WARNING: [pool www] server reached pm.max_children setting (5), consider raising it
rubberducky
55
19
A question was posted in IRC, so I'm posting the fix we had here in case anyone else needs it as well. Credit for this fix goes to my team, I had nothing to do with it.
Calculating Pool Size​
If you are seeing warnings that max child pool size has been reached we may want to increase pool size to improve performance.
First we must ensure that there is sufficient free memory when the switch is under load to give to php-fpm.
Once you establish the amount of memory available, check the average size of the current pools
ps -eo size,pid,user,command --sort -size | awk '{ hr=$1/1024 ; printf("%13.2f Mb ",hr) } { for ( x=4 ; x<=NF ; x++ ) { printf("%s ",$x) } print "" }' | grep php-fpm
You may get output like this
The average pool size is roughly 7MB, if you have 2GB available then you would calculate 2000 / 7 which would give about 285.
The config file is located in /etc/php/7.3/fpm/pool.d/www.conf
Edit the conf file according and restart php-fpm service
Reactions: DigitalDaz and Dan
