B benw Member Jan 21, 2019 30 2 8 40 Feb 18, 2019 #1 ive got work ext based methods working but looking for better solution. I need to set a condition based on the outbound caller id of the ext (first 3 digits) to pre pend that same cid for outbound routing. any ideas?
C chrisbware New Member Apr 17, 2018 28 2 3 Italy chrisbware.wordpress.com Feb 20, 2019 #2 Make an example please...in order to help you.
B benw Member Jan 21, 2019 30 2 8 40 Feb 20, 2019 #3 basically i need a simpler way to have a outbound route thats setup for different area codes. example: user ext 100 with a outbound caller id of 916-555-5555 would go outbound only the route that allows / condition set for 916-
A ad5ou Active Member Jun 12, 2018 890 206 43 Feb 20, 2019 #4 Set a condition in the outbound routes to check caller id
B benw Member Jan 21, 2019 30 2 8 40 Feb 20, 2019 #5 ad5ou said: Set a condition in the outbound routes to check caller id View attachment 698 Click to expand... that did trick
