Voicemail Issue
Frank
61
When setting the language to anything but English and I try accessing my voicemail via *97 it immediately returns 'code entered is incorrect'. It does not ask me to enter the code.
Worst part about this is that I fixed it once but I cannot remember how.
Any Ideas?
HI,
I have this problem too. @Frank you solved your problem?
Freeswitch: 1.6.20 (64bit)
FusionPBX: 4.4.0
Debian: 9.4
freeswitch@fusionpbx> console loglevel 6
+OK log level 6 [6]
+OK console log level set to INFO
2018-04-10 16:13:55.931215 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/1200@192.168.2.110 [3a58ab8b-c70d-42de-984f-942f1aaa2a46]
2018-04-10 16:13:55.931215 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [*97@192.168.2.110] from ip 192.168.0.5
2018-04-10 16:13:55.971242 [INFO] mod_dialplan_xml.c:637 Processing 1200 <1200>->*97 in context 192.168.2.110
2018-04-10 16:13:56.011243 [NOTICE] mod_dptools.c:1352 Channel [sofia/internal/1200@192.168.2.110] has been answered
2018-04-10 16:13:57.071228 [INFO] switch_ivr_async.c:4172 UnBound A-Leg: ALL
2018-04-10 16:13:57.131231 [ERR] switch_xml.c:3174 Can't find language pt.
2018-04-10 16:13:57.151218 [ERR] switch_xml.c:3174 Can't find language pt.
2018-04-10 16:14:00.071216 [NOTICE] sofia.c:1079 Hangup sofia/internal/1200@192.168.2.110 [CS_EXECUTE] [NORMAL_CLEARING]
2018-04-10 16:14:00.151229 [NOTICE] switch_core_session.c:1731 Session 18 (sofia/internal/1200@192.168.2.110) Ended
2018-04-10 16:14:00.151229 [NOTICE] switch_core_session.c:1735 Close Channel sofia/internal/1200@192.168.2.110 [CS_DESTROY]
Hello can anybdoy help me ? I got the same problem, bellow you have a DEBUG .
2018-06-08 10:30:57.235273 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/8048@fusion.nipvox.com.br:5060 [7ebc32f0-cfa0-4832-b835-167a4ee3943c]
2018-06-08 10:30:57.235273 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/8048@fusion.nipvox.com.br:5060) Running State Change CS_NEW (Cur 1 Tot 176)
2018-06-08 10:30:57.235273 [DEBUG] sofia.c:9873 sofia/internal/8048@fusion.nipvox.com.br:5060 receiving invite from 172.25.1.49:5060 version: 1.6.20 -37-987c9b9 64bit
2018-06-08 10:30:57.235273 [DEBUG] sofia.c:10044 IP 172.25.1.49 Rejected by acl "domains". Falling back to Digest auth.
2018-06-08 10:30:57.235273 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [*97@fusion.nipvox.com.br] from ip 172.25.1.49
2018-06-08 10:30:57.235273 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/8048@fusion.nipvox.com.br:5060) State NEW
2018-06-08 10:30:57.235273 [DEBUG] sofia.c:2334 detaching session 7ebc32f0-cfa0-4832-b835-167a4ee3943c
2018-06-08 10:30:57.255244 [DEBUG] sofia.c:2442 Re-attaching to session 7ebc32f0-cfa0-4832-b835-167a4ee3943c
2018-06-08 10:30:57.255244 [DEBUG] sofia.c:9873 sofia/internal/8048@fusion.nipvox.com.br:5060 receiving invite from 172.25.1.49:5060 version: 1.6.20 -37-987c9b9 64bit
2018-06-08 10:30:57.255244 [DEBUG] sofia.c:10044 IP 172.25.1.49 Rejected by acl "domains". Falling back to Digest auth.
