    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
2390    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
2391    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
2392    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
2393    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
2394    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
2395    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
2396    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
2397    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
2398    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
2399    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
2400    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
2401    f7be5878-d5b7-11e9-b222-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
2402    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
2403    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
2404    f7be5878-d5b7-11e9-b222-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
2405    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
2406    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
2407    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
2408    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
2409    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
2410    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 25 Tot 263)
2411    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
2412    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
2413    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
2414    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
2415    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
2416    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 25 Tot 263)
2417    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
2418    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
2419    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
2420    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
2421    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
2422    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
2423    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2424    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2425    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2426    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2427    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2428    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2429    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2430    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2431    f7be5878-d5b7-11e9-b222-213a7b2c3076
2432    f7be5878-d5b7-11e9-b222-213a7b2c3076 a=ptime:20
2433    f7be5878-d5b7-11e9-b222-213a7b2c3076 a=rtpmap:13 CN/8000
2434    f7be5878-d5b7-11e9-b222-213a7b2c3076 a=fmtp:101 0-16
2435    f7be5878-d5b7-11e9-b222-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2436    f7be5878-d5b7-11e9-b222-213a7b2c3076 a=rtpmap:8 PCMA/8000
2437    f7be5878-d5b7-11e9-b222-213a7b2c3076 a=rtpmap:0 PCMU/8000
2438    f7be5878-d5b7-11e9-b222-213a7b2c3076 m=audio 24582 RTP/AVP 0 8 101 13
2439    f7be5878-d5b7-11e9-b222-213a7b2c3076 t=0 0
2440    f7be5878-d5b7-11e9-b222-213a7b2c3076 c=IN IP4 192.168.1.83
2441    f7be5878-d5b7-11e9-b222-213a7b2c3076 s=FreeSWITCH
2442    f7be5878-d5b7-11e9-b222-213a7b2c3076 o=FreeSWITCH 1568307590 1568307591 IN IP4 192.168.1.83
2443    f7be5878-d5b7-11e9-b222-213a7b2c3076 v=0
2444    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] sofia.c:7301 Remote SDP:
2445    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.390508 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
2446    2019-09-12 16:49:32.370492 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2447    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.370492 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2448    2019-09-12 16:49:32.350498 [DEBUG] sofia.c:2522 Re-attaching to session f7be5878-d5b7-11e9-b222-213a7b2c3076
2449    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2450    2019-09-12 16:49:32.350498 [DEBUG] sofia.c:2413 detaching session f7be5878-d5b7-11e9-b222-213a7b2c3076
2451    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
2452    2019-09-12 16:49:32.350498 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
2453    2019-09-12 16:49:32.350498 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2454    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2455    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 25 Tot 263)
2456    f7be5878-d5b7-11e9-b222-213a7b2c3076 2019-09-12 16:49:32.350498 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7be5878-d5b7-11e9-b222-213a7b2c3076]
2457    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
2458    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
2459    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2460    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 24 Tot 262)
2461    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
2462    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2463    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
2464    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
2465    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 24 Tot 262)
2466    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
2467    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
2468    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
2469    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076
2470    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 a=sendrecv
2471    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 a=ptime:20
2472    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 a=rtpmap:13 CN/8000
2473    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 a=fmtp:101 0-16
2474    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2475    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 a=rtpmap:8 PCMA/8000
2476    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 a=rtpmap:0 PCMU/8000
2477    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 m=audio 24582 RTP/AVP 0 8 101 13
2478    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 t=0 0
2479    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 c=IN IP4 192.168.1.83
2480    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 s=FreeSWITCH
2481    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 o=FreeSWITCH 1568307590 1568307591 IN IP4 192.168.1.83
2482    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 v=0
2483    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 Local SDP:
2484    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
2485    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
2486    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
2487    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 24 Tot 262)
2488    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
2489    f7be2fc4-d5b7-11e9-b21e-213a7b2c3076 2019-09-12 16:49:32.350498 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7be2fc4-d5b7-11e9-b21e-213a7b2c3076]
2490    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
2491    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2492    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
2493    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2494    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
2495    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2496    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
2497    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
2498    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
2499    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
2500    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
2501    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
2502    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
2503    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
2504    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
2505    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
2506    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
2507    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
2508    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
2509    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
2510    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
2511    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
2512    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
2513    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
2514    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
2515    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
2516    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
2517    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
2518    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
2519    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
2520    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
2521    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
2522    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
2523    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
2524    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
2525    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
2526    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 23 Tot 261)
2527    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
2528    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
2529    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2530    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
2531    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
2532    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
2533    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
2534    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
2535    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
2536    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
2537    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
2538    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
2539    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
2540    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
2541    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
2542    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
2543    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
2544    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
2545    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
2546    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
2547    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
2548    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
2549    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
2550    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
2551    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
2552    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
2553    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
2554    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
2555    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
2556    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
2557    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
2558    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
2559    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
2560    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
2561    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
2562    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
2563    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
2564    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
2565    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
2566    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
2567    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2568    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
2569    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
2570    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2571    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
2572    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
2573    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2574    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
2575    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2576    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
2577    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
2578    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
2579    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2580    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
2581    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
2582    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2583    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
2584    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
2585    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2586    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
2587    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
2588    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2589    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
2590    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2591    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
2592    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
2593    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
2594    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
2595    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
2596    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
2597    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
2598    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
2599    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
2600    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
2601    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
2602    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
2603    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
2604    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
2605    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
2606    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
2607    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
2608    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
2609    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
2610    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
2611    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
2612    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
2613    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
2614    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
2615    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.350498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
2616    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
2617    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
2618    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
2619    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
2620    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
2621    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
2622    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
2623    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
2624    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
2625    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 23 Tot 261)
2626    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
2627    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
2628    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
2629    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
2630    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
2631    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 23 Tot 261)
2632    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
2633    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
2634    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
2635    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
2636    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
2637    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
2638    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2639    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2640    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2641    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2642    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2643    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2644    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2645    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2646    f7b6c20c-d5b7-11e9-b200-213a7b2c3076
2647    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 a=ptime:20
2648    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 a=rtpmap:13 CN/8000
2649    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 a=fmtp:101 0-16
2650    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2651    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 a=rtpmap:8 PCMA/8000
2652    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 a=rtpmap:0 PCMU/8000
2653    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 m=audio 31280 RTP/AVP 0 8 101 13
2654    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 t=0 0
2655    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 c=IN IP4 192.168.1.83
2656    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 s=FreeSWITCH
2657    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 o=FreeSWITCH 1568300892 1568300893 IN IP4 192.168.1.83
2658    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 v=0
2659    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] sofia.c:7301 Remote SDP:
2660    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
2661    2019-09-12 16:49:32.330491 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2662    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.330491 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2663    2019-09-12 16:49:32.310486 [DEBUG] sofia.c:2522 Re-attaching to session f7b6c20c-d5b7-11e9-b200-213a7b2c3076
2664    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2665    2019-09-12 16:49:32.310486 [DEBUG] sofia.c:2413 detaching session f7b6c20c-d5b7-11e9-b200-213a7b2c3076
2666    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
2667    2019-09-12 16:49:32.310486 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
2668    2019-09-12 16:49:32.310486 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2669    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2670    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 23 Tot 261)
2671    f7b6c20c-d5b7-11e9-b200-213a7b2c3076 2019-09-12 16:49:32.310486 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7b6c20c-d5b7-11e9-b200-213a7b2c3076]
2672    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
2673    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
2674    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 22 Tot 260)
2675    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
2676    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2677    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
2678    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
2679    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2680    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 22 Tot 260)
2681    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
2682    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
2683    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
2684    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076
2685    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 a=sendrecv
2686    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 a=ptime:20
2687    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 a=rtpmap:13 CN/8000
2688    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 a=fmtp:101 0-16
2689    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2690    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 a=rtpmap:8 PCMA/8000
2691    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 a=rtpmap:0 PCMU/8000
2692    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 m=audio 31280 RTP/AVP 0 8 101 13
2693    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 t=0 0
2694    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 c=IN IP4 192.168.1.83
2695    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 s=FreeSWITCH
2696    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 o=FreeSWITCH 1568300892 1568300893 IN IP4 192.168.1.83
2697    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 v=0
2698    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 Local SDP:
2699    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
2700    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
2701    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
2702    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 22 Tot 260)
2703    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
2704    f7b69aac-d5b7-11e9-b1fc-213a7b2c3076 2019-09-12 16:49:32.310486 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7b69aac-d5b7-11e9-b1fc-213a7b2c3076]
2705    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
2706    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2707    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
2708    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2709    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
2710    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2711    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
2712    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
2713    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
2714    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
2715    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
2716    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
2717    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
2718    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
2719    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
2720    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
2721    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
2722    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
2723    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
2724    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
2725    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
2726    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
2727    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
2728    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
2729    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
2730    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
2731    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
2732    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
2733    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
2734    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
2735    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
2736    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
2737    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
