UDP port Operation not permitted
weihsin2002
I am using the fs_cli command to originate a call to a media server. However I am receiving the 503 Service Unavailable. I have checked the media server listening on port 5060. I am able to use sip client to send the invite. Can you help me understand why when using the originate command it failed?
Thanks. Here is the log.
2021-06-13 22:08:10.682603 [DEBUG] switch_core_state_machine.c:585 (sofia/external/PaymentIVR2-34117) Running State Change CS_CONSUME_MEDIA (Cur 1 Tot 29)
soa_static.c:1028 soa_sdp_mode_set() soa_sdp_mode_set(0x7f1347ffc5c0, (nil), ""): called
soa_static.c:1445 offer_answer_step() soa_static(0x7f133c0412b0, soa_generate_offer): storing local description
soa.c:1268 soa_get_local_sdp() soa_get_local_sdp(static::0x7f133c0412b0, [(nil)], [0x7f1347ffe720], [0x7f1347ffe718]) called
2021-06-13 22:08:10.682603 [DEBUG] switch_core_state_machine.c:663 (sofia/external/PaymentIVR2-34117) State CONSUME_MEDIA
nta.c:2694 nta_tpn_by_url() nta: selecting scheme sip
2021-06-13 22:08:10.682603 [DEBUG] switch_core_state_machine.c:663 (sofia/external/PaymentIVR2-34117) State CONSUME_MEDIA going to sleep
tport.c:3285 tport_tsend() tport_tsend(0x7f133c004e80) tpn = UDP/10.201.21.140:5060
tport.c:4071 tport_resolve() tport_resolve addrinfo = 10.201.21.140:5060
tport.c:4708 tport_by_addrinfo() tport_by_addrinfo(0x7f133c004e80): not found by name UDP/10.201.21.140:5060
tport.c:3663 tport_send_fatal() tport_vsend(0x7f133c004e80): Operation not permitted with (s=35 UDP/10.201.21.140:5060)
tport.c:3521 tport_send_msg() tport_vsend returned -1
nta.c:8542 outgoing_print_tport_error() nta: INVITE (37269853): Operation not permitted (1) with UDP/[10.201.21.140]:5060
nua_session.c:4135 signal_call_state_change() nua(0x7f136c038fd0): call state changed: init -> calling, sent offer
soa.c:1268 soa_get_local_sdp() soa_get_local_sdp(static::0x7f133c0412b0, [0x7f1347ffe730], [0x7f1347ffe738], [(nil)]) called
nua_stack.c:269 nua_stack_event() nua(0x7f136c038fd0): event i_state INVITE sent
nua_stack.c:359 nua_application_event() nua: nua_application_event: entering
nua_stack.c:271 nua_stack_event() nua(0x7f136c038fd0): event r_invite 503 Service Unavailable
nua_session.c:4135 signal_call_state_change() nua(0x7f136c038fd0): call state changed: calling -> init
nua_stack.c:271 nua_stack_event() nua(0x7f136c038fd0): event i_state 503 Service Unavailable
nua_stack.c:271 nua_stack_event() nua(0x7f136c038fd0): event i_terminated 503 Service Unavailable
Wayne