2018-06-08 10:30:57.275262 [DEBUG] sofia.c:7084 Channel sofia/internal/8048@fusion.nipvox.com.br:5060 entering state [received][100]
2018-06-08 10:30:57.275262 [DEBUG] sofia.c:7094 Remote SDP:
v=0
o=- 20038 20038 IN IP4 172.25.1.49
s=SDP data
c=IN IP4 172.25.1.49
t=0 0
m=audio 12476 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-15
a=ptime:20
2018-06-08 10:30:57.275262 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-06-08 10:30:57.275262 [DEBUG] switch_core_media.c:4504 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2018-06-08 10:30:57.275262 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-06-08 10:30:57.275262 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2018-06-08 10:30:57.275262 [DEBUG] switch_core_media.c:4449 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[GSM:3:8000:20:13200:1]
2018-06-08 10:30:57.275262 [DEBUG] switch_core_media.c:4365 Set telephone-event payload to 101@8000
2018-06-08 10:30:57.275262 [DEBUG] switch_core_media.c:3061 Set Codec sofia/internal/8048@fusion.nipvox.com.br:5060 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
2018-06-08 10:30:57.275262 [DEBUG] switch_core_codec.c:111 sofia/internal/8048@fusion.nipvox.com.br:5060 Original read codec set to PCMU:0
2018-06-08 10:30:57.275262 [DEBUG] switch_core_media.c:4708 Set telephone-event payload to 101@8000
2018-06-08 10:30:57.275262 [DEBUG] switch_core_media.c:4767 sofia/internal/8048@fusion.nipvox.com.br:5060 Set 2833 dtmf send payload to 101 recv payload to 101
2018-06-08 10:30:57.275262 [DEBUG] sofia.c:7507 (sofia/internal/8048@fusion.nipvox.com.br:5060) State Change CS_NEW -> CS_INIT
2018-06-08 10:30:57.275262 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/8048@fusion.nipvox.com.br:5060) Running State Change CS_INIT (Cur 1 Tot 176)
2018-06-08 10:30:57.275262 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/8048@fusion.nipvox.com.br:5060) State INIT
2018-06-08 10:30:57.275262 [DEBUG] mod_sofia.c:90 sofia/internal/8048@fusion.nipvox.com.br:5060 SOFIA INIT
2018-06-08 10:30:57.275262 [DEBUG] switch_core_state_machine.c:40 sofia/internal/8048@fusion.nipvox.com.br:5060 Standard INIT
2018-06-08 10:30:57.275262 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/8048@fusion.nipvox.com.br:5060) State Change CS_INIT -> CS_ROUTING
2018-06-08 10:30:57.275262 [DEBUG] switch_core_state_machine.c:627 (sofia/internal/8048@fusion.nipvox.com.br:5060) State INIT going to sleep
2018-06-08 10:30:57.275262 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/8048@fusion.nipvox.com.br:5060) Running State Change CS_ROUTING (Cur 1 Tot 176)
2018-06-08 10:30:57.275262 [DEBUG] switch_channel.c:2249 (sofia/internal/8048@fusion.nipvox.com.br:5060) Callstate Change DOWN -> RINGING
2018-06-08 10:30:57.275262 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/8048@fusion.nipvox.com.br:5060) State ROUTING
2018-06-08 10:30:57.275262 [DEBUG] mod_sofia.c:143 sofia/internal/8048@fusion.nipvox.com.br:5060 SOFIA ROUTING
2018-06-08 10:30:57.275262 [DEBUG] switch_core_state_machine.c:236 sofia/internal/8048@fusion.nipvox.com.br:5060 Standard ROUTING
2018-06-08 10:30:57.275262 [INFO] mod_dialplan_xml.c:637 Processing 8048 <8048>->*97 in context fusion.nipvox.com.br
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->user_exists] continue=true
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [user_exists] () =~ // break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(user_exists=false)
2018-06-08 10:30:57.295259 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [user_exists]=[false]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->caller-details] continue=true
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(caller_destination=${destination_number}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(caller_destination=*97)
2018-06-08 10:30:57.295259 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [caller_destination]=[*97]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(caller_id_name=${caller_id_name}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(caller_id_name=8048)
2018-06-08 10:30:57.295259 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [caller_id_name]=[8048]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(caller_id_number=${caller_id_number}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(caller_id_number=8048)
2018-06-08 10:30:57.295259 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [caller_id_number]=[8048]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->variables] continue=true
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [variables] () =~ // break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action export(origination_callee_id_name=${destination_number})
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->call-direction] continue=true
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 ANTI-Action set(call_direction=local)
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->is_local] continue=true
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [is_local] ${user_exists}(false) =~ /false/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action lua(app.lua is_local)
