outbound calls without extension
mrjoli021
133
I have Cisco IAD with a couple of analog lines hanging off them. I have created a bridge on the inbound DID side and route the call the IAD. This is working fine. The problem is that when I try to make an outbound call.
The call comes into the fusionPBX box as DID@CiscoIAD (10.21.10.12) and since there is no extension for this DID freeswitch does not process the call. What are my options to process these types of calls where there are no extension on FusionPBX?
recv 1142 bytes from udp/[10.21.10.12]:61544 at 11:33:09.223320:
INVITE sip:15556667777@10.21.10.4:5060 SIP/2.0
Via: SIP/2.0/UDP 10.21.10.12:5060;branch=z9hG4bK14E05
Remote-Party-ID: <sip:11112223333@10.21.10.12>;party=calling;screen=no;privacy=off
From: <sip:11112223333@10.21.10.12>;tag=486DC2F8-1C36
To: <sip:15556667777@10.21.10.4>
Date: Mon, 27 Apr 2020 14:50:59 GMT
Call-ID: 57796C5D-87CD11EA-8107947A-535404DD@10.21.10.12
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1427655341-2278363626-2164429946-1398015197
User-Agent: Cisco-SIPGateway/IOS-15.2.1.T3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1587999059
Contact: <sip:11112223333@10.21.10.12:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 9354 8115 IN IP4 10.21.10.12
s=SIP Call
c=IN IP4 10.21.10.12
t=0 0
m=audio 20376 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-16
a=ptime:20
send 317 bytes to udp/[10.21.10.12]:5060 at 11:33:09.223871:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Timestamp: 1587999059 0.000258
User-Agent: FreeSWITCH
Content-Length: 0
2020-04-27 11:33:04.631015 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/11112223333@10.21.10.12 [65e02ee7-9163-4428-bff3-e43afa3502ea]
2020-04-27 11:33:04.631015 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/11112223333@10.21.10.12) Running State Change CS_NEW (Cur 1 Tot 85)
2020-04-27 11:33:04.631015 [DEBUG] sofia.c:9873 sofia/internal/11112223333@10.21.10.12 receiving invite from 10.21.10.12:61544 version: 1.6.20 -37-987c9b9 64bit
2020-04-27 11:33:04.631015 [DEBUG] sofia.c:10044 IP 10.21.10.12 Rejected by acl "domains". Falling back to Digest auth.
send 786 bytes to udp/[10.21.10.12]:5060 at 11:33:09.225336:
To: <sip:15556667777@10.21.10.4>;tag=tjF3Ztrm6HjmH
CSeq: 101 INVITE
Accept: application/sdp
Proxy-Authenticate: Digest realm="10.21.10.4", nonce="33c230f5-75e6-43f7-b774-5ccd7f72fbdc", algorithm=MD5, qop="auth"
Content-Length: 0
2020-04-27 11:33:04.631015 [DEBUG] sofia.c:2334 detaching session 65e02ee7-9163-4428-bff3-e43afa3502ea
2020-04-27 11:33:04.631015 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [15556667777@10.21.10.4] from ip 10.21.10.12
2020-04-27 11:33:04.631015 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/11112223333@10.21.10.12) State NEW
recv 387 bytes from udp/[10.21.10.12]:61544 at 11:33:09.228231:
ACK sip:15556667777@10.21.10.4:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
