Ring All - Tiers - How do they apply?
gflow
287
Hi All,
Question regarding call centre ring strategy "Ring All" and how the tiers apply.
If I had 4 tiers and set "Tier rules apply = true" and I had 2 agents in each tier.
Agent call timeout is 30 seconds
Tier wait second is 15 seconds
I want the agents in each tier to ring for 15 seconds and then go to the next tier, have only those 2 agents ring for 15 seconds and go to the next tier and have only those agents ring....
That isn't happening, what is happening and im not sure if this is the correct behaviour or a bug:
After 15 seconds tier 2 will start ringing but tier 1 phones are still ringing and will ring until the agent timeout of 30 seconds is reached.
By the time I reach tier 4 I basically have all the agent phones ringing.
Does this sound right? I'm almost positive i've tested this before and it's not how it worked but I could be wrong.
I've now rebooted the machine and it's now not taking into account tier levels at all and just ringing all phones and I have "tier rules apply = true"
Any idea's?
I think i've figured it out, please correct me if anybody gets different results.
When using Ring All strategy in the call centre, with tiers apply enabled you can only have a maximum of two tiers.
If I have tiers 0,1,2,3,4,5 after all agents in tier 0 ring then all agents in tiers 1,2,3,4,5 will ring all the same time.
This is tested on 4.4.11
