*72 Call Forward not working
Techd00d
If a user tries to enable a call forward via *72, everything seems to work fine, the number even reflects in the GUI on the call routing page for that extension. However, any calls to that extension direct to voicemail instead.
If I simply go to the call routing page and click save without making any changes to the call forward number, it all works perfectly and calls are forwarded as expected.
I just updated to the latest for both apt-get upgrade and from the upgrade source code page in Fusion. The problem has apparently been happening for at least the past 2 months, I was just made aware.
Any ideas?
Techd00d
Anyone have any thoughts on this? Seems to be reproducible as I spun up a fresh install and it did the same thing.
I'm happy to do paid support on this if needed (Even though it seems to be a bug) but I've sent 2 emails in to support@fusionpbx.com and received no response in over a week. :(