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->user_record] continue=true
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [user_record] () =~ // break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(user_record=${user_data ${destination_number}@${domain_name} var user_record}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(user_record=)
2018-06-08 10:30:57.315261 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [user_record]=[UNDEF]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(from_user_exists=true)
2018-06-08 10:30:57.315261 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [from_user_exists]=[true]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${call_direction}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${call_direction}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${call_direction}() =~ /^local$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(from_user_record=)
2018-06-08 10:30:57.335261 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [from_user_record]=[UNDEF]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->redial] continue=true
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [redial] destination_number(*97) =~ /^(redial|\*870)$/ break=on-true
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [redial] () =~ // break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->speed_dial] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [speed_dial] destination_number(*97) =~ /^\*0(.*)$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->default_caller_id] continue=true
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(emergency_caller_id_name=)
2018-06-08 10:30:57.335261 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [emergency_caller_id_name]=[UNDEF]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(emergency_caller_id_number=)
2018-06-08 10:30:57.335261 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [emergency_caller_id_number]=[UNDEF]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(outbound_caller_id_name=)
2018-06-08 10:30:57.335261 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [outbound_caller_id_name]=[UNDEF]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(outbound_caller_id_number=)
2018-06-08 10:30:57.335261 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [outbound_caller_id_number]=[UNDEF]
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->SipPulse.8d] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [SipPulse.8d] ${user_exists}(false) =~ /false/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [SipPulse.8d] destination_number(*97) =~ /^(\d{8,12})$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->agent_status] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [agent_status] destination_number(*97) =~ /^\*22$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->agent_status_id] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [agent_status_id] destination_number(*97) =~ /^\*23$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->NOC_SUPORTE] continue=
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [NOC_SUPORTE] destination_number(*97) =~ /^([^#]+#)(.*)$/ break=never
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [NOC_SUPORTE] destination_number(*97) =~ /^8049$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->group-intercept] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [group-intercept] destination_number(*97) =~ /^\*8$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->page-extension] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [page-extension] destination_number(*97) =~ /^\*8(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->eavesdrop] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [eavesdrop] destination_number(*97) =~ /^\*33(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->call_privacy] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [call_privacy] destination_number(*97) =~ /^\*67(\d+)$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->call_return] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [call_return] destination_number(*97) =~ /^\*69$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->intercept-ext-polycom] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [intercept-ext-polycom] destination_number(*97) =~ /^\*97(\d+)$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->extension_queue] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [extension_queue] destination_number(*97) =~ /^\*800(.