recording issue
gpetrom
20
Hi
I have enabled in on extension to record all calls.
In inbound calls. Call records are ok
When the extension is making an outbound call and i am going from cdr detail record to hear it. I am able to hear only the bleg not aleg(Local extension).
I am lost i do not know what i should search for
Anyone else has experienced such a problem?
PS In the actual call i do not have any audio issues.
Update solution found
It seems that this is not something with fusionpbx.
I have tried this with freeswitch and vanilla configuration and same thing happens.
So the solution was to enable this way the recordings
         <action application="set" data="bridge_pre_execute_bleg_app=record_session"/>
         <action application="set" data="bridge_pre_execute_bleg_data=$${recordings_dir}/${strftime(%Y-%m-%d-%H-%M-%S)}_${destination_number}_
Now I am trying to figure out how to enable this only in outgoing calls.
Hello
It seems that the problem exist when you want to record local calls also.
I have tried all possible scenarios and it just don t work.
This happens also in freeswitch with vanilla configuration.
I am testing in debian 11 with freeswitch 1.10.7
Does anyone else has this problem
