Problem in LXC with php session files
588
There seems to be an oustanding issue in containers that has not been fixed in jessie. You may run for a long time and never suffer but slowly you will be accumulating tiny session files.
Have a look in: /var/lib/php/sessions
Anyway the fix for now is to change the cronjob that runs the garbage collector and stop it using systemd:
systemctl disable phpsessionclean.timer
systemctl stop phpsessionclean.timer
Then:
nano -w /etc/cron.d/php
Change it to:
09,39 *     * * *     root   [ -x /usr/lib/php/sessionclean ] && /usr/lib/php/sessionclean
Reactions: krooney
