signalwire?
nktech1135
us
Has anybody used this carrier? If so what can you tell me about it?
They have a freeswitch module and i was wondering how it works with fusion?
The carrier IS Freeswitch. I don't think we use the module with FusionPBX for some reason.
If you want to terminate traffic with them you have to send it with the CID of a DID you have registered with them. It's basically a non starter for me as I might be getting origination from one place and need to send to a different provider based on cost.
Is it possible to install and enable the signalwire mod on FusionPBX? Steps I took
- Updated the FusionPBX.
- Edited the file /var/www/fusionpbx/resources/templates/conf/autoload_configs/modules.conf.xml and added signalwire module right under Applications.
- Restarted FusionPBX.
