And then along comes Giovanni and owns it :D
197
Pretty damn slick interface and features for sure. Job well done!
I would still prefer option to open a new window, but easy enough to drag out the tab for same effect.
Will be fun to put through the paces when time allows.
Reactions: gmaruzz
gmaruzz
11
<3
Thank you for nice words!
You can:
# cd /var/www/fusionpbx/app/saraphone;
# git stash; git pull; git stash apply;
often, and you will get latest features/bigfixes, and maintain your own modifications
-giovanni
Reactions: krooney
<3
You can:
-giovanni
I made a small modification so voicemail does *97 and then voicemail_authorized=true in the dialplan to make life a little easier.
Everything I have tried has worked :D
Reactions: gmaruzz
gmaruzz
11
Yep, I use *97 in FusionPBX production too, *98 is just to keep compatibility with standard plain FreeSWITCH vanilla dialplan
voicemail_authorized is very nice feature indeed (albeit by default, better let people enter the password)
I will put both your suggestions in README.md and Wiki
THANKS!!!
agile
27
Amazing just what I was looking for. Thanks Giovanni.
Just a thought, due to pandemic it's increasingly demanding to have video chat and conferencing with screen sharing functionality.
can we request feature update to Sara phone?
1. Vedo call
2. Conference calls with video
3. Screensharing.
gmaruzz
11
thank you for nice words
nope, those features does not belong to a business phone
there will be a specific separate and distinct videoconference client
agile
27
Thanks for the quick response Giovanni. I just installed this and I am getting the error message. I have got wss 7443 port enabled and the public IP given in Advanced >default setting >Sara Phone. can you please help by pointing me in the right direction?
Solution We need UDP and TCP both open for 7443
UDP -7443
TCP -7443
Many thanks.
agile
27
Thanks for the quick response Giovanni. I just installed this and I am getting the error message. I have got wss 7443 port enabled and the public IP given in Advanced >default setting >Sara Phone. can you please help by pointing me in the right direction.
Many thanks.
Solution
udp port 7443 was open but not TCP port 7443
once I enabled the port TCP 7443 this worked.
