407 Proxy Authentication R
MORAES
12
Good evening guys, how are you ?
Did anyone when installing fusion PBX have any difficulties with incoming calls?
I made two fusionpbx one installed with debian and the other ubuntu.
I made all the input and saint settings. the same works to leave the call, it works to connect between extensions but does not work on the incoming route.
attached is the printout
It is not a firewall as it is open and I have also validated this entry. drifts normally.
I believe there is some configuration parameter missing or there is a bug that I don't know about
MORAES
12
Thank you very much my friend, that was exactly it, I discovered it a few minutes before you answered me. I had deleted the providers and created a specific one, I changed the point to the rule I created and it worked