2738    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
2739    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
2740    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
2741    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 21 Tot 259)
2742    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
2743    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
2744    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2745    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
2746    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
2747    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
2748    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
2749    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
2750    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
2751    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
2752    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
2753    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
2754    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
2755    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
2756    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
2757    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
2758    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
2759    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
2760    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
2761    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
2762    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
2763    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
2764    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
2765    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
2766    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
2767    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
2768    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
2769    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
2770    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
2771    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
2772    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
2773    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
2774    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
2775    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
2776    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
2777    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
2778    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
2779    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
2780    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
2781    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
2782    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2783    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
2784    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
2785    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2786    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
2787    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
2788    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2789    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
2790    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2791    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.310486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
2792    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
2793    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
2794    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2795    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
2796    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
2797    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2798    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
2799    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
2800    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2801    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
2802    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
2803    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2804    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
2805    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
2806    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
2807    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
2808    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
2809    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
2810    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
2811    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
2812    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
2813    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
2814    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
2815    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
2816    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
2817    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
2818    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
2819    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
2820    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
2821    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
2822    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
2823    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
2824    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
2825    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
2826    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
2827    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
2828    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
2829    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
2830    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
2831    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
2832    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
2833    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
2834    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
2835    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
2836    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
2837    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
2838    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
2839    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
2840    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 21 Tot 259)
2841    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
2842    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
2843    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
2844    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
2845    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
2846    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 21 Tot 259)
2847    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
2848    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
2849    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
2850    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
2851    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
2852    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
2853    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2854    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2855    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2856    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2857    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2858    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2859    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2860    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2861    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076
2862    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 a=ptime:20
2863    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 a=rtpmap:13 CN/8000
2864    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 a=fmtp:101 0-16
2865    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2866    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 a=rtpmap:8 PCMA/8000
2867    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 a=rtpmap:0 PCMU/8000
2868    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 m=audio 25416 RTP/AVP 0 8 101 13
2869    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 t=0 0
2870    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 c=IN IP4 192.168.1.83
2871    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 s=FreeSWITCH
2872    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 o=FreeSWITCH 1568306756 1568306757 IN IP4 192.168.1.83
2873    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 v=0
2874    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] sofia.c:7301 Remote SDP:
2875    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.290498 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
2876    2019-09-12 16:49:32.270491 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2877    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.270491 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2878    2019-09-12 16:49:32.250496 [DEBUG] sofia.c:2522 Re-attaching to session f7aecdd6-d5b7-11e9-b1de-213a7b2c3076
2879    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2880    2019-09-12 16:49:32.250496 [DEBUG] sofia.c:2413 detaching session f7aecdd6-d5b7-11e9-b1de-213a7b2c3076
2881    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
2882    2019-09-12 16:49:32.250496 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
2883    2019-09-12 16:49:32.250496 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
2884    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
2885    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 21 Tot 259)
2886    f7aecdd6-d5b7-11e9-b1de-213a7b2c3076 2019-09-12 16:49:32.250496 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7aecdd6-d5b7-11e9-b1de-213a7b2c3076]
2887    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
2888    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
2889    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
2890    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 20 Tot 258)
2891    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
2892    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
2893    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
2894    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
2895    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 20 Tot 258)
2896    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
2897    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
2898    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
2899    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076
2900    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 a=sendrecv
2901    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 a=ptime:20
2902    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 a=rtpmap:13 CN/8000
2903    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 a=fmtp:101 0-16
2904    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 a=rtpmap:101 telephone-event/8000
2905    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 a=rtpmap:8 PCMA/8000
2906    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 a=rtpmap:0 PCMU/8000
2907    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 m=audio 25416 RTP/AVP 0 8 101 13
2908    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 t=0 0
2909    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 c=IN IP4 192.168.1.83
2910    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 s=FreeSWITCH
2911    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 o=FreeSWITCH 1568306756 1568306757 IN IP4 192.168.1.83
2912    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 v=0
2913    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 Local SDP:
2914    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
2915    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
2916    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
2917    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 20 Tot 258)
2918    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
2919    f7aea5cc-d5b7-11e9-b1da-213a7b2c3076 2019-09-12 16:49:32.250496 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7aea5cc-d5b7-11e9-b1da-213a7b2c3076]
2920    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
2921    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2922    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
2923    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
2924    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
2925    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2926    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
2927    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
2928    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
2929    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
2930    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
2931    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
2932    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
2933    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
2934    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
2935    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
2936    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
2937    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
2938    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
2939    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
2940    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
2941    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
2942    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
2943    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
2944    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
2945    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
2946    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
2947    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
2948    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
2949    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
2950    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
2951    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
2952    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
2953    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
2954    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
2955    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
2956    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 19 Tot 257)
2957    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
2958    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
2959    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
2960    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
2961    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
2962    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
2963    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
2964    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
2965    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
2966    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
2967    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
2968    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
2969    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
2970    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
2971    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
2972    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
2973    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
2974    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
2975    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
2976    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
2977    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
2978    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
2979    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
2980    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
2981    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
2982    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
2983    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
2984    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
2985    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
2986    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
2987    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
2988    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
2989    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
2990    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
2991    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
2992    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
2993    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
2994    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
2995    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
2996    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
2997    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
2998    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
2999    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3000    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3001    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
3002    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3003    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3004    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
3005    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3006    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
3007    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
3008    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
3009    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3010    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
3011    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
3012    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3013    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
3014    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3015    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3016    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
3017    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3018    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3019    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
3020    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3021    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
3022    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
3023    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
3024    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
3025    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
3026    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
3027    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
3028    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
3029    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
3030    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
3031    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
3032    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
3033    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
3034    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
3035    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
3036    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
3037    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
3038    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
3039    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
3040    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
3041    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
3042    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
3043    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
3044    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
3045    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.250496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
3046    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
3047    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
3048    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
3049    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
3050    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
3051    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
3052    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
3053    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
3054    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
3055    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 19 Tot 257)
3056    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
3057    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
3058    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
3059    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
3060    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
3061    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 19 Tot 257)
3062    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
3063    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
3064    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
3065    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
3066    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
3067    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
3068    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
3069    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3070    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3071    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3072    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3073    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
3074    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3075    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3076    f7a70970-d5b7-11e9-b1bc-213a7b2c3076
3077    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 a=ptime:20
3078    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 a=rtpmap:13 CN/8000
3079    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 a=fmtp:101 0-16
3080    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3081    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 a=rtpmap:8 PCMA/8000
3082    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 a=rtpmap:0 PCMU/8000
3083    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 m=audio 21784 RTP/AVP 0 8 101 13
3084    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 t=0 0
3085    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 c=IN IP4 192.168.1.83
3086    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 s=FreeSWITCH
3087    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 o=FreeSWITCH 1568310388 1568310389 IN IP4 192.168.1.83
3088    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 v=0
3089    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] sofia.c:7301 Remote SDP:
3090    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
3091    2019-09-12 16:49:32.230495 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3092    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.230495 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3093    2019-09-12 16:49:32.210486 [DEBUG] sofia.c:2522 Re-attaching to session f7a70970-d5b7-11e9-b1bc-213a7b2c3076
