Strange behavior port forwarding 5060
ChrisLab
32
Morning All.
Thanks admin for account approval.
I've got Fusionpbx behind nat.
I want to register phones from outside. When I port forward 5060, I can register phone, no problem.
Next I want to register trunk to provider. Registration fails.
If I disable port forward 5060, Gateway registers, and phone registration fails.
Forward 5060 again, phone registers & Gateway fails.
Has anyone else had this before, or can someone please point me in the right direction.
Please let me know what additional info I can provide.
Thanks!
I run one of my boxes behind NAT with no issues
Make sure that you have SIP ALG disabled on the router, as that will just cause you pain.
Mine is also on MT with dstnat rules
5060-5069 TCP
5060-5090,10000-32768 UDP
External registrations such as Groundwire show up as eg 95060
In Variables have you set your public ip address in
external_rtp_ip
external_sip_ip
I've only got port fwd 5060 UDP & the rtp ports.
I'll try now as you've got them.
In Variables I've set both to host:FQDN as i've got dynamic public IP, and it resolves when looking at profile status.
Let me test above port forwarding and get back.
Thanks!
Hi Glennbtn.
I tried above port forwarding rules. Same results.
As soon as I enable rule, phone registers, & gateway registration drops.
Disable rule > phone registration drops & gateway registers OK.
Lost here.
To be honest this smells of SIP ALG where 1 item would registered with 5060 then when the next device registers, it knocks off the previously registered device.
SIP ALG definitely disabled.
As I see it, 5060 needs to be port forwarded to get external phones registered.
Question is, why does Gateway registration drop as soon as 5060 gets forwarded?
Are these set as dstnat and not srcnat
If so I am also at a loss as have many site pbx's setup behind MT routers with no issues
Post some logs when doing the forwarding, preferably using sngrep of the attempt to register to the provider.
Hi Daz.
I attached 2 screenshots.
The 1st one is where 5060 is forwarded & trunk doesn't register.
I left it running & disable port forward, and after a few seconds, trunk registers. (2nd Pic).
I hope this info helps.
Thanks!
We need the detail not a picture. Inside the register press F6 and paste that.
Hi Daz,
Sorry about that, still learning..
Please find screenshot attached.
I hope I didn't hide to many details....
Just another thing, I rebooted the server before the attached sngrep, and noticed that my internal & external profiles didn't load.
I checked freeswitch log and found:
[ERR] sofia.c:3296 Error Creating SIP UA for profile: external (sip:mod_sofia@:5080;maddr=192.168.0.99;transport=udp,tcp)
[ERR] sofia.c:3307 Error Creating SIP UA for profile: internal (sip:mod_sofia@:5060;maddr=192.168.0.99;transport=udp,tcp)
The likely causes for this are:
1) Another application is already listening on the specified address.
2) The IP the profile is attempting to bind to is not local to this system.
Started OK manually.
I don't know if this has something to do with whats happening.
Hi All.
I got my problem resolved by setting my 5060 port forward to my WAN interface only.
Don't know If this is two wrongs to make a right, but everything is working as expected.
Thanks for all the input.
