SOS - Inbound calls work but NOT outbound calls
rfc1920
16
I have a test setup at home using VOIP.ms and a setup at work pointing to an asterisk system which is our very poor man's SBC. I have been able to get inbound calls, hold music, etc. to work just fine. So far I am working with one number (mine).
I have setup two gateways: the aforementioned asterisk server as well as Vitelity as a backup provider. FusionPBX is behind our NAT firewall with no ports forwarded, etc. We register to Vitelity and NOREG to asterisk. I currently have domain ACL set to allow with no entries.
However, outbound calls appear to instantly be re-rerouted as inbound calls and fail immediately. They never leave FusionPBX so I am sure I have screwed something up.
Below, 7135554444 is the called number, 7134445555 is the calling number as well as a destination for extension 11264, att.local.domain is the servername/domain of FusionPBX, and phone.client.ip.address is the calling phone client (3CX):
2021-07-12 15:07:43.534144 [DEBUG] switch_core_media.c:3847 Set Codec sofia/internal/11264@att.local.domain:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
2021-07-12 15:07:43.534144 [DEBUG] switch_core_codec.c:111 sofia/internal/11264@att.local.domain:5060 Original read codec set to PCMU:0
2021-07-12 15:07:43.534144 [DEBUG] switch_core_media.c:5860 Set telephone-event payload to 101@8000
2021-07-12 15:07:43.534144 [DEBUG] switch_core_media.c:5918 sofia/internal/11264@att.local.domain:5060 Set 2833 dtmf send payload to 101 recv payload to 101
2021-07-12 15:07:43.534144 [DEBUG] sofia.c:7840 (sofia/internal/11264@att.local.domain:5060) State Change CS_NEW -> CS_INIT
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:604 (sofia/internal/11264@att.local.domain:5060) State NEW
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/11264@att.local.domain:5060) Running State Change CS_INIT (Cur 1 Tot 219)
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/11264@att.local.domain:5060) State INIT
2021-07-12 15:07:43.534144 [DEBUG] mod_sofia.c:93 sofia/internal/11264@att.local.domain:5060 SOFIA INIT
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:40 sofia/internal/11264@att.local.domain:5060 Standard INIT
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/11264@att.local.domain:5060) State Change CS_INIT -> CS_ROUTING
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/11264@att.local.domain:5060) State INIT going to sleep
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/11264@att.local.domain:5060) Running State Change CS_ROUTING (Cur 1 Tot 219)
2021-07-12 15:07:43.534144 [DEBUG] switch_channel.c:2332 (sofia/internal/11264@att.local.domain:5060) Callstate Change DOWN -> RINGING
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/11264@att.local.domain:5060) State ROUTING
2021-07-12 15:07:43.534144 [DEBUG] mod_sofia.c:154 sofia/internal/11264@att.local.domain:5060 SOFIA ROUTING
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:236 sofia/internal/11264@att.local.domain:5060 Standard ROUTING
2021-07-12 15:07:43.534144 [INFO] mod_dialplan_xml.c:637 Processing First Last <11264>->97135554444 in context public
Dialplan: sofia/internal/11264@att.local.domain:5060 parsing [public->caller-details] continue=true
Dialplan: sofia/internal/11264@att.local.domain:5060 Regex (PASS) [caller-details] () =~ // break=never
Dialplan: sofia/internal/11264@att.local.domain:5060 Action export(call_direction=inbound) INLINE
EXECUTE [depth=0] sofia/internal/11264@att.local.domain:5060 export(call_direction=inbound)
2021-07-12 15:07:43.534144 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [call_direction]=[inbound]
Dialplan: sofia/internal/11264@att.local.domain:5060 Action set(caller_destination=${sip_to_user}) INLINE
EXECUTE [depth=0] sofia/internal/11264@att.local.domain:5060 set(caller_destination=97135554444)
2021-07-12 15:07:43.534144 [DEBUG] mod_dptools.c:1685 SET sofia/internal/11264@att.local.domain:5060 [caller_destination]=[97135554444]
Dialplan: sofia/internal/11264@att.local.domain:5060 Action set(caller_id_name=${caller_id_name}) INLINE
EXECUTE [depth=0] sofia/internal/11264@att.local.domain:5060 set(caller_id_name=First Last)
2021-07-12 15:07:43.534144 [DEBUG] mod_dptools.c:1685 SET sofia/internal/11264@att.local.domain:5060 [caller_id_name]=[First Last]
Dialplan: sofia/internal/11264@att.local.domain:5060 Action set(caller_id_number=${caller_id_number})
Dialplan: sofia/internal/11264@att.local.domain:5060 parsing [public->8324445555] continue=false
Dialplan: sofia/internal/11264@att.local.domain:5060 Regex (FAIL) [8324445555] destination_number(97135554444) =~ /^\+?1?(8324445555)$/ break=on-false
Dialplan: sofia/internal/11264@att.local.domain:5060 parsing [public->not-found] continue=false
Dialplan: sofia/internal/11264@att.local.domain:5060 Regex (PASS) [not-found] () =~ // break=on-false
Dialplan: sofia/internal/11264@att.local.domain:5060 Action set(call_direction=inbound) INLINE
EXECUTE [depth=0] sofia/internal/11264@att.local.domain:5060 set(call_direction=inbound)
2021-07-12 15:07:43.534144 [DEBUG] mod_dptools.c:1685 SET sofia/internal/11264@att.local.domain:5060 [call_direction]=[inbound]
Dialplan: sofia/internal/11264@att.local.domain:5060 Action log(WARNING [inbound routes] 404 not found ${sip_network_ip})
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:287 (sofia/internal/11264@att.local.domain:5060) State Change CS_ROUTING -> CS_EXECUTE
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/11264@att.local.domain:5060) State ROUTING going to sleep
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/11264@att.local.domain:5060) Running State Change CS_EXECUTE (Cur 1 Tot 219)
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/11264@att.local.domain:5060) State EXECUTE
2021-07-12 15:07:43.534144 [DEBUG] mod_sofia.c:209 sofia/internal/11264@att.local.domain:5060 SOFIA EXECUTE
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:329 sofia/internal/11264@att.local.domain:5060 Standard EXECUTE
EXECUTE [depth=0] sofia/internal/11264@att.local.domain:5060 set(caller_id_number=11264)
2021-07-12 15:07:43.534144 [DEBUG] mod_dptools.c:1685 SET sofia/internal/11264@att.local.domain:5060 [caller_id_number]=[11264]
EXECUTE [depth=0] sofia/internal/11264@att.local.domain:5060 log(WARNING [inbound routes] 404 not found phone.client.ip.address)
2021-07-12 15:07:43.534144 [WARNING] mod_dptools.c:1879 [inbound routes] 404 not found phone.client.ip.address
2021-07-12 15:07:43.534144 [NOTICE] switch_core_state_machine.c:386 sofia/internal/11264@att.local.domain:5060 has executed the last dialplan instruction, hanging up.