3094    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3095    2019-09-12 16:49:32.210486 [DEBUG] sofia.c:2413 detaching session f7a70970-d5b7-11e9-b1bc-213a7b2c3076
3096    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
3097    2019-09-12 16:49:32.210486 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
3098    2019-09-12 16:49:32.210486 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3099    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3100    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 19 Tot 257)
3101    f7a70970-d5b7-11e9-b1bc-213a7b2c3076 2019-09-12 16:49:32.210486 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7a70970-d5b7-11e9-b1bc-213a7b2c3076]
3102    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
3103    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
3104    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3105    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 18 Tot 256)
3106    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
3107    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
3108    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
3109    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
3110    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 18 Tot 256)
3111    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
3112    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
3113    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
3114    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076
3115    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 a=sendrecv
3116    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 a=ptime:20
3117    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 a=rtpmap:13 CN/8000
3118    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 a=fmtp:101 0-16
3119    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3120    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 a=rtpmap:8 PCMA/8000
3121    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 a=rtpmap:0 PCMU/8000
3122    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 m=audio 21784 RTP/AVP 0 8 101 13
3123    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 t=0 0
3124    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 c=IN IP4 192.168.1.83
3125    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 s=FreeSWITCH
3126    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 o=FreeSWITCH 1568310388 1568310389 IN IP4 192.168.1.83
3127    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 v=0
3128    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 Local SDP:
3129    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
3130    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
3131    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
3132    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 18 Tot 256)
3133    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
3134    f7a6e422-d5b7-11e9-b1b8-213a7b2c3076 2019-09-12 16:49:32.210486 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7a6e422-d5b7-11e9-b1b8-213a7b2c3076]
3135    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
3136    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3137    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
3138    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3139    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
3140    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
3141    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
3142    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
3143    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
3144    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
3145    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
3146    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
3147    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
3148    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
3149    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
3150    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
3151    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
3152    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
3153    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
3154    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
3155    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
3156    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
3157    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
3158    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
3159    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
3160    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
3161    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
3162    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.210486 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
3163    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
3164    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
3165    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
3166    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
3167    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
3168    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
3169    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
3170    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
3171    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 17 Tot 255)
3172    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
3173    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
3174    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
3175    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
3176    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
3177    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
3178    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
3179    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
3180    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
3181    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
3182    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
3183    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
3184    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
3185    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
3186    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
3187    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
3188    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
3189    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
3190    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
3191    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
3192    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
3193    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
3194    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
3195    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
3196    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
3197    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
3198    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
3199    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
3200    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
3201    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
3202    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
3203    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
3204    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
3205    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
3206    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
3207    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
3208    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
3209    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
3210    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
3211    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
3212    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3213    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
3214    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3215    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3216    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
3217    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3218    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3219    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
3220    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3221    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
3222    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
3223    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
3224    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3225    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
3226    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
3227    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3228    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
3229    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3230    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3231    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
3232    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3233    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3234    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
3235    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3236    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
3237    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
3238    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
3239    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
3240    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
3241    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
3242    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
3243    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
3244    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
3245    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
3246    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
3247    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
3248    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
3249    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
3250    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
3251    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
3252    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
3253    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
3254    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
3255    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
3256    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
3257    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
3258    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
3259    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
3260    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
3261    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
3262    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
3263    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
3264    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
3265    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
3266    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
3267    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
3268    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
3269    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
3270    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 17 Tot 255)
3271    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
3272    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
3273    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
3274    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
3275    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
3276    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 17 Tot 255)
3277    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
3278    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
3279    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
3280    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
3281    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
3282    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
3283    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
3284    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3285    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3286    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3287    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3288    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
3289    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3290    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3291    f79f28f4-d5b7-11e9-b19a-213a7b2c3076
3292    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 a=ptime:20
3293    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 a=rtpmap:13 CN/8000
3294    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 a=fmtp:101 0-16
3295    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3296    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 a=rtpmap:8 PCMA/8000
3297    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 a=rtpmap:0 PCMU/8000
3298    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 m=audio 28504 RTP/AVP 0 8 101 13
3299    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 t=0 0
3300    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 c=IN IP4 192.168.1.83
3301    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 s=FreeSWITCH
3302    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 o=FreeSWITCH 1568303668 1568303669 IN IP4 192.168.1.83
3303    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 v=0
3304    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] sofia.c:7301 Remote SDP:
3305    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.190496 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
3306    2019-09-12 16:49:32.170518 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3307    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.170518 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3308    2019-09-12 16:49:32.150497 [DEBUG] sofia.c:2522 Re-attaching to session f79f28f4-d5b7-11e9-b19a-213a7b2c3076
3309    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3310    2019-09-12 16:49:32.150497 [DEBUG] sofia.c:2413 detaching session f79f28f4-d5b7-11e9-b19a-213a7b2c3076
3311    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
3312    2019-09-12 16:49:32.150497 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
3313    2019-09-12 16:49:32.150497 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3314    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3315    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 17 Tot 255)
3316    f79f28f4-d5b7-11e9-b19a-213a7b2c3076 2019-09-12 16:49:32.150497 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f79f28f4-d5b7-11e9-b19a-213a7b2c3076]
3317    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
3318    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
3319    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3320    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 16 Tot 254)
3321    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
3322    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
3323    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
3324    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
3325    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 16 Tot 254)
3326    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
3327    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
3328    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
3329    f79f0464-d5b7-11e9-b196-213a7b2c3076
3330    f79f0464-d5b7-11e9-b196-213a7b2c3076 a=sendrecv
3331    f79f0464-d5b7-11e9-b196-213a7b2c3076 a=ptime:20
3332    f79f0464-d5b7-11e9-b196-213a7b2c3076 a=rtpmap:13 CN/8000
3333    f79f0464-d5b7-11e9-b196-213a7b2c3076 a=fmtp:101 0-16
3334    f79f0464-d5b7-11e9-b196-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3335    f79f0464-d5b7-11e9-b196-213a7b2c3076 a=rtpmap:8 PCMA/8000
3336    f79f0464-d5b7-11e9-b196-213a7b2c3076 a=rtpmap:0 PCMU/8000
3337    f79f0464-d5b7-11e9-b196-213a7b2c3076 m=audio 28504 RTP/AVP 0 8 101 13
3338    f79f0464-d5b7-11e9-b196-213a7b2c3076 t=0 0
3339    f79f0464-d5b7-11e9-b196-213a7b2c3076 c=IN IP4 192.168.1.83
3340    f79f0464-d5b7-11e9-b196-213a7b2c3076 s=FreeSWITCH
3341    f79f0464-d5b7-11e9-b196-213a7b2c3076 o=FreeSWITCH 1568303668 1568303669 IN IP4 192.168.1.83
3342    f79f0464-d5b7-11e9-b196-213a7b2c3076 v=0
3343    f79f0464-d5b7-11e9-b196-213a7b2c3076 Local SDP:
3344    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
3345    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
3346    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
3347    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 16 Tot 254)
3348    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
3349    f79f0464-d5b7-11e9-b196-213a7b2c3076 2019-09-12 16:49:32.150497 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f79f0464-d5b7-11e9-b196-213a7b2c3076]
3350    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
3351    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3352    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
3353    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3354    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
3355    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
3356    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
3357    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
3358    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
3359    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
3360    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
3361    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
3362    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
3363    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
3364    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
3365    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
3366    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
3367    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
3368    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
3369    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
3370    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
3371    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
3372    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
3373    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
3374    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
3375    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
3376    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
3377    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
3378    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
3379    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
3380    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
3381    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
3382    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
3383    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
3384    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
3385    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
3386    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 15 Tot 253)
3387    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
3388    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
3389    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
3390    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
3391    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
3392    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
3393    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
3394    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
3395    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
3396    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
3397    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
3398    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
3399    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
3400    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
3401    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
3402    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
3403    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
3404    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
3405    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
3406    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
3407    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
3408    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
3409    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
3410    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
3411    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
3412    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
3413    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
3414    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
3415    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
3416    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
3417    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
3418    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
3419    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
3420    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
3421    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
3422    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
3423    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
3424    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
3425    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
3426    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
3427    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3428    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
3429    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3430    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3431    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
3432    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3433    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3434    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
3435    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3436    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
3437    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
3438    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
3439    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3440    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
3441    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
3442    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3443    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
3444    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3445    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3446    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
3447    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3448    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3449    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
