Yealink RPS Provisioning URL Multi tenant
Methodz86
47
Hi All,
As most of us would take advantage of Yealink RPS service, it works very good and never had an issue. I have a perfectly functional FusionPBX instance running with about 45 tenants/domains so far and have been creating a new Server in RPS for each tenant.
My question is, can I just have a single server in Yealink RPS to attach all my devices and still have FusionPBX filter it out correctly for the correct tenant/domain? I'm sure it's probably easy, but just wanted to get a feel for what others out there doing or any good recommendations or any pro's / con's. - Thanks.
Fusion PBX 4.4.3
Freeswitch 1.8.7
Debian 9.9
Reactions: JamesBorne
197
If you turn off "http_domain_filter" in default settings, you can send all devices in RPS to a single server as long as your http_auth settings are the same between all domains on the server.
Pro, easier to configure new phones
Con, less secure. harder to determine where a phone belongs after it is in the wild, etc.
Personally I don't think the security aspect is high risk for much real danger, but I do prefer to set each batch of phones to a specific customer/domain in RPS,GAPS,ZTP, etc to have another point of record for any devices we have sold/provisioned. We also set different user/passwords for each domain's provisioning access for added security.
roger_roger
198
19
I am not able get the rps to point to my fusionpbx. which works with auto provision if I set them in the phone. If that make
my office number 209-370-1930
A snip of your RPS config would be helpful. However, I suggest you start a new thread for this instead of hijacking this one.
