Ring Group timeout not working
Alfa
I get some trouble witch Rings Group... I have set a ring group with a 300 secondes timeout on extension, hangup at Timeout Destination. I call the ring group, It ring extension propely but after about 15~25 secondes it hangup.
Console show:
switch_ivr_originate.c:3601 Hangup sofia/internal/xxx@XXX.XXX.X.XX:12557 [CS_CONSUME_MEDIA] [NO_ANSWER]
switch_ivr_originate.c:2841 Cannot create outgoing channel of type [user] cause: [NO_ANSWER]
switch_ivr_originate.c:3829 Originate Resulted in Error Cause: 19 [NO_ANSWER]
mod_dptools.c:3409 Originate Failed. Cause: NO_ANSWER
I try to change timeout value, add/remove extensions from ring group, but nothing work :( I someone has solved a similar isue, I'm open to suggestion ;)