3450    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3451    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
3452    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
3453    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
3454    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
3455    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
3456    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
3457    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
3458    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
3459    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
3460    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
3461    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
3462    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
3463    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
3464    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
3465    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
3466    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
3467    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
3468    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
3469    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
3470    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
3471    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
3472    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
3473    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
3474    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
3475    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.150497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
3476    f7974cb0-d5b7-11e9-b178-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
3477    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
3478    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
3479    f7974cb0-d5b7-11e9-b178-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
3480    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
3481    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
3482    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
3483    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
3484    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
3485    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 15 Tot 253)
3486    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
3487    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
3488    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
3489    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
3490    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
3491    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 15 Tot 253)
3492    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
3493    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
3494    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
3495    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
3496    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
3497    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
3498    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
3499    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3500    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3501    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3502    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3503    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
3504    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3505    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3506    f7974cb0-d5b7-11e9-b178-213a7b2c3076
3507    f7974cb0-d5b7-11e9-b178-213a7b2c3076 a=ptime:20
3508    f7974cb0-d5b7-11e9-b178-213a7b2c3076 a=rtpmap:13 CN/8000
3509    f7974cb0-d5b7-11e9-b178-213a7b2c3076 a=fmtp:101 0-16
3510    f7974cb0-d5b7-11e9-b178-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3511    f7974cb0-d5b7-11e9-b178-213a7b2c3076 a=rtpmap:8 PCMA/8000
3512    f7974cb0-d5b7-11e9-b178-213a7b2c3076 a=rtpmap:0 PCMU/8000
3513    f7974cb0-d5b7-11e9-b178-213a7b2c3076 m=audio 22250 RTP/AVP 0 8 101 13
3514    f7974cb0-d5b7-11e9-b178-213a7b2c3076 t=0 0
3515    f7974cb0-d5b7-11e9-b178-213a7b2c3076 c=IN IP4 192.168.1.83
3516    f7974cb0-d5b7-11e9-b178-213a7b2c3076 s=FreeSWITCH
3517    f7974cb0-d5b7-11e9-b178-213a7b2c3076 o=FreeSWITCH 1568309922 1568309923 IN IP4 192.168.1.83
3518    f7974cb0-d5b7-11e9-b178-213a7b2c3076 v=0
3519    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] sofia.c:7301 Remote SDP:
3520    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
3521    2019-09-12 16:49:32.130506 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3522    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.130506 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3523    2019-09-12 16:49:32.110487 [DEBUG] sofia.c:2522 Re-attaching to session f7974cb0-d5b7-11e9-b178-213a7b2c3076
3524    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3525    2019-09-12 16:49:32.110487 [DEBUG] sofia.c:2413 detaching session f7974cb0-d5b7-11e9-b178-213a7b2c3076
3526    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
3527    2019-09-12 16:49:32.110487 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
3528    2019-09-12 16:49:32.110487 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3529    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3530    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 15 Tot 253)
3531    f7974cb0-d5b7-11e9-b178-213a7b2c3076 2019-09-12 16:49:32.110487 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7974cb0-d5b7-11e9-b178-213a7b2c3076]
3532    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
3533    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
3534    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3535    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 14 Tot 252)
3536    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
3537    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
3538    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
3539    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
3540    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 14 Tot 252)
3541    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
3542    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
3543    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
3544    f7972672-d5b7-11e9-b174-213a7b2c3076
3545    f7972672-d5b7-11e9-b174-213a7b2c3076 a=sendrecv
3546    f7972672-d5b7-11e9-b174-213a7b2c3076 a=ptime:20
3547    f7972672-d5b7-11e9-b174-213a7b2c3076 a=rtpmap:13 CN/8000
3548    f7972672-d5b7-11e9-b174-213a7b2c3076 a=fmtp:101 0-16
3549    f7972672-d5b7-11e9-b174-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3550    f7972672-d5b7-11e9-b174-213a7b2c3076 a=rtpmap:8 PCMA/8000
3551    f7972672-d5b7-11e9-b174-213a7b2c3076 a=rtpmap:0 PCMU/8000
3552    f7972672-d5b7-11e9-b174-213a7b2c3076 m=audio 22250 RTP/AVP 0 8 101 13
3553    f7972672-d5b7-11e9-b174-213a7b2c3076 t=0 0
3554    f7972672-d5b7-11e9-b174-213a7b2c3076 c=IN IP4 192.168.1.83
3555    f7972672-d5b7-11e9-b174-213a7b2c3076 s=FreeSWITCH
3556    f7972672-d5b7-11e9-b174-213a7b2c3076 o=FreeSWITCH 1568309922 1568309923 IN IP4 192.168.1.83
3557    f7972672-d5b7-11e9-b174-213a7b2c3076 v=0
3558    f7972672-d5b7-11e9-b174-213a7b2c3076 Local SDP:
3559    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
3560    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
3561    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
3562    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 14 Tot 252)
3563    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
3564    f7972672-d5b7-11e9-b174-213a7b2c3076 2019-09-12 16:49:32.110487 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7972672-d5b7-11e9-b174-213a7b2c3076]
3565    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
3566    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3567    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
3568    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3569    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
3570    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
3571    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
3572    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
3573    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
3574    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
3575    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.110487 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
3576    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
3577    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
3578    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
3579    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
3580    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
3581    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
3582    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
3583    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
3584    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
3585    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
3586    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
3587    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
3588    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
3589    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
3590    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
3591    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
3592    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
3593    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
3594    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
3595    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
3596    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
3597    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
3598    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
3599    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
3600    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
3601    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 13 Tot 251)
3602    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
3603    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
3604    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
3605    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
3606    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
3607    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
3608    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
3609    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
3610    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
3611    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
3612    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
3613    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
3614    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
3615    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
3616    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
3617    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
3618    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
3619    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
3620    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
3621    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
3622    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
3623    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
3624    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
3625    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
3626    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
3627    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
3628    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
3629    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
3630    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
3631    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
3632    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
3633    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
3634    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
3635    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
3636    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
3637    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
3638    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
3639    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
3640    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
3641    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
3642    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3643    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
3644    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3645    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3646    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
3647    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3648    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3649    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
3650    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3651    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
3652    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
3653    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
3654    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3655    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
3656    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
3657    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3658    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
3659    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3660    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3661    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
3662    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3663    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3664    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
3665    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3666    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
3667    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
3668    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
3669    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
3670    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
3671    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
3672    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
3673    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
3674    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
3675    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
3676    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
3677    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
3678    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
3679    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
3680    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
3681    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
3682    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
3683    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
3684    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
3685    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
3686    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
3687    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
3688    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
3689    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
3690    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
3691    f78fef24-d5b7-11e9-b156-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
3692    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
3693    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
3694    f78fef24-d5b7-11e9-b156-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
3695    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
3696    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
3697    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
3698    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
3699    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
3700    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 13 Tot 251)
3701    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
3702    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
3703    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
3704    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
3705    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
3706    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 13 Tot 251)
3707    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
3708    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
3709    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
3710    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
3711    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
3712    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
3713    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
3714    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3715    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3716    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3717    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3718    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
3719    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3720    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3721    f78fef24-d5b7-11e9-b156-213a7b2c3076
3722    f78fef24-d5b7-11e9-b156-213a7b2c3076 a=ptime:20
3723    f78fef24-d5b7-11e9-b156-213a7b2c3076 a=rtpmap:13 CN/8000
3724    f78fef24-d5b7-11e9-b156-213a7b2c3076 a=fmtp:101 0-16
3725    f78fef24-d5b7-11e9-b156-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3726    f78fef24-d5b7-11e9-b156-213a7b2c3076 a=rtpmap:8 PCMA/8000
3727    f78fef24-d5b7-11e9-b156-213a7b2c3076 a=rtpmap:0 PCMU/8000
3728    f78fef24-d5b7-11e9-b156-213a7b2c3076 m=audio 25434 RTP/AVP 0 8 101 13
3729    f78fef24-d5b7-11e9-b156-213a7b2c3076 t=0 0
3730    f78fef24-d5b7-11e9-b156-213a7b2c3076 c=IN IP4 192.168.1.83
3731    f78fef24-d5b7-11e9-b156-213a7b2c3076 s=FreeSWITCH
3732    f78fef24-d5b7-11e9-b156-213a7b2c3076 o=FreeSWITCH 1568306738 1568306739 IN IP4 192.168.1.83
3733    f78fef24-d5b7-11e9-b156-213a7b2c3076 v=0
3734    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] sofia.c:7301 Remote SDP:
3735    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.090493 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
3736    2019-09-12 16:49:32.070491 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3737    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.070491 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3738    2019-09-12 16:49:32.050495 [DEBUG] sofia.c:2522 Re-attaching to session f78fef24-d5b7-11e9-b156-213a7b2c3076
3739    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3740    2019-09-12 16:49:32.050495 [DEBUG] sofia.c:2413 detaching session f78fef24-d5b7-11e9-b156-213a7b2c3076
3741    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
3742    2019-09-12 16:49:32.050495 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
3743    2019-09-12 16:49:32.050495 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3744    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3745    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 13 Tot 251)
3746    f78fef24-d5b7-11e9-b156-213a7b2c3076 2019-09-12 16:49:32.050495 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f78fef24-d5b7-11e9-b156-213a7b2c3076]
3747    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
3748    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
3749    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3750    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 12 Tot 250)
3751    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
3752    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
3753    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
3754    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
3755    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 12 Tot 250)
3756    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
3757    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
3758    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
3759    f78fce40-d5b7-11e9-b152-213a7b2c3076
3760    f78fce40-d5b7-11e9-b152-213a7b2c3076 a=sendrecv
3761    f78fce40-d5b7-11e9-b152-213a7b2c3076 a=ptime:20
3762    f78fce40-d5b7-11e9-b152-213a7b2c3076 a=rtpmap:13 CN/8000
3763    f78fce40-d5b7-11e9-b152-213a7b2c3076 a=fmtp:101 0-16
3764    f78fce40-d5b7-11e9-b152-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3765    f78fce40-d5b7-11e9-b152-213a7b2c3076 a=rtpmap:8 PCMA/8000
3766    f78fce40-d5b7-11e9-b152-213a7b2c3076 a=rtpmap:0 PCMU/8000
3767    f78fce40-d5b7-11e9-b152-213a7b2c3076 m=audio 25434 RTP/AVP 0 8 101 13
3768    f78fce40-d5b7-11e9-b152-213a7b2c3076 t=0 0
3769    f78fce40-d5b7-11e9-b152-213a7b2c3076 c=IN IP4 192.168.1.83
3770    f78fce40-d5b7-11e9-b152-213a7b2c3076 s=FreeSWITCH
3771    f78fce40-d5b7-11e9-b152-213a7b2c3076 o=FreeSWITCH 1568306738 1568306739 IN IP4 192.168.1.83
3772    f78fce40-d5b7-11e9-b152-213a7b2c3076 v=0
3773    f78fce40-d5b7-11e9-b152-213a7b2c3076 Local SDP:
3774    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
3775    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
3776    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
3777    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 12 Tot 250)
3778    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
3779    f78fce40-d5b7-11e9-b152-213a7b2c3076 2019-09-12 16:49:32.050495 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f78fce40-d5b7-11e9-b152-213a7b2c3076]
3780    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
3781    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3782    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
3783    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3784    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
3785    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
3786    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
3787    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
3788    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
3789    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
3790    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
3791    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
3792    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
3793    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
3794    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
3795    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
3796    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
3797    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
3798    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
3799    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
3800    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
3801    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
3802    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
3803    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
3804    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
3805    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
3806    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
