add theme location
Mikeme
173
HI all,
so, system using themes/default.
how can i change /set the Default Settings to different location or add another directory location?
Do you mean, how do you change the theme from default to your own?
If so, it's in default settings: ['domain']['template']['name']
It's configured to select a drop down of directories in that theme folder (which is hardcoded, so the themes must remain in the theme folder).
Mikeme
173
Thank you, so I need to generate new setting under domain then on sub write template and then folder location?
Can you past same example please? Like a scrennshot?
