problem registering new number
banda bassotti
I have registered a new number but can not receive calls. follows the tcpdump and configuration:
14:55:10.684634 IP 192.168.1.1.5065 > 192.168.1.202.5080: UDP, bad length 1673 > 1472
E...f. .@.jS..............6.INVITE sip:gw+5c3c087c-84c6-4c81-bf0b-f910bca81c33@192.168.1.202:5080;transport=UDP;user=phone SIP/2.0
From: <sip:+3902xxxx@telecomitalia.it;user=phone>;tag=1bc7918-7f000001-13e2-50029-42db-2c898022-42db
To: <sip:**02@modemtelecom.homenet.telecomitalia.it;user=phone>
Call-ID: 1be2490-7f000001-13e2-50029-42db-71e5fb3c-42db
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.1.1:5065;branch=z9hG4bK-42db-10527b9-59a85103
Max-Forwards: 66
Accept: application/sdp,application/isup,application/xml
Accept-Contact: *;audio;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel"
Supported: timer,100rel
Session-ID: 1b28b684985a19daed23ff2e3954fdfd
Allow: INVITE, ACK, BYE, CANCEL, INFO, OPTIONS, REFER, SUBSCRIBE, NOTIFY, UPDATE, PRACK
P-Asserted-Identity: <sip:+3902xxxx@telecomitalia.it;user=phone>
P-Called-Party-ID: <tel:+3906xxxx>
Min-SE: 180
Contact: <sip:+3902xxxx@192.168.1.1:5065;transport=UDP;user=phone>;audio;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel"
User-Agent: Technicolor / VDNT-S / AGVTF_5.3.3 / AGVTF_5.3.3
Proxy-Authorization: Digest username="+3906xxxx",realm="modemtelecom.homenet.telecomitalia.it",nonce="d93bc4c5-66d1-4d17-b72f-a6a07bf9eefd",uri="sip:gw+5c3c087c-84c6-4c81-bf0b-f910bca81c33@192.168.1.202:5080;transport=UDP",response="3eabfb51b55398724e3bfe87ac813050",algorithm=MD5,cnonce="10527bb",qop=auth,nc=00000010
Content-Type: application/sdp
Content-Length: 229
v=0
o=- 2134125489 42472937
14:55:10.685132 IP 192.168.1.202.5080 > 192.168.1.1.5065: UDP, length 381
Eh......@.S
................SIP/2.0 100 Trying
CSeq: 1 INVITE
User-Agent: FreeSWITCH
Content-Length: 0
14:55:10.686547 IP 192.168.1.202.5080 > 192.168.1.1.5065: UDP, length 775
Eh.#....@.Q................<SIP/2.0 407 Proxy Authentication Required
To: <sip:**02@modemtelecom.homenet.telecomitalia.it;user=phone>;tag=3UyS2XpSaajvF
CSeq: 1 INVITE
Proxy-Authenticate: Digest realm="modemtelecom.homenet.telecomitalia.it", nonce="15c78fec-a0c7-43c5-8927-a0bb8df628eb", stale=true, algorithm=MD5, qop="auth"
Content-Length: 0
14:55:10.696540 IP 192.168.1.1.5065 > 192.168.1.202.5080: UDP, length 605
E..yf...@................e..ACK sip:gw+5c3c087c-84c6-4c81-bf0b-f910bca81c33@192.168.1.202:5080;transport=UDP;user=phone SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
You have done something to alter the default behaviour, there is no way port 5080 should be asking for authentication, you must have changed settings, probably in the external profile.
This should work.
Advanced > Access Controls > Domains > "+"
Type = allow
CIDR = 85.119.188.3/32
SAVE
Status > SIP Status > Reload ACL
