Registration and Outbound calls from the same IP
mrjoli021
133
I am running a DsipRouter instance and using that as my public facing Registration as well as my outbound gateway. The problem is that I have to set a domain ACL for the DSIProuter_LAN's IP for the registration to work. When I do this my phones from the internet register without any issues and Freeswitch sees them as comming from Kamailio's LAN IP. Inbound calls also work fine, the problem is on the outbound side. Freeswitch is treating the call as an Inbound call and cant find any routes in the public context because of this domain ACL rule.
How can I tell FusionPBX / Freeswitch to use the outbound routes for outbound calls?
1.1.1.1(phone) -> 174.89.3.4 (DsipRouter_WAN) -> 192.168.1.9 (Dsiprouter_LAN)-> 192.168.1.10 (FusionPBX) (phone gets registered but on the registration it says it is from 192.168.1.9 )
Outbound call fails with no routes found in public context. Eventhough there are outbound routes defined to go to DsipRouter_LAN)