3807    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
3808    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
3809    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
3810    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
3811    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
3812    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
3813    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
3814    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
3815    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
3816    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 11 Tot 249)
3817    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
3818    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
3819    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
3820    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
3821    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
3822    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
3823    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
3824    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
3825    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
3826    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
3827    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
3828    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
3829    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
3830    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
3831    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
3832    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
3833    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
3834    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
3835    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
3836    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
3837    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
3838    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
3839    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
3840    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
3841    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
3842    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
3843    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
3844    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
3845    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
3846    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
3847    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
3848    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
3849    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
3850    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
3851    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
3852    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
3853    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
3854    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
3855    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
3856    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
3857    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3858    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
3859    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3860    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3861    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
3862    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3863    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3864    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
3865    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3866    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
3867    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
3868    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
3869    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
3870    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
3871    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
3872    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3873    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
3874    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
3875    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3876    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
3877    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
3878    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3879    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
3880    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
3881    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
3882    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
3883    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
3884    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
3885    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
3886    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
3887    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
3888    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
3889    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
3890    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
3891    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
3892    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
3893    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
3894    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
3895    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
3896    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
3897    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
3898    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
3899    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
3900    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
3901    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
3902    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
3903    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
3904    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
3905    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.050495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
3906    f7889e7c-d5b7-11e9-b134-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
3907    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
3908    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
3909    f7889e7c-d5b7-11e9-b134-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
3910    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
3911    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
3912    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
3913    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
3914    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
3915    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 11 Tot 249)
3916    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
3917    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
3918    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
3919    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
3920    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
3921    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 11 Tot 249)
3922    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
3923    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
3924    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
3925    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
3926    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
3927    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
3928    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
3929    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3930    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3931    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3932    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
3933    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
3934    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
3935    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
3936    f7889e7c-d5b7-11e9-b134-213a7b2c3076
3937    f7889e7c-d5b7-11e9-b134-213a7b2c3076 a=ptime:20
3938    f7889e7c-d5b7-11e9-b134-213a7b2c3076 a=rtpmap:13 CN/8000
3939    f7889e7c-d5b7-11e9-b134-213a7b2c3076 a=fmtp:101 0-16
3940    f7889e7c-d5b7-11e9-b134-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3941    f7889e7c-d5b7-11e9-b134-213a7b2c3076 a=rtpmap:8 PCMA/8000
3942    f7889e7c-d5b7-11e9-b134-213a7b2c3076 a=rtpmap:0 PCMU/8000
3943    f7889e7c-d5b7-11e9-b134-213a7b2c3076 m=audio 30870 RTP/AVP 0 8 101 13
3944    f7889e7c-d5b7-11e9-b134-213a7b2c3076 t=0 0
3945    f7889e7c-d5b7-11e9-b134-213a7b2c3076 c=IN IP4 192.168.1.83
3946    f7889e7c-d5b7-11e9-b134-213a7b2c3076 s=FreeSWITCH
3947    f7889e7c-d5b7-11e9-b134-213a7b2c3076 o=FreeSWITCH 1568301302 1568301303 IN IP4 192.168.1.83
3948    f7889e7c-d5b7-11e9-b134-213a7b2c3076 v=0
3949    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] sofia.c:7301 Remote SDP:
3950    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
3951    2019-09-12 16:49:32.030500 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3952    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.030500 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3953    2019-09-12 16:49:32.010484 [DEBUG] sofia.c:2522 Re-attaching to session f7889e7c-d5b7-11e9-b134-213a7b2c3076
3954    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3955    2019-09-12 16:49:32.010484 [DEBUG] sofia.c:2413 detaching session f7889e7c-d5b7-11e9-b134-213a7b2c3076
3956    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
3957    2019-09-12 16:49:32.010484 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
3958    2019-09-12 16:49:32.010484 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
3959    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
3960    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 11 Tot 249)
3961    f7889e7c-d5b7-11e9-b134-213a7b2c3076 2019-09-12 16:49:32.010484 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7889e7c-d5b7-11e9-b134-213a7b2c3076]
3962    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
3963    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
3964    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
3965    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 10 Tot 248)
3966    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
3967    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
3968    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
3969    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
3970    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 10 Tot 248)
3971    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
3972    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
3973    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
3974    f7887f46-d5b7-11e9-b130-213a7b2c3076
3975    f7887f46-d5b7-11e9-b130-213a7b2c3076 a=sendrecv
3976    f7887f46-d5b7-11e9-b130-213a7b2c3076 a=ptime:20
3977    f7887f46-d5b7-11e9-b130-213a7b2c3076 a=rtpmap:13 CN/8000
3978    f7887f46-d5b7-11e9-b130-213a7b2c3076 a=fmtp:101 0-16
3979    f7887f46-d5b7-11e9-b130-213a7b2c3076 a=rtpmap:101 telephone-event/8000
3980    f7887f46-d5b7-11e9-b130-213a7b2c3076 a=rtpmap:8 PCMA/8000
3981    f7887f46-d5b7-11e9-b130-213a7b2c3076 a=rtpmap:0 PCMU/8000
3982    f7887f46-d5b7-11e9-b130-213a7b2c3076 m=audio 30870 RTP/AVP 0 8 101 13
3983    f7887f46-d5b7-11e9-b130-213a7b2c3076 t=0 0
3984    f7887f46-d5b7-11e9-b130-213a7b2c3076 c=IN IP4 192.168.1.83
3985    f7887f46-d5b7-11e9-b130-213a7b2c3076 s=FreeSWITCH
3986    f7887f46-d5b7-11e9-b130-213a7b2c3076 o=FreeSWITCH 1568301302 1568301303 IN IP4 192.168.1.83
3987    f7887f46-d5b7-11e9-b130-213a7b2c3076 v=0
3988    f7887f46-d5b7-11e9-b130-213a7b2c3076 Local SDP:
3989    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
3990    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
3991    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
3992    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 10 Tot 248)
3993    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
3994    f7887f46-d5b7-11e9-b130-213a7b2c3076 2019-09-12 16:49:32.010484 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7887f46-d5b7-11e9-b130-213a7b2c3076]
3995    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
3996    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3997    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
3998    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
3999    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
4000    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4001    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
4002    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
4003    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
4004    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
4005    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
4006    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
4007    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
4008    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
4009    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
4010    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
4011    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
4012    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
4013    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
4014    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
4015    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
4016    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
4017    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
4018    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
4019    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
4020    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
4021    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
4022    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:32 -0700]
4023    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:32 -0700)
4024    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
4025    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
4026    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
4027    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
4028    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
4029    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
4030    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
4031    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 9 Tot 247)
4032    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
4033    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
4034    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4035    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
4036    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
4037    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
4038    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
4039    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
4040    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
4041    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
4042    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
4043    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
4044    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
4045    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
4046    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
4047    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
4048    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
4049    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
4050    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
4051    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
4052    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
4053    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
4054    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
4055    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
4056    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
4057    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
4058    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
4059    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
4060    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
4061    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
4062    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
4063    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
4064    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
4065    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
4066    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
4067    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
4068    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
4069    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
4070    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
4071    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4072    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4073    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
4074    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4075    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4076    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
4077    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4078    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4079    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
4080    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4081    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:32.010484 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
4082    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
4083    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
4084    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4085    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
4086    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4087    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4088    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
4089    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4090    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4091    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
4092    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4093    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4094    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
4095    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4096    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
4097    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
4098    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
4099    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
4100    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
4101    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
4102    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
4103    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
4104    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
4105    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
4106    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
4107    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
4108    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
4109    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
4110    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
4111    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
4112    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
4113    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
4114    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
4115    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
4116    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
4117    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
4118    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
4119    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
4120    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
4121    f7818902-d5b7-11e9-b112-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
4122    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
4123    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
4124    f7818902-d5b7-11e9-b112-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
4125    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
4126    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
4127    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
4128    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
4129    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
4130    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 9 Tot 247)
4131    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
4132    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
4133    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
4134    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
4135    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
4136    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 9 Tot 247)
4137    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
4138    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
4139    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
4140    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
4141    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
4142    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
4143    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
4144    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
4145    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
4146    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
4147    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
4148    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
4149    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
4150    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
4151    f7818902-d5b7-11e9-b112-213a7b2c3076
4152    f7818902-d5b7-11e9-b112-213a7b2c3076 a=ptime:20
4153    f7818902-d5b7-11e9-b112-213a7b2c3076 a=rtpmap:13 CN/8000
4154    f7818902-d5b7-11e9-b112-213a7b2c3076 a=fmtp:101 0-16
4155    f7818902-d5b7-11e9-b112-213a7b2c3076 a=rtpmap:101 telephone-event/8000
4156    f7818902-d5b7-11e9-b112-213a7b2c3076 a=rtpmap:8 PCMA/8000
4157    f7818902-d5b7-11e9-b112-213a7b2c3076 a=rtpmap:0 PCMU/8000
4158    f7818902-d5b7-11e9-b112-213a7b2c3076 m=audio 17828 RTP/AVP 0 8 101 13
4159    f7818902-d5b7-11e9-b112-213a7b2c3076 t=0 0
4160    f7818902-d5b7-11e9-b112-213a7b2c3076 c=IN IP4 192.168.1.83
4161    f7818902-d5b7-11e9-b112-213a7b2c3076 s=FreeSWITCH
4162    f7818902-d5b7-11e9-b112-213a7b2c3076 o=FreeSWITCH 1568314343 1568314344 IN IP4 192.168.1.83
4163    f7818902-d5b7-11e9-b112-213a7b2c3076 v=0
4164    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] sofia.c:7301 Remote SDP:
4165    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
4166    2019-09-12 16:49:31.990500 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
4167    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.990500 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
4168    2019-09-12 16:49:31.970487 [DEBUG] sofia.c:2522 Re-attaching to session f7818902-d5b7-11e9-b112-213a7b2c3076
4169    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.970487 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
