Play sound file once after Paging
henryd99
20
Hi all,
Hope your all doing well.
I've been playing with the dialplan trying to make an audio .wav file play once *724 successfully pages 3 devices.
I want the audio file to play through the speakers straight away, a sort of alarm system.
Thanks!
There is a documented way to use existing dial plan to do exactly what you wish in the fusionpbx.com member documentation that I don't believe we are allowed to share here. (but it might be posted somewhere already)
There is also the "school bells" optional app that might be of use to you.
Thanks for the response, Ive been on the fence about the membership due to the API library they have already made, this may be the push to go in that direction. Thanks!
I am actually the sponsor for the school bells app. Igor doesn't use the master release so app only works on older versions.
You can also edit a dialplan with export command to play the file after answer
