problem with incoming call
yhbilisim
29
Hi
Do you have any information on this?
2019-01-05 10:23:21.676516 [NOTICE] switch_channel.c:1104 New Channel sofia/external/90534360XXXX@91.93.84.58 [d9df6411-46dc-4b6d-b92e-8d60dcbfcbc2]
2019-01-05 10:23:21.676516 [DEBUG] switch_core_state_machine.c:584 (sofia/external/90534360XXXX@91.93.84.58) Running State Change CS_NEW (Cur 1 Tot 3)
2019-01-05 10:23:21.676516 [DEBUG] sofia.c:9873 sofia/external/90534360XXXX@91.93.84.58 receiving invite from 91.93.84.58:5060 version: 1.6.20 -37-987c9b9 64bit
2019-01-05 10:23:21.676516 [DEBUG] sofia.c:10044 IP 91.93.84.58 Rejected by acl "domains". Falling back to Digest auth.
2019-01-05 10:23:21.676516 [DEBUG] switch_core_state_machine.c:603 (sofia/external/90534360XXXX@91.93.84.58) State NEW
2019-01-05 10:23:21.676516 [DEBUG] sofia.c:2334 detaching session d9df6411-46dc-4b6d-b92e-8d60dcbfcbc2
2019-01-05 10:23:21.716514 [NOTICE] switch_channel.c:1104 New Channel sofia/external/90534360XXXX@91.93.84.58 [853f6d4a-61db-4d38-86d5-712f4b846e1e]
2019-01-05 10:23:21.716514 [DEBUG] switch_core_state_machine.c:584 (sofia/external/90534360XXXX@91.93.84.58) Running State Change CS_NEW (Cur 2 Tot 4)
2019-01-05 10:23:21.716514 [DEBUG] sofia.c:9873 sofia/external/90534360XXXX@91.93.84.58 receiving invite from 91.93.84.58:5060 version: 1.6.20 -37-987c9b9 64bit
2019-01-05 10:23:21.716514 [DEBUG] sofia.c:10044 IP 91.93.84.58 Rejected by acl "domains". Falling back to Digest auth.
2019-01-05 10:23:21.716514 [DEBUG] switch_core_state_machine.c:603 (sofia/external/90534360XXXX@91.93.84.58) State NEW
2019-01-05 10:23:21.716514 [DEBUG] sofia.c:2334 detaching session 853f6d4a-61db-4d38-86d5-712f4b846e1e
Make sure to add your Carrier IP addresses to the Advanced -> Access Controls under Domains in the CIDR section if adding a single ip address then add 91.93.84.58/32 then go to Status -> SIP Status and click on the Reload ACL button.
Thank you.
