polyphase lowpass filter
glennbtn
Hi All
I have setup a queue and using the lua script for position in the queue as per https://freeswitch.org/confluence/display/FREESWITCH/mod_callcenter
I have 2 servers built exactly the same. It works perfectly on 1 but the other just rejects the call and the only error I can find is
mod_dptools.c:3631 Originate Failed. Cause: CALL_REJECTED
mod_shout.c:332 polyphase lowpass filter disabled
Anyone know how and where I can enable the filter?
Ok that was a bum steer in the logs. The filter was to do with call recoding which is working fine.
