SOLVED phones wont register after upgrade 4.2 to 4.4
krooney
176
16
hi all
im facing this issue after upgrading my cluster from 4.2 to 4.4 any help would be appreciated.
*** Ok just found it will only register with UDP***
Is there a setting to change to tcp before upgrade it was fine
No settings at all to change, did you follow the instructions exactly for a version upgrade?
Also, post some sngrep logs of a register attempt or even FS logs, just saying its broke doesn't cut it, you need to help us to help you.
Weird working now mark that as solved but i opened another thread where i cant make outbound calls
