480 Temporarily Unavailable
cyprusvoip
27
Hey guys
I haven't use my experimental pbx for few days and today i started working on it again and i keep getting this error 480 Temporarily Unavailable on all my calls both external and internal.Any ideas?Any help will be appreciated.I had this issue few weeks back and couldnt resolve it so i have done a new clean install but this time i want to fix it somehow.
Some sort of log would be helpful, it could be absolutely anything.
cyprusvoip
27
this is what i get a complete log file from a call
INVITE sip:100@192.168.10.242 SIP/2.0
Via: SIP/2.0/TCP 192.168.10.43:57549;branch=z9hG4bK-524287-1---1e2e046781e24f 50;rport
Max-Forwards: 70
Contact: <sip:101@192.168.10.43:57580;rinstance=7e36b9c365f6f298;transport=tc p>
To: <sip:100@192.168.10.242>
Call-ID: 89322Mjg2YTQyYjcyMWE3ZjY4YTQ2MWRkMTBmMDQ3YTkzM2I
CSeq: 1 INVITE
Allow: SUBSCRIBE, NOTIFY, INVITE, ACK, CANCEL, BYE, REFER, INFO, OPTIONS, MES SAGE
Content-Type: application/sdp
Supported: replaces
User-Agent: X-Lite release 5.1.0 stamp 89322
Content-Length: 336
v=0
o=- 13164672648080945 1 IN IP4 192.168.10.43
s=X-Lite release 5.1.0 stamp 89322
c=IN IP4 192.168.10.43
t=0 0
m=audio 54270 RTP/AVP 9 8 120 0 84 101
a=rtpmap:120 opus/48000/2
a=fmtp:120 useinbandfec=1; usedtx=1; maxaveragebitrate=64000
a=rtpmap:84 speex/16000
a=fmtp:101 0-15
a=sendrecv
2018-03-04 23:30:46.002858 [NOTICE] switch_channel.c:1104 New Channel sofia/inte rnal/101@192.168.10.242 [e1512308-b4d6-42de-a1cc-4ff4c31ed8ca]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:584 (sofia/intern al/101@192.168.10.242) Running State Change CS_NEW (Cur 1 Tot 4)
2018-03-04 23:30:46.002858 [DEBUG] sofia.c:10070 sofia/internal/101@192.168.10.2 42 receiving invite from 192.168.10.43:57580 version: 1.6.19 64bit
2018-03-04 23:30:46.002858 [DEBUG] sofia.c:10186 IP 192.168.10.43 Approved by ac l "domains[]". Access Granted.
2018-03-04 23:30:46.002858 [DEBUG] sofia.c:11378 Setting NAT mode based on via p ort
2018-03-04 23:30:46.002858 [DEBUG] sofia.c:7283 Channel sofia/internal/101@192.1 68.10.242 entering state [received][100]
2018-03-04 23:30:46.002858 [DEBUG] sofia.c:7293 Remote SDP:
v=0
t=0 0
a=fmtp:101 0-15
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5184 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [opus:120:48000:20:0:2]/[PCMU:0:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [opus:120:48000:20:0:2]/[PCMA:8:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5184 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [speex:84:16000:20:0:1]/[PCMU:0:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5129 Audio Codec Compare [speex:84:16000:20:0:1]/[PCMA:8:8000:20:64000:1]
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5045 Set telephone-event payload to 101@8000
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:3444 Set Codec sofia/inte rnal/101@192.168.10.242 PCMA/8000 20 ms 160 samples 64000 bits 1 channels
2018-03-04 23:30:46.002858 [DEBUG] switch_core_codec.c:111 sofia/internal/101@19 2.168.10.242 Original read codec set to PCMA:8
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5388 Set telephone-event payload to 101@8000
2018-03-04 23:30:46.002858 [DEBUG] switch_core_media.c:5446 sofia/internal/101@1 92.168.10.242 Set 2833 dtmf send payload to 101 recv payload to 101
2018-03-04 23:30:46.002858 [DEBUG] sofia.c:7706 (sofia/internal/101@192.168.10.2 42) State Change CS_NEW -> CS_INIT
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:603 (sofia/intern al/101@192.168.10.242) State NEW
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:584 (sofia/intern al/101@192.168.10.242) Running State Change CS_INIT (Cur 1 Tot 4)
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:627 (sofia/intern al/101@192.168.10.242) State INIT
2018-03-04 23:30:46.002858 [DEBUG] mod_sofia.c:93 sofia/internal/101@192.168.10. 242 SOFIA INIT
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:40 sofia/internal /101@192.168.10.242 Standard INIT
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:48 (sofia/interna l/101@192.168.10.242) State Change CS_INIT -> CS_ROUTING
