Ring group name displaying on handset
galactic
26
Hi all
requiring what ring group the call is being distributed from to be displayed on handset
this can be done from other pbx's but cant seem to find it on fusion.
If you can't find it, it will need to be enabled.
Go to Advanced, Group Manager, press Permissions under Superadmin, search for ring_group_cid_name_prefix, and enable it.
You should protect it so that in the future it doesn't get disabled.
Good Luck.