*)$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->intercept-ext] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [intercept-ext] destination_number(*97) =~ /^\*\*(\d+)$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->dx] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [dx] destination_number(*97) =~ /^dx$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->extension-to-voicemail] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [extension-to-voicemail] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->send_to_voicemail] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [send_to_voicemail] destination_number(*97) =~ /^\*99(\d{2,10})$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->att_xfer] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [att_xfer] destination_number(*97) =~ /^att_xfer$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->vmain] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [vmain] destination_number(*97) =~ /^vmain$|^\*4000$|^\*98$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->xfer_vm] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [xfer_vm] destination_number(*97) =~ /^xfer_vm$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->is_transfer] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (FAIL) [is_transfer] destination_number(*97) =~ /^is_transfer$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 parsing [fusion.nipvox.com.br->vmain_user] continue=false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Regex (PASS) [vmain_user] destination_number(*97) =~ /^\*97$/ break=on-false
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action answer()
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action sleep(1000)
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(voicemail_action=check)
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(voicemail_id=${caller_id_number})
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action set(voicemail_profile=default)
Dialplan: sofia/internal/8048@fusion.nipvox.com.br:5060 Action lua(app.lua voicemail)
2018-06-08 10:30:57.335261 [DEBUG] switch_core_state_machine.c:286 (sofia/internal/8048@fusion.nipvox.com.br:5060) State Change CS_ROUTING -> CS_EXECUTE
2018-06-08 10:30:57.335261 [DEBUG] switch_core_state_machine.c:643 (sofia/internal/8048@fusion.nipvox.com.br:5060) State ROUTING going to sleep
2018-06-08 10:30:57.335261 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/8048@fusion.nipvox.com.br:5060) Running State Change CS_EXECUTE (Cur 1 Tot 176)
2018-06-08 10:30:57.335261 [DEBUG] switch_core_state_machine.c:650 (sofia/internal/8048@fusion.nipvox.com.br:5060) State EXECUTE
2018-06-08 10:30:57.335261 [DEBUG] mod_sofia.c:198 sofia/internal/8048@fusion.nipvox.com.br:5060 SOFIA EXECUTE
2018-06-08 10:30:57.335261 [DEBUG] switch_core_state_machine.c:328 sofia/internal/8048@fusion.nipvox.com.br:5060 Standard EXECUTE
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 export(origination_callee_id_name=*97)
2018-06-08 10:30:57.335261 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [origination_callee_id_name]=[*97]
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(RFC2822_DATE=Fri, 08 Jun 2018 10:30:57 -0300)
2018-06-08 10:30:57.335261 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [RFC2822_DATE]=[Fri, 08 Jun 2018 10:30:57 -0300]
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(call_direction=local)
2018-06-08 10:30:57.335261 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [call_direction]=[local]
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 lua(app.lua is_local)
2018-06-08 10:30:57.355282 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7f4914063d40 Connected.
2018-06-08 10:30:57.355282 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7f4914063d40 released.
2018-06-08 10:30:57.355282 [DEBUG] switch_cpp.cpp:1112 sofia/internal/8048@fusion.nipvox.com.br:5060 destroy/unlink session from object
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 hash(insert/fusion.nipvox.com.br-last_dial/8048/*97)
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 answer()
2018-06-08 10:30:57.375243 [DEBUG] switch_core_media.c:6878 AUDIO RTP [sofia/internal/8048@fusion.nipvox.com.br:5060] 200.220.135.75 port 26688 -> 172.25.1.49 port 12476 codec: 0 ms: 20
2018-06-08 10:30:57.375243 [DEBUG] switch_rtp.c:4137 Starting timer [soft] 160 bytes per 20ms
2018-06-08 10:30:57.375243 [DEBUG] switch_core_media.c:7180 sofia/internal/8048@fusion.nipvox.com.br:5060 Set 2833 dtmf send payload to 101
2018-06-08 10:30:57.375243 [DEBUG] switch_core_media.c:7187 sofia/internal/8048@fusion.nipvox.com.br:5060 Set 2833 dtmf receive payload to 101
2018-06-08 10:30:57.375243 [DEBUG] switch_core_media.c:7210 sofia/internal/8048@fusion.nipvox.com.br:5060 Set rtp dtmf delay to 40
2018-06-08 10:30:57.375243 [DEBUG] mod_sofia.c:850 Local SDP sofia/internal/8048@fusion.nipvox.com.br:5060:
v=0
o=FreeSWITCH 1528437969 1528437970 IN IP4 200.220.135.75
s=FreeSWITCH
c=IN IP4 200.220.135.75
t=0 0
m=audio 26688 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
2018-06-08 10:30:57.375243 [NOTICE] mod_dptools.c:1312 Channel [sofia/internal/8048@fusion.nipvox.com.br:5060] has been answered
2018-06-08 10:30:57.375243 [DEBUG] switch_channel.c:3773 (sofia/internal/8048@fusion.nipvox.com.br:5060) Callstate Change RINGING -> ACTIVE
2018-06-08 10:30:57.375243 [DEBUG] sofia.c:7084 Channel sofia/internal/8048@fusion.nipvox.com.br:5060 entering state [completed][200]
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 sleep(1000)
2018-06-08 10:30:57.395233 [DEBUG] sofia.c:7084 Channel sofia/internal/8048@fusion.nipvox.com.br:5060 entering state [ready][200]
2018-06-08 10:30:57.515235 [DEBUG] switch_rtp.c:7308 Correct audio ip/port confirmed.