4170    2019-09-12 16:49:31.970487 [DEBUG] sofia.c:2413 detaching session f7818902-d5b7-11e9-b112-213a7b2c3076
4171    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.970487 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
4172    2019-09-12 16:49:31.970487 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
4173    2019-09-12 16:49:31.970487 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
4174    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.970487 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
4175    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 9 Tot 247)
4176    f7818902-d5b7-11e9-b112-213a7b2c3076 2019-09-12 16:49:31.950495 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f7818902-d5b7-11e9-b112-213a7b2c3076]
4177    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
4178    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
4179    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
4180    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 8 Tot 246)
4181    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
4182    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
4183    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
4184    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
4185    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 8 Tot 246)
4186    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
4187    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
4188    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
4189    f7816a26-d5b7-11e9-b10e-213a7b2c3076
4190    f7816a26-d5b7-11e9-b10e-213a7b2c3076 a=sendrecv
4191    f7816a26-d5b7-11e9-b10e-213a7b2c3076 a=ptime:20
4192    f7816a26-d5b7-11e9-b10e-213a7b2c3076 a=rtpmap:13 CN/8000
4193    f7816a26-d5b7-11e9-b10e-213a7b2c3076 a=fmtp:101 0-16
4194    f7816a26-d5b7-11e9-b10e-213a7b2c3076 a=rtpmap:101 telephone-event/8000
4195    f7816a26-d5b7-11e9-b10e-213a7b2c3076 a=rtpmap:8 PCMA/8000
4196    f7816a26-d5b7-11e9-b10e-213a7b2c3076 a=rtpmap:0 PCMU/8000
4197    f7816a26-d5b7-11e9-b10e-213a7b2c3076 m=audio 17828 RTP/AVP 0 8 101 13
4198    f7816a26-d5b7-11e9-b10e-213a7b2c3076 t=0 0
4199    f7816a26-d5b7-11e9-b10e-213a7b2c3076 c=IN IP4 192.168.1.83
4200    f7816a26-d5b7-11e9-b10e-213a7b2c3076 s=FreeSWITCH
4201    f7816a26-d5b7-11e9-b10e-213a7b2c3076 o=FreeSWITCH 1568314343 1568314344 IN IP4 192.168.1.83
4202    f7816a26-d5b7-11e9-b10e-213a7b2c3076 v=0
4203    f7816a26-d5b7-11e9-b10e-213a7b2c3076 Local SDP:
4204    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
4205    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
4206    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
4207    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 8 Tot 246)
4208    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
4209    f7816a26-d5b7-11e9-b10e-213a7b2c3076 2019-09-12 16:49:31.950495 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7816a26-d5b7-11e9-b10e-213a7b2c3076]
4210    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
4211    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
4212    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
4213    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
4214    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
4215    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4216    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
4217    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
4218    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
4219    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
4220    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
4221    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
4222    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
4223    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
4224    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
4225    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
4226    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
4227    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
4228    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
4229    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
4230    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
4231    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
4232    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
4233    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
4234    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
4235    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
4236    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
4237    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:31 -0700]
4238    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:31 -0700)
4239    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
4240    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
4241    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
4242    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
4243    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
4244    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
4245    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
4246    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 7 Tot 245)
4247    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
4248    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
4249    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4250    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
4251    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
4252    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
4253    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
4254    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
4255    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
4256    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
4257    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
4258    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
4259    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
4260    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
4261    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
4262    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
4263    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
4264    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
4265    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
4266    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
4267    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
4268    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
4269    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
4270    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
4271    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
4272    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
4273    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
4274    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
4275    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
4276    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
4277    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
4278    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
4279    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
4280    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
4281    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
4282    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
4283    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
4284    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
4285    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
4286    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4287    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4288    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
4289    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4290    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4291    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
4292    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4293    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4294    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
4295    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4296    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
4297    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
4298    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
4299    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4300    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
4301    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4302    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4303    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
4304    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4305    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4306    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
4307    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4308    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4309    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
4310    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4311    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
4312    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
4313    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
4314    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
4315    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
4316    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
4317    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
4318    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
4319    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
4320    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
4321    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
4322    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
4323    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
4324    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
4325    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
4326    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
4327    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
4328    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
4329    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
4330    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
4331    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
4332    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
4333    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
4334    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
4335    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
4336    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
4337    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
4338    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
4339    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
4340    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
4341    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
4342    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
4343    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
4344    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
4345    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 7 Tot 245)
4346    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
4347    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
4348    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
4349    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
4350    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
4351    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 7 Tot 245)
4352    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
4353    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
4354    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
4355    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
4356    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
4357    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
4358    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
4359    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
4360    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
4361    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
4362    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
4363    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
4364    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
4365    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
4366    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076
4367    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 a=ptime:20
4368    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 a=rtpmap:13 CN/8000
4369    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 a=fmtp:101 0-16
4370    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 a=rtpmap:101 telephone-event/8000
4371    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 a=rtpmap:8 PCMA/8000
4372    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 a=rtpmap:0 PCMU/8000
4373    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 m=audio 24900 RTP/AVP 0 8 101 13
4374    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 t=0 0
4375    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 c=IN IP4 192.168.1.83
4376    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 s=FreeSWITCH
4377    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 o=FreeSWITCH 1568307271 1568307272 IN IP4 192.168.1.83
4378    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 v=0
4379    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] sofia.c:7301 Remote SDP:
4380    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.950495 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
4381    2019-09-12 16:49:31.930491 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
4382    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.930491 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
4383    2019-09-12 16:49:31.910497 [DEBUG] sofia.c:2522 Re-attaching to session f77a75f4-d5b7-11e9-b0f0-213a7b2c3076
4384    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
4385    2019-09-12 16:49:31.910497 [DEBUG] sofia.c:2413 detaching session f77a75f4-d5b7-11e9-b0f0-213a7b2c3076
4386    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
4387    2019-09-12 16:49:31.910497 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
4388    2019-09-12 16:49:31.910497 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
4389    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
4390    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 7 Tot 245)
4391    f77a75f4-d5b7-11e9-b0f0-213a7b2c3076 2019-09-12 16:49:31.910497 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f77a75f4-d5b7-11e9-b0f0-213a7b2c3076]
4392    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
4393    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
4394    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
4395    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 6 Tot 244)
4396    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
4397    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
4398    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
4399    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
4400    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 6 Tot 244)
4401    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
4402    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
4403    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
4404    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076
4405    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 a=sendrecv
4406    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 a=ptime:20
4407    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 a=rtpmap:13 CN/8000
4408    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 a=fmtp:101 0-16
4409    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 a=rtpmap:101 telephone-event/8000
4410    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 a=rtpmap:8 PCMA/8000
4411    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 a=rtpmap:0 PCMU/8000
4412    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 m=audio 24900 RTP/AVP 0 8 101 13
4413    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 t=0 0
4414    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 c=IN IP4 192.168.1.83
4415    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 s=FreeSWITCH
4416    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 o=FreeSWITCH 1568307271 1568307272 IN IP4 192.168.1.83
4417    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 v=0
4418    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 Local SDP:
4419    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
4420    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
4421    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
4422    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 6 Tot 244)
4423    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
4424    f77a4de0-d5b7-11e9-b0ec-213a7b2c3076 2019-09-12 16:49:31.910497 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f77a4de0-d5b7-11e9-b0ec-213a7b2c3076]
4425    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
4426    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
4427    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
4428    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
4429    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
4430    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4431    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
4432    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
4433    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
4434    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
4435    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
4436    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
4437    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
4438    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
4439    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
4440    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
4441    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
4442    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
4443    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
4444    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
4445    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
4446    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
4447    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
4448    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
4449    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
4450    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
4451    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
4452    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:31 -0700]
4453    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:31 -0700)
4454    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
4455    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
4456    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
4457    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
4458    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
4459    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
4460    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
4461    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 5 Tot 243)
4462    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
4463    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
4464    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4465    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
4466    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
4467    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
4468    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
4469    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
4470    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
4471    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
4472    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
4473    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
4474    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
4475    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
4476    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
4477    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
4478    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
4479    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
4480    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
4481    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
4482    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
4483    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
4484    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
4485    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
4486    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
4487    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
4488    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
4489    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
4490    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
4491    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
4492    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
4493    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
4494    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
4495    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
4496    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
4497    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
4498    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
4499    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
4500    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
4501    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4502    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4503    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
4504    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4505    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4506    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
4507    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4508    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4509    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
4510    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4511    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
4512    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
4513    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
4514    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4515    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
4516    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4517    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4518    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
4519    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4520    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4521    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
