I really have problems understanding the upgrade process of FusionPBX.
What exactly are the steps (one by one) that are needed:
							 docs.fusionpbx.com
					docs.fusionpbx.com
That mix of GIT and GUI is confusing. Do you need to do both?
Then here: https://docs.fusionpbx.com/en/latest/advanced/version_upgrade.html#version-4-2-to-4-4
I mean who remembers every little setting he did over the years?
I have to delete all Dialplans to then create new ones (making notes of them before that)?
I also need to move FusionPBX to a new machine with Buster.
What are the steps for that?
Even the Jessi update does not work because i get:
I cant remember that i did add packages.sury.org to the sources and that site does not have Jessi anymore.
Here is my current status:
Upgrade — FusionPBX Docs documentation
How do I know if there are customized scripts?Any customized scripts, having the same name as the default scripts, will be overwritten.
???If your config.lua file was located in scripts/resources/, then you’ll need to restore it (from the backup previously performed) to scripts/resources/config.lua.
andIf you have made any changes to these make notes on the changes before you delete them.
I don't know if there are any changes and does it mean you have to go through 1 million pages and settings in the GUI and note everything (screenshots)?Update these Dialplans by first selecting and deleting their entries from within the Dialplan Manager for all domains.
	~$ apt update
W: Failed to fetch https://packages.sury.org/php/dists/jessie/main/binary-amd64/Packages  HttpError404
E: Some index files failed to download. They have been ignored, or old ones used instead.Here is my current status:
