Hello
We are running FusionPBX with the following version
The system is running on Proxmox VM
When enabling "Call Recording" on particular extension - customer is experiencing bad quality of the calls
This is the only difference with other extensions at the same location
We did packet capture and no packet loss
What can be possible causing it ?
Thank you
Thank you