4522    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4523    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4524    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
4525    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4526    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
4527    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
4528    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
4529    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
4530    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
4531    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
4532    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
4533    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
4534    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
4535    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
4536    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
4537    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
4538    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
4539    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
4540    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
4541    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
4542    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
4543    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
4544    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
4545    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
4546    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
4547    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
4548    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
4549    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
4550    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.910497 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
4551    f772856a-d5b7-11e9-b0ce-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
4552    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
4553    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
4554    f772856a-d5b7-11e9-b0ce-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
4555    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
4556    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
4557    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
4558    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
4559    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
4560    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 5 Tot 243)
4561    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
4562    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
4563    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
4564    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
4565    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
4566    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 5 Tot 243)
4567    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
4568    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
4569    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
4570    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
4571    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
4572    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
4573    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
4574    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
4575    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
4576    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
4577    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
4578    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
4579    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
4580    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
4581    f772856a-d5b7-11e9-b0ce-213a7b2c3076
4582    f772856a-d5b7-11e9-b0ce-213a7b2c3076 a=ptime:20
4583    f772856a-d5b7-11e9-b0ce-213a7b2c3076 a=rtpmap:13 CN/8000
4584    f772856a-d5b7-11e9-b0ce-213a7b2c3076 a=fmtp:101 0-16
4585    f772856a-d5b7-11e9-b0ce-213a7b2c3076 a=rtpmap:101 telephone-event/8000
4586    f772856a-d5b7-11e9-b0ce-213a7b2c3076 a=rtpmap:8 PCMA/8000
4587    f772856a-d5b7-11e9-b0ce-213a7b2c3076 a=rtpmap:0 PCMU/8000
4588    f772856a-d5b7-11e9-b0ce-213a7b2c3076 m=audio 16408 RTP/AVP 0 8 101 13
4589    f772856a-d5b7-11e9-b0ce-213a7b2c3076 t=0 0
4590    f772856a-d5b7-11e9-b0ce-213a7b2c3076 c=IN IP4 192.168.1.83
4591    f772856a-d5b7-11e9-b0ce-213a7b2c3076 s=FreeSWITCH
4592    f772856a-d5b7-11e9-b0ce-213a7b2c3076 o=FreeSWITCH 1568315763 1568315764 IN IP4 192.168.1.83
4593    f772856a-d5b7-11e9-b0ce-213a7b2c3076 v=0
4594    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] sofia.c:7301 Remote SDP:
4595    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
4596    2019-09-12 16:49:31.890509 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
4597    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.890509 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
4598    2019-09-12 16:49:31.870489 [DEBUG] sofia.c:2522 Re-attaching to session f772856a-d5b7-11e9-b0ce-213a7b2c3076
4599    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
4600    2019-09-12 16:49:31.870489 [DEBUG] sofia.c:2413 detaching session f772856a-d5b7-11e9-b0ce-213a7b2c3076
4601    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
4602    2019-09-12 16:49:31.870489 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
4603    2019-09-12 16:49:31.870489 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
4604    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
4605    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 5 Tot 243)
4606    f772856a-d5b7-11e9-b0ce-213a7b2c3076 2019-09-12 16:49:31.870489 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f772856a-d5b7-11e9-b0ce-213a7b2c3076]
4607    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
4608    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
4609    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
4610    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 4 Tot 242)
4611    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
4612    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
4613    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
4614    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
4615    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 4 Tot 242)
4616    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
4617    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
4618    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
4619    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076
4620    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 a=sendrecv
4621    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 a=ptime:20
4622    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 a=rtpmap:13 CN/8000
4623    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 a=fmtp:101 0-16
4624    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 a=rtpmap:101 telephone-event/8000
4625    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 a=rtpmap:8 PCMA/8000
4626    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 a=rtpmap:0 PCMU/8000
4627    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 m=audio 16408 RTP/AVP 0 8 101 13
4628    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 t=0 0
4629    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 c=IN IP4 192.168.1.83
4630    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 s=FreeSWITCH
4631    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 o=FreeSWITCH 1568315763 1568315764 IN IP4 192.168.1.83
4632    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 v=0
4633    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 Local SDP:
4634    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
4635    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
4636    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
4637    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 4 Tot 242)
4638    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
4639    f7725cb6-d5b7-11e9-b0ca-213a7b2c3076 2019-09-12 16:49:31.870489 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f7725cb6-d5b7-11e9-b0ca-213a7b2c3076]
4640    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
4641    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
4642    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
4643    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [call_direction]=[outbound] to event
4644    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.870489 [DEBUG] switch_channel.c:1250 sofia/internal/600@192.168.1.83:5060 EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
4645    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4646    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [continue_on_fail]=[true]
4647    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(continue_on_fail=true)
4648    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [callee_id_number]=[6046812011]
4649    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(callee_id_number=6046812011)
4650    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [ignore_display_updates]=[true]
4651    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(ignore_display_updates=true)
4652    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [inherit_codec]=[true]
4653    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(inherit_codec=true)
4654    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_number]=[UNDEF]
4655    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_number=)
4656    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [effective_caller_id_name]=[UNDEF]
4657    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(effective_caller_id_name=)
4658    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [hangup_after_bridge]=[true]
4659    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(hangup_after_bridge=true)
4660    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
4661    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 unset(call_timeout)
4662    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
4663    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=outbound)
4664    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [sip_h_X-accountcode]=[UNDEF]
4665    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(sip_h_X-accountcode=)
4666    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 hash(insert/192.168.1.83-last_dial/600/6046812011)
4667    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:31 -0700]
4668    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:31 -0700)
4669    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
4670    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(origination_callee_id_name=6046812011)
4671    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_number]=[600]
4672    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_number=600)
4673    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:328 sofia/internal/600@192.168.1.83:5060 Standard EXECUTE
4674    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_sofia.c:209 sofia/internal/600@192.168.1.83:5060 SOFIA EXECUTE
4675    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/600@192.168.1.83:5060) State EXECUTE
4676    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_EXECUTE (Cur 3 Tot 241)
4677    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING going to sleep
4678    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/600@192.168.1.83:5060) State Change CS_ROUTING -> CS_EXECUTE
4679    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4680    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(continue_on_fail=true)
4681    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(callee_id_number=6046812011)
4682    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(ignore_display_updates=true)
4683    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(inherit_codec=true)
4684    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_number=${outbound_caller_id_number})
4685    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(effective_caller_id_name=${outbound_caller_id_name})
4686    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(hangup_after_bridge=true)
4687    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action unset(call_timeout)
4688    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(call_direction=outbound)
4689    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(sip_h_X-accountcode=${accountcode})
4690    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
4691    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
4692    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->Grandstream FXO.10d] continue=false
4693    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_number]=[UNDEF]
4694    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_number=)
4695    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
4696    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [outbound_caller_id_name]=[UNDEF]
4697    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(outbound_caller_id_name=)
4698    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
4699    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
4700    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_number]=[UNDEF]
4701    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_number=)
4702    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
4703    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [emergency_caller_id_name]=[UNDEF]
4704    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(emergency_caller_id_name=)
4705    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
4706    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
4707    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->default_caller_id] continue=true
4708    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
4709    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->speed_dial] continue=false
4710    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
4711    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [redial] () =~ // break=never
4712    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
4713    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->redial] continue=true
4714    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
4715    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
4716    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4717    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4718    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
4719    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4720    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4721    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
4722    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4723    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4724    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
4725    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4726    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_record]=[UNDEF]
4727    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_record=)
4728    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
4729    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
4730    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
4731    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4732    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4733    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
4734    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4735    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4736    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
4737    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4738    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4739    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
4740    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4741    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [from_user_exists]=[true]
4742    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(from_user_exists=true)
4743    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
4744    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_record] () =~ // break=on-false
4745    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_record] continue=true
4746    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
4747    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action export(origination_callee_id_name=${destination_number})
4748    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [variables] () =~ // break=on-false
4749    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->variables] continue=true
4750    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
4751    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 export(call_direction=local)
4752    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 ANTI-Action export(call_direction=local) INLINE
4753    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
4754    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->call-direction] continue=true
4755    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_number=${caller_id_number})
4756    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_id_name]=[600]
4757    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_id_name=600)
4758    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_id_name=${caller_id_name}) INLINE
4759    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [caller_destination]=[6046812011]
4760    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(caller_destination=6046812011)
4761    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(caller_destination=${destination_number}) INLINE
4762    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
4763    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->caller-details] continue=true
4764    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
4765    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_dptools.c:1598 SET sofia/internal/600@192.168.1.83:5060 [user_exists]=[false]
4766    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 EXECUTE sofia/internal/600@192.168.1.83:5060 set(user_exists=false)
4767    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
4768    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 Regex (PASS) [user_exists] () =~ // break=on-false
4769    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 Dialplan: sofia/internal/600@192.168.1.83:5060 parsing [192.168.1.83->user_exists] continue=true
4770    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
4771    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:236 sofia/internal/600@192.168.1.83:5060 Standard ROUTING
4772    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_sofia.c:154 sofia/internal/600@192.168.1.83:5060 SOFIA ROUTING
4773    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/600@192.168.1.83:5060) State ROUTING
4774    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_channel.c:2249 (sofia/internal/600@192.168.1.83:5060) Callstate Change DOWN -> RINGING
4775    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_ROUTING (Cur 3 Tot 241)
4776    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT going to sleep
4777    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/600@192.168.1.83:5060) State Change CS_INIT -> CS_ROUTING
4778    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:40 sofia/internal/600@192.168.1.83:5060 Standard INIT
4779    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] mod_sofia.c:93 sofia/internal/600@192.168.1.83:5060 SOFIA INIT
4780    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/600@192.168.1.83:5060) State INIT
4781    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_INIT (Cur 3 Tot 241)
4782    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] sofia.c:7716 (sofia/internal/600@192.168.1.83:5060) State Change CS_NEW -> CS_INIT
4783    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5795 sofia/internal/600@192.168.1.83:5060 Set 2833 dtmf send payload to 101 recv payload to 101
4784    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
4785    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_codec.c:111 sofia/internal/600@192.168.1.83:5060 Original read codec set to PCMU:0
4786    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/600@192.168.1.83:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
4787    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
4788    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
4789    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
4790    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
4791    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
4792    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
4793    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
4794    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
4795    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
4796    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076
4797    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 a=ptime:20
4798    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 a=rtpmap:13 CN/8000
4799    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 a=fmtp:101 0-16
4800    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 a=rtpmap:101 telephone-event/8000
4801    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 a=rtpmap:8 PCMA/8000
4802    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 a=rtpmap:0 PCMU/8000
4803    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 m=audio 20030 RTP/AVP 0 8 101 13
4804    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 t=0 0
4805    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 c=IN IP4 192.168.1.83
4806    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 s=FreeSWITCH
4807    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 o=FreeSWITCH 1568312141 1568312142 IN IP4 192.168.1.83
4808    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 v=0
4809    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] sofia.c:7301 Remote SDP:
4810    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.850496 [DEBUG] sofia.c:7291 Channel sofia/internal/600@192.168.1.83:5060 entering state [received][100]
4811    2019-09-12 16:49:31.830506 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
4812    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.830506 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
4813    2019-09-12 16:49:31.810492 [DEBUG] sofia.c:2522 Re-attaching to session f76ae90e-d5b7-11e9-b0ac-213a7b2c3076
4814    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
4815    2019-09-12 16:49:31.810492 [DEBUG] sofia.c:2413 detaching session f76ae90e-d5b7-11e9-b0ac-213a7b2c3076
4816    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/600@192.168.1.83:5060) State NEW
4817    2019-09-12 16:49:31.810492 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.83
4818    2019-09-12 16:49:31.810492 [DEBUG] sofia.c:10263 IP 192.168.1.83 Rejected by acl "domains". Falling back to Digest auth.
4819    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] sofia.c:10092 sofia/internal/600@192.168.1.83:5060 receiving invite from 192.168.1.83:5080 version: 1.8.4 64bit
4820    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/600@192.168.1.83:5060) Running State Change CS_NEW (Cur 3 Tot 241)