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:627 (sofia/intern al/101@192.168.10.242) State INIT going to sleep
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:584 (sofia/intern al/101@192.168.10.242) Running State Change CS_ROUTING (Cur 1 Tot 4)
2018-03-04 23:30:46.002858 [DEBUG] switch_channel.c:2249 (sofia/internal/101@192 .168.10.242) Callstate Change DOWN -> RINGING
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:643 (sofia/intern al/101@192.168.10.242) State ROUTING
2018-03-04 23:30:46.002858 [DEBUG] mod_sofia.c:154 sofia/internal/101@192.168.10 .242 SOFIA ROUTING
2018-03-04 23:30:46.002858 [DEBUG] switch_core_state_machine.c:236 sofia/interna l/101@192.168.10.242 Standard ROUTING
2018-03-04 23:30:46.002858 [INFO] mod_dialplan_xml.c:637 Processing 101 <101>->1 00 in context public
send 313 bytes to tcp/[192.168.10.43]:57580 at 23:30:46.241319:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.10.43:57549;branch=z9hG4bK-524287-1---1e2e046781e24f 50;rport=57580
CSeq: 1 INVITE
User-Agent: FreeSWITCH
Content-Length: 0
Dialplan: sofia/internal/101@192.168.10.242 parsing [public->caller-details] con tinue=true
Dialplan: sofia/internal/101@192.168.10.242 Regex (PASS) [caller-details] () =~ // break=never
Dialplan: sofia/internal/101@192.168.10.242 Action export(call_direction=inbound ) INLINE
EXECUTE sofia/internal/101@192.168.10.242 export(call_direction=inbound)
2018-03-04 23:30:46.002858 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [c all_direction]=[inbound]
Dialplan: sofia/internal/101@192.168.10.242 Action set(caller_destination=${dest ination_number}) INLINE
EXECUTE sofia/internal/101@192.168.10.242 set(caller_destination=100)
2018-03-04 23:30:46.022856 [DEBUG] mod_dptools.c:1588 SET sofia/internal/101@192 .168.10.242 [caller_destination]=[100]
Dialplan: sofia/internal/101@192.168.10.242 Action set(caller_id_name=${caller_i d_name}) INLINE
EXECUTE sofia/internal/101@192.168.10.242 set(caller_id_name=101)
2018-03-04 23:30:46.022856 [DEBUG] mod_dptools.c:1588 SET sofia/internal/101@192 .168.10.242 [caller_id_name]=[101]
Dialplan: sofia/internal/101@192.168.10.242 Action set(caller_id_number=${caller _id_number}) INLINE
EXECUTE sofia/internal/101@192.168.10.242 set(caller_id_number=101)
2018-03-04 23:30:46.022856 [DEBUG] mod_dptools.c:1588 SET sofia/internal/101@192 .168.10.242 [caller_id_number]=[101]
Dialplan: sofia/internal/101@192.168.10.242 parsing [public->not-found] continue =false
Dialplan: sofia/internal/101@192.168.10.242 Regex (PASS) [not-found] () =~ // br eak=on-false
2018-03-04 23:30:46.022856 [DEBUG] switch_channel.c:1296 EXPORT (export_vars) [c all_direction]=[inbound]
Dialplan: sofia/internal/101@192.168.10.242 Action set(call_direction=inbound) I NLINE
EXECUTE sofia/internal/101@192.168.10.242 set(call_direction=inbound)
2018-03-04 23:30:46.022856 [DEBUG] mod_dptools.c:1588 SET sofia/internal/101@192 .168.10.242 [call_direction]=[inbound]
Dialplan: sofia/internal/101@192.168.10.242 Action log([inbound routes] 404 not found ${sip_network_ip}) INLINE
EXECUTE sofia/internal/101@192.168.10.242 log([inbound routes] 404 not found 192 .168.10.43)
2018-03-04 23:30:46.022856 [DEBUG] mod_dptools.c:1782 routes] 404 not found 192. 168.10.43
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:286 (sofia/intern al/101@192.168.10.242) State Change CS_ROUTING -> CS_EXECUTE
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:643 (sofia/intern al/101@192.168.10.242) State ROUTING going to sleep
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:584 (sofia/intern al/101@192.168.10.242) Running State Change CS_EXECUTE (Cur 1 Tot 4)
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:650 (sofia/intern al/101@192.168.10.242) State EXECUTE
2018-03-04 23:30:46.022856 [DEBUG] mod_sofia.c:209 sofia/internal/101@192.168.10 .242 SOFIA EXECUTE
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:328 sofia/interna l/101@192.168.10.242 Standard EXECUTE
2018-03-04 23:30:46.022856 [NOTICE] switch_core_state_machine.c:385 sofia/intern al/101@192.168.10.242 has executed the last dialplan instruction, hanging up.
