acl not working after upgrade from 4.4 to 5.1.2
trumee
19
I upgraded fusionpbx following the instructions here. Unfortunately after the upgrade the acl modification seems to be broken. When i try to add an ip address to the 'providers' acl, the webui shows that it is added. The fs_cli on the hand does not list the new ip address.
Is there any way to fix this?
dcitelecom
153
Try to run the GUI upgrade for Source Code, Schema, Data Types, App Defaults, Menu, Defaults and Permission Defaults
markjcrane
543
189
For the Upgrade
Latest version of FusionPBX uses an ACL called providers. The original ACL was called domains. Upgrade standardizes on providers instead of domains. So there is an App Defaults that changes domains to providers. Then flushes the cache and rescans the SIP profile. Although the rescan seems to not work. You can do the rescan of the SIP profiles from the menu -> Status -> SIP Status page. Or you can Restart FreeSWITCH.
Add an Node to Providers ACL
When adding a row to the providers access control list you need to press the RELOAD button in Access Controls or go to Status -> SIP Status and press the RELOADACL button.
