play_and_get_digits no input vs wrong input
ewdpb
150
21
I am writing a LUA script using freeswitch play_and_get_digits. The code is quite simple:
    local caller_input = session:playAndGetDigits(min_digits_allowed, max_digits_allowed, max_tries, timeout, terminators, audio, audio_on_invalid_input, pattern, caller_input, interdigit_timeout);
It works well. My only problem is when the caller does not enter anything. By default it play the audio defined in audio_on_invalid_input which I use to inform the caller the value they entered is not valid. I would like to be able to differentiate between wrong input (e.g. digit 5 when only 1 or 2 are allowed) and no input at all.
What would the best way to do this be?
Thanks!