2018-03-04 23:30:46.022856 [NOTICE] switch_core_state_machine.c:387 Hangup sofia /internal/101@192.168.10.242 [CS_EXECUTE] [NORMAL_CLEARING]
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:650 (sofia/intern al/101@192.168.10.242) State EXECUTE going to sleep
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:584 (sofia/intern al/101@192.168.10.242) Running State Change CS_HANGUP (Cur 1 Tot 4)
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:850 (sofia/intern al/101@192.168.10.242) Callstate Change RINGING -> HANGUP
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:852 (sofia/intern al/101@192.168.10.242) State HANGUP
2018-03-04 23:30:46.022856 [DEBUG] mod_sofia.c:449 Channel sofia/internal/101@19 2.168.10.242 hanging up, cause: NORMAL_CLEARING
2018-03-04 23:30:46.022856 [DEBUG] mod_sofia.c:588 Responding to INVITE with: 48 0
send 838 bytes to tcp/[192.168.10.43]:57580 at 23:30:46.248855:
SIP/2.0 480 Temporarily Unavailable
Max-Forwards: 70
To: <sip:100@192.168.10.242>;tag=H115Qr0Xec41S
CSeq: 1 INVITE
Accept: application/sdp
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER, RE FER, NOTIFY, PUBLISH, SUBSCRIBE
Allow-Events: talk, hold, conference, presence, as-feature-event, dialog, lin e-seize, call-info, sla, include-session-description, presence.winfo, message-su mmary, refer
Content-Length: 0
Remote-Party-ID: "100" <sip:100@192.168.10.242>;party=calling;privacy=off;scr een=no
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:60 sofia/internal /101@192.168.10.242 Standard HANGUP, cause: NORMAL_CLEARING
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:852 (sofia/intern al/101@192.168.10.242) State HANGUP going to sleep
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:619 (sofia/intern al/101@192.168.10.242) State Change CS_HANGUP -> CS_REPORTING
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:584 (sofia/intern al/101@192.168.10.242) Running State Change CS_REPORTING (Cur 1 Tot 4)
2018-03-04 23:30:46.022856 [DEBUG] switch_core_state_machine.c:938 (sofia/intern al/101@192.168.10.242) State REPORTING
recv 332 bytes from tcp/[192.168.10.43]:57580 at 23:30:46.281825:
ACK sip:100@192.168.10.242 SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
2018-03-04 23:30:46.102853 [DEBUG] switch_core_state_machine.c:174 sofia/interna l/101@192.168.10.242 Standard REPORTING, cause: NORMAL_CLEARING
2018-03-04 23:30:46.102853 [DEBUG] switch_core_state_machine.c:938 (sofia/intern al/101@192.168.10.242) State REPORTING going to sleep
2018-03-04 23:30:46.102853 [DEBUG] switch_core_state_machine.c:610 (sofia/intern al/101@192.168.10.242) State Change CS_REPORTING -> CS_DESTROY
2018-03-04 23:30:46.102853 [DEBUG] switch_core_session.c:1713 Session 4 (sofia/i nternal/101@192.168.10.242) Locked, Waiting on external entities
2018-03-04 23:30:46.102853 [NOTICE] switch_core_session.c:1731 Session 4 (sofia/ internal/101@192.168.10.242) Ended
2018-03-04 23:30:46.102853 [NOTICE] switch_core_session.c:1735 Close Channel sof ia/internal/101@192.168.10.242 [CS_DESTROY]
2018-03-04 23:30:46.102853 [DEBUG] switch_core_state_machine.c:741 (sofia/intern al/101@192.168.10.242) Running State Change CS_DESTROY (Cur 0 Tot 4)
2018-03-04 23:30:46.102853 [DEBUG] switch_core_state_machine.c:751 (sofia/intern al/101@192.168.10.242) State DESTROY
2018-03-04 23:30:46.102853 [DEBUG] mod_sofia.c:354 sofia/internal/101@192.168.10 .242 SOFIA DESTROY
2018-03-04 23:30:46.102853 [DEBUG] switch_core_state_machine.c:181 sofia/interna l/101@192.168.10.242 Standard DESTROY
2018-03-04 23:30:46.102853 [DEBUG] switch_core_state_machine.c:751 (sofia/intern al/101@192.168.10.242) State DESTROY going to sleep
There is your problem:
So you would habe been better saying, " I have messed with the ACL and now it is broken" :)
Don't touch the ACL, its only for putting carrier IPs in.
cyprusvoip
27
I did but it still gives me the same sofia.c:10186 IP 192.168.10.43 Approved by ac l "domains[]". Access Granted,i reload the acl from sip status and nothing happened,restarted all service nothing,i rebooted the machine and keeps giving access granted.
Best to reboot the box after this to clear memcache etc, ah sorry just saw you have
you also need your own servers ip that you are registering to but under domain, not CIDRdomainsacl.jpg
cyprusvoip
27
i have added that to the domain too but after i removed it,will i have to add it /32?or just like my network /24?
No, you do not touch the ACL except for carriers, under the domain part you DO NOT add /32 or anything.
cyprusvoip
27
Please sent a screenshot of acl and access control.In access control section domain must be in deny mode.
hellraider
This configuration on the acl, it give me access to call local extensions, but not are aviable message it give me. It don't have to recibe call of sip trunk. When i enable the domains acl, it always put on public context and i don't know how to fix it. This is my sitiation now.