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(voicemail_action=check)
2018-06-08 10:30:58.375273 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [voicemail_action]=[check]
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(voicemail_id=8048)
2018-06-08 10:30:58.375273 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [voicemail_id]=[8048]
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 set(voicemail_profile=default)
2018-06-08 10:30:58.375273 [DEBUG] mod_dptools.c:1548 SET sofia/internal/8048@fusion.nipvox.com.br:5060 [voicemail_profile]=[default]
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 lua(app.lua voicemail)
2018-06-08 10:30:58.375273 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7f4914063d40 Connected.
EXECUTE sofia/internal/8048@fusion.nipvox.com.br:5060 unbind_meta_app()
2018-06-08 10:30:59.395271 [INFO] switch_ivr_async.c:4072 UnBound A-Leg: ALL
2018-06-08 10:30:59.395271 [DEBUG] switch_cpp.cpp:745 CoreSession::setVariable('playback_terminators', '#')
2018-06-08 10:30:59.395271 [DEBUG] switch_ivr_play_say.c:70 No language specified - Using [pt]
2018-06-08 10:30:59.435252 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7f491415baa0 Connected.
2018-06-08 10:30:59.435252 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7f491415baa0 released.
2018-06-08 10:30:59.435252 [ERR] switch_xml.c:3174 Can't find language pt.
2018-06-08 10:30:59.435252 [DEBUG] switch_ivr_play_say.c:70 No language specified - Using [pt]
2018-06-08 10:30:59.455350 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7f491415baa0 Connected.
2018-06-08 10:30:59.455350 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7f491415baa0 released.
2018-06-08 10:30:59.455350 [ERR] switch_xml.c:3174 Can't find language pt.
2018-06-08 10:30:59.455350 [DEBUG] switch_ivr_play_say.c:70 No language specified - Using [pt]
2018-06-08 10:30:59.475314 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7f491415baa0 Connected.
2018-06-08 10:30:59.475314 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7f491415baa0 released.
2018-06-08 10:30:59.475314 [ERR] switch_xml.c:3174 Can't find language pt.
2018-06-08 10:30:59.475314 [DEBUG] switch_core_file.c:342 File /usr/share/freeswitch/sounds/pt/BR/karina/voicemail/vm-fail_auth.wav sample rate 48000 doesn't match requested rate 8000
2018-06-08 10:30:59.475314 [DEBUG] switch_ivr_play_say.c:1498 Codec Activated L16@8000hz 1 channels 20ms
Digidaz, thx for your interest, I had same issue like this error:
Problem was language not defined on /etc/freeswitch/freeswitch.xml under language section.
Hope this helps anyone.
Regards,
Once your language is present in that /etc/freeswitch/freeswitch.xml list,
if you have changed the Voice (like using recorded files from somewhere else),
you must have edited Advanced > Variables > sound_prefix,
but this new value won't be recognised under /etc/freeswitch/languages/pt/pt.xml,
therefore you must modify that file like this (substitute pt for your particular case if needed):
<include>
        <language name="pt" say-module="pt" sound-prefix="$${sound_prefix}" tts-engine="cepstra" tts-voice="david">
@markjcrane This bug exists since at least two years ago, but it is trivial to be fixed.
Reactions: porrivmi
<include>
Mark how i could fix this issue?
