Setting up DISA with a DID
gunemalli
24
Hey All,
I need some help on setting up DISA for a customer. They will have a dedicated DID which should ideally point straight to DISA so that they can toggle call diversion on/off.
With FreePBX you can directly point the call to the DISA, but with FusionPBX I can't seem to find a way to get this done. Also there's no documentation about this at all to even figure it out by myself.
Any help would be appreciated.
First step would be to search for DISA in the Dialplan Manager.
It's there, but disabled.
You could point a number at *3472 to begin testing.
I've been going through the same thing. I figured out that you have to enable it like James said... Then under Dialplan > Destinations set an outbound rule. After that is done you can enable the option through the IVR.
