Hello all!
I am running FusionPBX 4.2.2
I am very new to FusionPBX and FreeSWITCH in general. My past experience is primarily with Asterisk and FreePBX, however, I recently had the need for a multi-tenant solution and came across FusionPBX and have been very impressed so far.
I just got my first setup going however, I am experiencing one way audio with outbound calls, which spells out some sort of NAT issue I'm sure -- I just don't know my way around the FusionPBX GUI and settings to know what to change and where I should address this. I read over the official documentation on this and unfortunately it wasn't clear to me on what exactly I should be looking for.
My FusionPBX is behind NAT with a public IP, hosted in AWS.
Would someone mind providing some assistance please?
While I'm at it, I'm also not receiving inbound calls. I've verified my IP is whitelisted with my carrier so that isn't the issue.. It seems like the PBX is denying the traffic, I'm just not sure what to do to correct it? Here is a snip of the logs when I place an inbound call, any input would be appreciated!
2017-11-03 08:31:18.407681 [NOTICE] switch_channel.c:1104 New Channel sofia/internal/12146749682@67.231.4.151 [45f2ddfe-c09b-11e7-b8e7-f3de750ab7b3]
nua_stack.c:359 nua_application_event() nua: nua_application_event: entering
2017-11-03 08:31:18.407681 [DEBUG] switch_core_state_machine.c:584 (sofia/internal/12146749682@67.231.4.151) Running State Change CS_NEW (Cur 1 Tot 29)
nua.c:366 nua_handle_magic() nua: nua_handle_magic: entering
2017-11-03 08:31:18.407681 [DEBUG] sofia.c:9873 sofia/internal/12146749682@67.231.4.151 receiving invite from 67.231.4.151:5060 version: 1.6.19 64bit
2017-11-03 08:31:18.407681 [DEBUG] sofia.c:10044 IP 67.231.4.151 Rejected by acl "domains". Falling back to Digest auth.
nua.c:879 nua_respond() nua: nua_respond: entering
nua_stack.c:529 nua_signal() nua(0x7f7218045a50): sent signal r_respond
2017-11-03 08:31:18.407681 [WARNING] sofia_reg.c:1792 SIP auth challenge (INVITE) on sofia profile 'internal' for [19723384978@vpbx02.velocityvoice.net] from ip 67 .231.4.151
2017-11-03 08:31:18.407681 [DEBUG] switch_core_state_machine.c:603 (sofia/internal/12146749682@67.231.4.151) State NEW
nua_stack.c:573 nua_stack_signal() nua(0x7f7218045a50): recv signal r_respond 407 Proxy Authentication Required
