Show Maximum Concurrent Calls
Robert Birch
114
Is there a way to tell how what the peak concurrent calls are on a given FusionPBX system?
If I go to Status -> Sip Status, I see the following:
UP 0 years, 324 days, 1 hour, 58 minutes, 38 seconds, 66 milliseconds, 377 microseconds
FreeSWITCH (Version 1.8.5 -6-31281a0bf1 64bit) is ready
611060 session(s) since startup
13 session(s) - peak 85, last 5min 13
0 session(s) per Sec out of max 30, peak 224, last 5min 2
1000 session(s) max
min idle cpu 0.00/87.83
Current Stack Size/Max 240K/8192K
Would the peak number be this? I can't really find exactly what these stats mean.
Or if I go to Status -> System Status, there is are entries about connections.
curr_connections1
total_connections24
connection_structures2
Is total_connections what I am looking for?
Thanks,
Shredder
Thanks,
Shredder
Hi Mate
Did you get an answer on this I kind of after the same thing, Trying to cut our costs down a but by reducung the number of channels we have on our Sip Trunk