2021-07-12 15:07:43.534144 [NOTICE] switch_core_state_machine.c:388 Hangup sofia/internal/11264@att.local.domain:5060 [CS_EXECUTE] [NORMAL_CLEARING]
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/11264@att.local.domain:5060) State EXECUTE going to sleep
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/11264@att.local.domain:5060) Running State Change CS_HANGUP (Cur 1 Tot 219)
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:848 (sofia/internal/11264@att.local.domain:5060) Callstate Change RINGING -> HANGUP
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/11264@att.local.domain:5060) State HANGUP
2021-07-12 15:07:43.534144 [DEBUG] mod_sofia.c:453 Channel sofia/internal/11264@att.local.domain:5060 hanging up, cause: NORMAL_CLEARING
2021-07-12 15:07:43.534144 [DEBUG] mod_sofia.c:598 Responding to INVITE with: 480
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:60 sofia/internal/11264@att.local.domain:5060 Standard HANGUP, cause: NORMAL_CLEARING
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/11264@att.local.domain:5060) State HANGUP going to sleep
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:620 (sofia/internal/11264@att.local.domain:5060) State Change CS_HANGUP -> CS_REPORTING
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/11264@att.local.domain:5060) Running State Change CS_REPORTING (Cur 1 Tot 219)
2021-07-12 15:07:43.534144 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/11264@att.local.domain:5060) State REPORTING
2021-07-12 15:07:43.594141 [DEBUG] switch_core_state_machine.c:174 sofia/internal/11264@att.local.domain:5060 Standard REPORTING, cause: NORMAL_CLEARING
2021-07-12 15:07:43.594141 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/11264@att.local.domain:5060) State REPORTING going to sleep
2021-07-12 15:07:43.594141 [DEBUG] switch_core_state_machine.c:611 (sofia/internal/11264@att.local.domain:5060) State Change CS_REPORTING -> CS_DESTROY
2021-07-12 15:07:43.594141 [DEBUG] switch_core_session.c:1736 Session 219 (sofia/internal/11264@att.local.domain:5060) Locked, Waiting on external entities
2021-07-12 15:07:43.594141 [NOTICE] switch_core_session.c:1754 Session 219 (sofia/internal/11264@att.local.domain:5060) Ended
2021-07-12 15:07:43.594141 [NOTICE] switch_core_session.c:1758 Close Channel sofia/internal/11264@att.local.domain:5060 [CS_DESTROY]
2021-07-12 15:07:43.594141 [DEBUG] switch_core_state_machine.c:739 (sofia/internal/11264@att.local.domain:5060) Running State Change CS_DESTROY (Cur 0 Tot 219)
2021-07-12 15:07:43.594141 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/11264@att.local.domain:5060) State DESTROY
2021-07-12 15:07:43.594141 [DEBUG] mod_sofia.c:364 sofia/internal/11264@att.local.domain:5060 SOFIA DESTROY
2021-07-12 15:07:43.594141 [DEBUG] switch_core_state_machine.c:181 sofia/internal/11264@att.local.domain:5060 Standard DESTROY
2021-07-12 15:07:43.594141 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/11264@att.local.domain:5060) State DESTROY going to sleep
The outbound route ends with the following:
That is our local asterisk gateway at the top, although it never gets there. When I had ACL set to deny with an allow for asterisk, I think the reverse was the case (inbound broken, outbound working).
FWIW, the only reason I mentioned the home setup and VOIP.ms is that I appear to have made it down the same rabbit hole there.
Once again, asking for help is the quickest way to fix it yourself. I simply re-enabled ACL with default deny and a single allow for the upstream asterisk server ip/32 and left the right side blank. Inbound and outbound are both working now.
I don't think you want to do that, only your carriers advertised IP Addresses. Your internal extensions are going to end up using the wrong context otherwise.