4821    f76ae90e-d5b7-11e9-b0ac-213a7b2c3076 2019-09-12 16:49:31.810492 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/600@192.168.1.83:5060 [f76ae90e-d5b7-11e9-b0ac-213a7b2c3076]
4822    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] sofia.c:7291 Channel sofia/external/6046812011 entering state [calling][0]
4823    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA going to sleep
4824    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:662 (sofia/external/6046812011) State CONSUME_MEDIA
4825    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_CONSUME_MEDIA (Cur 2 Tot 240)
4826    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING going to sleep
4827    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_ivr_originate.c:67 (sofia/external/6046812011) State Change CS_ROUTING -> CS_CONSUME_MEDIA
4828    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_sofia.c:154 sofia/external/6046812011 SOFIA ROUTING
4829    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:643 (sofia/external/6046812011) State ROUTING
4830    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_ROUTING (Cur 2 Tot 240)
4831    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT going to sleep
4832    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:48 (sofia/external/6046812011) State Change CS_INIT -> CS_ROUTING
4833    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:40 sofia/external/6046812011 Standard INIT
4834    f76abd44-d5b7-11e9-b0a8-213a7b2c3076
4835    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 a=sendrecv
4836    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 a=ptime:20
4837    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 a=rtpmap:13 CN/8000
4838    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 a=fmtp:101 0-16
4839    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 a=rtpmap:101 telephone-event/8000
4840    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 a=rtpmap:8 PCMA/8000
4841    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 a=rtpmap:0 PCMU/8000
4842    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 m=audio 20030 RTP/AVP 0 8 101 13
4843    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 t=0 0
4844    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 c=IN IP4 192.168.1.83
4845    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 s=FreeSWITCH
4846    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 o=FreeSWITCH 1568312141 1568312142 IN IP4 192.168.1.83
4847    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 v=0
4848    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 Local SDP:
4849    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] sofia_glue.c:1302 sofia/external/6046812011 sending invite version: 1.8.4 64bit
4850    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_sofia.c:93 sofia/external/6046812011 SOFIA INIT
4851    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:627 (sofia/external/6046812011) State INIT
4852    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:584 (sofia/external/6046812011) Running State Change CS_INIT (Cur 2 Tot 240)
4853    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_sofia.c:5018 (sofia/external/6046812011) State Change CS_NEW -> CS_INIT
4854    f76abd44-d5b7-11e9-b0a8-213a7b2c3076 2019-09-12 16:49:31.810492 [NOTICE] switch_channel.c:1104 New Channel sofia/external/6046812011 [f76abd44-d5b7-11e9-b0a8-213a7b2c3076]
4855    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_ivr_originate.c:2204 Parsing global variables
4856    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_channel.c:1250 sofia/internal/anonymous@anonymous.invalid EXPORTING[export_vars] [call_direction]=[outbound] to event
4857    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_channel.c:1250 sofia/internal/anonymous@anonymous.invalid EXPORTING[export_vars] [origination_callee_id_name]=[6046812011] to event
4858    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_channel.c:1250 sofia/internal/anonymous@anonymous.invalid EXPORTING[export_vars] [call_direction]=[outbound] to event
4859    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_channel.c:1250 sofia/internal/anonymous@anonymous.invalid EXPORTING[export_vars] [domain_name]=[192.168.1.83] to event
4860    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4861    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [continue_on_fail]=[true]
4862    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(continue_on_fail=true)
4863    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [callee_id_number]=[6046812011]
4864    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(callee_id_number=6046812011)
4865    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [ignore_display_updates]=[true]
4866    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(ignore_display_updates=true)
4867    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [inherit_codec]=[true]
4868    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(inherit_codec=true)
4869    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [effective_caller_id_number]=[UNDEF]
4870    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(effective_caller_id_number=)
4871    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [effective_caller_id_name]=[UNDEF]
4872    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(effective_caller_id_name=)
4873    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [hangup_after_bridge]=[true]
4874    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(hangup_after_bridge=true)
4875    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1743 UNSET [call_timeout]
4876    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid unset(call_timeout)
4877    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[outbound]
4878    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid export(call_direction=outbound)
4879    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [sip_h_X-accountcode]=[UNDEF]
4880    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(sip_h_X-accountcode=)
4881    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid hash(insert/192.168.1.83-last_dial/500/6046812011)
4882    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [RFC2822_DATE]=[Thu, 12 Sep 2019 16:49:31 -0700]
4883    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(RFC2822_DATE=Thu, 12 Sep 2019 16:49:31 -0700)
4884    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[6046812011]
4885    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid export(origination_callee_id_name=6046812011)
4886    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [caller_id_number]=[500]
4887    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(caller_id_number=500)
4888    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:328 sofia/internal/anonymous@anonymous.invalid Standard EXECUTE
4889    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_sofia.c:209 sofia/internal/anonymous@anonymous.invalid SOFIA EXECUTE
4890    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/anonymous@anonymous.invalid) State EXECUTE
4891    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_EXECUTE (Cur 1 Tot 239)
4892    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/anonymous@anonymous.invalid) State ROUTING going to sleep
4893    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/anonymous@anonymous.invalid) State Change CS_ROUTING -> CS_EXECUTE
4894    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action bridge(sofia/gateway/f0684e1a-65a7-48fc-b5e4-53bc9f0b9796/6046812011)
4895    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(continue_on_fail=true)
4896    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(callee_id_number=6046812011)
4897    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(ignore_display_updates=true)
4898    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(inherit_codec=true)
4899    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(effective_caller_id_number=${outbound_caller_id_number})
4900    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(effective_caller_id_name=${outbound_caller_id_name})
4901    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(hangup_after_bridge=true)
4902    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action unset(call_timeout)
4903    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action export(call_direction=outbound)
4904    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(sip_h_X-accountcode=${accountcode})
4905    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [Grandstream FXO.10d] destination_number(6046812011) =~ /^(\d{10})$/ break=on-false
4906    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [Grandstream FXO.10d] ${user_exists}(false) =~ /false/ break=on-false
4907    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->Grandstream FXO.10d] continue=false
4908    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [outbound_caller_id_number]=[UNDEF]
4909    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(outbound_caller_id_number=)
4910    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
4911    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [outbound_caller_id_name]=[UNDEF]
4912    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(outbound_caller_id_name=)
4913    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
4914    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
4915    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [emergency_caller_id_number]=[UNDEF]
4916    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(emergency_caller_id_number=)
4917    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
4918    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [emergency_caller_id_name]=[UNDEF]
4919    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(emergency_caller_id_name=)
4920    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
4921    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
4922    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->default_caller_id] continue=true
4923    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [speed_dial] destination_number(6046812011) =~ /^\*0(.*)$/ break=on-false
4924    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->speed_dial] continue=false
4925    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
4926    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [redial] () =~ // break=never
4927    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [redial] destination_number(6046812011) =~ /^(redial|\*870)$/ break=on-true
4928    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->redial] continue=true
4929    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
4930    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
4931    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4932    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_exists}(false) =~ /^true$/ break=never
4933    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
4934    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4935    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_exists}(false) =~ /^true$/ break=never
4936    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
4937    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4938    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_exists}(false) =~ /^true$/ break=never
4939    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
4940    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_exists}(false) =~ /^true$/ break=never
4941    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${from_user_exists}(false) =~ /^true$/ break=never
4942    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
4943    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
4944    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4945    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
4946    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
4947    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4948    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
4949    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
4950    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4951    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
4952    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
4953    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [from_user_exists]=[false]
4954    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(from_user_exists=false)
4955    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
4956    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [user_record] () =~ // break=on-false
4957    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->user_record] continue=true
4958    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
4959    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action export(origination_callee_id_name=${destination_number})
4960    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [variables] () =~ // break=on-false
4961    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->variables] continue=true
4962    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [call_direction]=[local]
4963    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid export(call_direction=local)
4964    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid ANTI-Action export(call_direction=local) INLINE
4965    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
4966    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->call-direction] continue=true
4967    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(caller_id_number=${caller_id_number})
4968    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [caller_id_name]=[500]
4969    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(caller_id_name=500)
4970    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(caller_id_name=${caller_id_name}) INLINE
4971    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [caller_destination]=[6046812011]
4972    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(caller_destination=6046812011)
4973    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(caller_destination=${destination_number}) INLINE
4974    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
4975    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->caller-details] continue=true
4976    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
4977    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.810492 [DEBUG] mod_dptools.c:1598 SET sofia/internal/anonymous@anonymous.invalid [user_exists]=[false]
4978    f7625b40-d5b7-11e9-b08b-213a7b2c3076 EXECUTE sofia/internal/anonymous@anonymous.invalid set(user_exists=false)
4979    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
4980    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid Regex (PASS) [user_exists] () =~ // break=on-false
4981    f7625b40-d5b7-11e9-b08b-213a7b2c3076 Dialplan: sofia/internal/anonymous@anonymous.invalid parsing [192.168.1.83->user_exists] continue=true
4982    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [INFO] mod_dialplan_xml.c:637 Processing Chris <500>->6046812011 in context 192.168.1.83
4983    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_state_machine.c:236 sofia/internal/anonymous@anonymous.invalid Standard ROUTING
4984    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] mod_sofia.c:154 sofia/internal/anonymous@anonymous.invalid SOFIA ROUTING
4985    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/anonymous@anonymous.invalid) State ROUTING
4986    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_channel.c:2249 (sofia/internal/anonymous@anonymous.invalid) Callstate Change DOWN -> RINGING
4987    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_ROUTING (Cur 1 Tot 239)
4988    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/anonymous@anonymous.invalid) State INIT going to sleep
4989    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/anonymous@anonymous.invalid) State Change CS_INIT -> CS_ROUTING
4990    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_state_machine.c:40 sofia/internal/anonymous@anonymous.invalid Standard INIT
4991    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] mod_sofia.c:93 sofia/internal/anonymous@anonymous.invalid SOFIA INIT
4992    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/anonymous@anonymous.invalid) State INIT
4993    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_INIT (Cur 1 Tot 239)
4994    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] sofia.c:7716 (sofia/internal/anonymous@anonymous.invalid) State Change CS_NEW -> CS_INIT
4995    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5795 sofia/internal/anonymous@anonymous.invalid Set 2833 dtmf send payload to 101 recv payload to 101
4996    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5737 Set telephone-event payload to 101@8000
4997    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_codec.c:111 sofia/internal/anonymous@anonymous.invalid Original read codec set to PCMU:0
4998    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:3781 Set Codec sofia/internal/anonymous@anonymous.invalid PCMU/8000 20 ms 160 samples 64000 bits 1 channels
4999    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5394 Set telephone-event payload to 101@8000
5000    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [opus:123:48000:20:0:2]/[PCMA:8:8000:20:64000:1]
5001    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [opus:123:48000:20:0:2]/[PCMU:0:8000:20:64000:1]
5002    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [opus:123:48000:20:0:2]/[G722:9:8000:20:64000:1]
5003    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G726-32:2:8000:20:0:1]/[PCMA:8:8000:20:64000:1]
5004    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G726-32:2:8000:20:0:1]/[PCMU:0:8000:20:64000:1]
5005    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G726-32:2:8000:20:0:1]/[G722:9:8000:20:64000:1]
5006    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [iLBC:97:8000:20:0:1]/[PCMA:8:8000:20:64000:1]
5007    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [iLBC:97:8000:20:0:1]/[PCMU:0:8000:20:64000:1]
5008    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [iLBC:97:8000:20:0:1]/[G722:9:8000:20:64000:1]
5009    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
5010    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
5011    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [G722:9:8000:20:64000:1] ++++ is saved as a match
5012    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G722:9:8000:20:64000:1]/[G722:9:8000:20:64000:1]
5013    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
5014    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
5015    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G729:18:8000:20:8000:1]/[G722:9:8000:20:64000:1]
5016    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G723:4:8000:20:6300:1]/[PCMA:8:8000:20:64000:1]
5017    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G723:4:8000:20:6300:1]/[PCMU:0:8000:20:64000:1]
5018    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [G723:4:8000:20:6300:1]/[G722:9:8000:20:64000:1]
5019    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
5020    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
5021    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
5022    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
5023    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
5024    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5533 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
5025    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
5026    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] switch_core_media.c:5478 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
5027    f7625b40-d5b7-11e9-b08b-213a7b2c3076
5028    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=ptime:20
5029    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=fmtp:101 0-15
5030    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=rtpmap:101 telephone-event/8000
5031    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=rtpmap:123 opus/48000/2
5032    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=rtpmap:2 G726-32/8000
5033    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=fmtp:97 mode=30
5034    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=rtpmap:97 iLBC/8000
5035    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=rtpmap:9 G722/8000
5036    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=fmtp:18 annexb=no
5037    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=rtpmap:18 G729/8000
5038    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=rtpmap:4 G723/8000
5039    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=rtpmap:8 PCMA/8000
5040    f7625b40-d5b7-11e9-b08b-213a7b2c3076 a=rtpmap:0 PCMU/8000
5041    f7625b40-d5b7-11e9-b08b-213a7b2c3076 m=audio 5036 RTP/AVP 0 8 4 18 9 97 2 123 101
5042    f7625b40-d5b7-11e9-b08b-213a7b2c3076 t=0 0
5043    f7625b40-d5b7-11e9-b08b-213a7b2c3076 c=IN IP4 192.168.1.97
5044    f7625b40-d5b7-11e9-b08b-213a7b2c3076 s=SIP Call
5045    f7625b40-d5b7-11e9-b08b-213a7b2c3076 o=500 8001 8000 IN IP4 192.168.1.97
5046    f7625b40-d5b7-11e9-b08b-213a7b2c3076 v=0
5047    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] sofia.c:7301 Remote SDP:
5048    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.790497 [DEBUG] sofia.c:7291 Channel sofia/internal/anonymous@anonymous.invalid entering state [received][100]
5049    2019-09-12 16:49:31.770496 [DEBUG] sofia.c:10263 IP 192.168.1.97 Rejected by acl "domains". Falling back to Digest auth.
5050    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.770496 [DEBUG] sofia.c:10092 sofia/internal/anonymous@anonymous.invalid receiving invite from 192.168.1.97:5062 version: 1.8.4 64bit
5051    2019-09-12 16:49:31.770496 [DEBUG] sofia.c:2522 Re-attaching to session f7625b40-d5b7-11e9-b08b-213a7b2c3076
5052    2019-09-12 16:49:31.750498 [DEBUG] sofia.c:2413 detaching session f7625b40-d5b7-11e9-b08b-213a7b2c3076
5053    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.750498 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/anonymous@anonymous.invalid) State NEW
5054    2019-09-12 16:49:31.750498 [WARNING] sofia_reg.c:1798 SIP auth challenge (INVITE) on sofia profile 'internal' for [6046812011@192.168.1.83] from ip 192.168.1.97
5055    2019-09-12 16:49:31.750498 [DEBUG] sofia.c:10263 IP 192.168.1.97 Rejected by acl "domains". Falling back to Digest auth.
5056    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.750498 [DEBUG] sofia.c:10092 sofia/internal/anonymous@anonymous.invalid receiving invite from 192.168.1.97:5062 version: 1.8.4 64bit
5057    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.750498 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/anonymous@anonymous.invalid) Running State Change CS_NEW (Cur 1 Tot 239)
5058    f7625b40-d5b7-11e9-b08b-213a7b2c3076 2019-09-12 16:49:31.750498 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/anonymous@anonymous.invalid [f7625b40-d5b7-11e9-b08b-213a7b2c3076]
I haven't used POTS on the PBX before so not sure what's going on here, and I can't identify anything blatantly wrong in that log.
Sorry mate.
