Voicemail Transcription issue
Mikeme
200
hi guys,
having a problem with voicemail transcription with google API when trying to run this option first time.
i set up:
google_key: MY_KEY
google_url: https://speech.googleapis.com/v1p1beta1/speech
transcribe_language: en-US
transcribe_provider: google
transcribe_enabled: enable
transcription_enabled_default: true
and enabled voicemail transcription to extension.
once leaving a message I'm getting an email with all the details and the word "Transcription" without any text of the message in the end of the email.
also checked the log fs_cli and there is no mention about transcription process once i leave message.
i have read Transcription guide and run some searches in forum and seems like all setting are correct.
i also double check my google account API running well using https://texttospeech.googleapis.com/v1/voices?key=MY_KEY with no problem.
System version: 5.0.3
Anyone has the same issue?
hi guys,
i set up:
google_key: MY_KEY
Unfortunately no one has responded to me yet. I am stuck on same issue. If you solve this, kindly share the solution with me too.
I have even tried Azure API. same issue with that too.
Well I hope someone will help us.
I think it might be something with lua script or something like that.
Any help will be appreciated!
Try adding transcribe_alternate_language = es (or any other language you’d like). I believe that value needs to be filled in order for google to work
