SOLVED SIP Phone Registration
mc6650
123
Hello
I have a SIP phone that can register to a stand alone FusionPBX server (192.168.2.25). If I shut that server down and turn on a virtual machine with the exact same ip address (192.168.2.25) as the stand alone, the soft phone will not register? I can ping 192.168.2.25 and I've run a sudo firewall-cmd --state on the virtual Debian 11 machine and I get an error message (sudo: firewall-cmd: command not found), so I don't believe there's a firewall running within it, plus the Proxmox VM doesn't have firewall turned on. Any ideas on how I can go about registering my soft phone on the VM? I should point out that the FusionPBX on the VM was created from a backup / restore I took from the stand alone server.
Thanks in advance for any help that can be provided.
Can you post your Sofia status profile internal and external? What domain is FB using as initial?
I've solved the issue by rebuilding the FusionPBX server on the virtual machine. Thanks for your reply.
