Recommendation for best VoIP phone to use with FusionPBX
Lalitha Jayaraman
I am looking for a recommendation for best VoIP phone (provider) to use with FusionPBX. Any help would be appreciated..
Lalitha
+1 for Yealink. A detailed description of requirements might change the recommendation though :)
I am basically looking for a soft VoIP Phone that I can use and integrate with FusionPBX. The documentation says VoiceTel and SkyeTel? Is Yealinks a soft VoIP too??
Out of VoiceTel and SkyeTel which one is better?? Thanks!
We use Yealinks. Have also used Grandstreams from a legacy Asterisk system and Cisco. Found the Grandstream clickers broke and failed more frequently. Yealinks are easy and they are inexpensive. I just bought 7 used T-38G's in great condition with power supplies and new handset cords on ebay for about 200.00 for a small non-profit office. For my softphone on Android I bought the pay to play version of Zoiper, although my BPO staff in the Philipines are using Phonerlite on their PC's at home. Seems to be working for them.
