HI!
Whet i see PBX log i see AMVD errors:
Why? some modules not work correctly?
Thanks!
2021-08-10 16:55:08.857346 [NOTICE] switch_loadable_module.c:412 Adding API Function 'callcenter_config'
2021-08-10 16:55:08.857410 [NOTICE] switch_loadable_module.c:412 Adding API Function 'callcenter_break'
2021-08-10 16:55:08.857433 [NOTICE] switch_loadable_module.c:443 Adding JSON API Function 'callcenter_config'
2021-08-10 16:55:08.860674 [NOTICE] switch_loadable_module.c:412 Adding API Function 'blacklist'
2021-08-10 16:55:08.863246 [NOTICE] switch_loadable_module.c:350 Adding Application 'play_fsv'
2021-08-10 16:55:08.863280 [NOTICE] switch_loadable_module.c:350 Adding Application 'record_fsv'
2021-08-10 16:55:08.863317 [NOTICE] switch_loadable_module.c:350 Adding Application 'play_yuv'
2021-08-10 16:55:08.863329 [NOTICE] switch_loadable_module.c:350 Adding Application 'decode_video'
2021-08-10 16:55:08.863346 [NOTICE] switch_loadable_module.c:480 Adding File Format 'fsv'
2021-08-10 16:55:08.868812 [ERR] mod_avmd.c:966 AVMD config parameter 'debug' missing or invalid - using default
2021-08-10 16:55:08.868837 [ERR] mod_avmd.c:972 AVMD config parameter 'report_status' missing or invalid - using default
2021-08-10 16:55:08.868841 [ERR] mod_avmd.c:978 AVMD config parameter 'fast_math' missing or invalid - using default
2021-08-10 16:55:08.868843 [ERR] mod_avmd.c:984 AVMD config parameter 'require_continuous_streak' missing or invalid - using default
2021-08-10 16:55:08.868846 [ERR] mod_avmd.c:990 AVMD config parameter 'sample_n_continuous_streak' missing or invalid - using default
2021-08-10 16:55:08.868848 [ERR] mod_avmd.c:996 AVMD config parameter 'sample_n_to_skip' missing or invalid - using default
2021-08-10 16:55:08.868850 [ERR] mod_avmd.c:1002 AVMD config parameter 'require_continuous_streak_amp' missing or invalid - using default
2021-08-10 16:55:08.868853 [ERR] mod_avmd.c:1008 AVMD config parameter 'sample_n_continuous_streak_amp' missing or invalid - using default
2021-08-10 16:55:08.868855 [ERR] mod_avmd.c:1014 AVMD config parameter 'simplified_estimation' missing or invalid - using default
2021-08-10 16:55:08.868857 [ERR] mod_avmd.c:1020 AVMD config parameter 'inbound_channel' missing or invalid - using default
2021-08-10 16:55:08.868859 [ERR] mod_avmd.c:1026 AVMD config parameter 'outbound_channel' missing or invalid - using default
2021-08-10 16:55:08.868861 [ERR] mod_avmd.c:1032 AVMD config parameter 'detection_mode' missing or invalid - using default
2021-08-10 16:55:08.868863 [ERR] mod_avmd.c:1038 AVMD config parameter 'detectors_n' missing or invalid - using default
2021-08-10 16:55:08.868866 [ERR] mod_avmd.c:1044 AVMD config parameter 'detectors_lagged_n' missing or invalid - using default
2021-08-10 16:55:08.868868 [INFO] mod_avmd.c:1052 Type 'avmd show' to display default settings. Type 'avmd ' + TAB for autocompletion.
2021-08-10 16:55:08.868963 [NOTICE] mod_avmd.c:1212 Advanced voicemail detection enabled
2021-08-10 16:55:08.868990 [NOTICE] switch_loadable_module.c:350 Adding Application 'avmd_start'
2021-08-10 16:55:08.869019 [NOTICE] switch_loadable_module.c:350 Adding Application 'avmd_stop'
2021-08-10 16:55:08.869031 [NOTICE] switch_loadable_module.c:350 Adding Application 'avmd'
2021-08-10 16:55:08.869044 [NOTICE] switch_loadable_module.c:412 Adding API Function 'avmd'
2021-08-10 16:55:08.872531 [NOTICE] switch_loadable_module.c:350 Adding Application 'curl'
2021-08-10 16:55:08.872552 [NOTICE] switch_loadable_module.c:350 Adding Application 'curl_sendfile'
2021-08-10 16:55:08.872563 [NOTICE] switch_loadable_module.c:412 Adding API Function 'curl'
2021-08-10 16:55:08.872574 [NOTICE] switch_loadable_module.c:412 Adding API Function 'curl_sendfile'
2021-08-10 16:55:08.882578 [INFO] switch_core_sqldb.c:1899 fifo Starting SQL thread.
(info:
FreeSWITCH (Version 1.10.6 -release.12 64bit) is ready)
Thanks!
(info:
FusionPBX | 4.5.26 |
