There are guides about this but they are old and different from each other and none of them worked with current version.
One of them being this:
www.pbxforums.com
The other being this:
Following the commenters' advices and these guides, I still can't make it work. Any ideas how to make it possible? All our clients are connected via TLS-NAT, only one with TCP and one with TLS without NAT. So it is actually vital to be able to diagnose SIP problems with TLS.
Enable TLS debugging with SNGREP
Thanks to a guy called TomP over at https://www.tomp.uk/2019/02/freeswitch-sip-capture-over-tls-with-sngrep-and-hep/ for this solution. nano -w /usr/share/freeswitch/scripts/app/xml_handler/resources/scripts/configuration/sofia.conf.lua Change the line from: --table.insert(xml, [[...
