Applications Tab issue?
btil
13
On my PC, when logged into FusionPBX and I hover over the Applications Tab, The cloumn fills to the bottom on the screen (task bar). "Recordings" is the last oprion there. I cannot get to or see any choice below that. What trick am I missing?
agree
135
24
the dropdown list is not height responsive only solution is to minimize your browser view
btil
13
FYI, Tried to minimize on chrome and firefox no change. If I move the task bar to the side can get a few more lines. But never see "Voicemail" Worked okay on my LG tablet.
Quick workaround - Use the CTRL- key combination repeatedly to zoom out until you can see the whole dropdown. Count how many time you press CRTL- because then you can quickly press CTRL+ the same number of times to restore the view (zoom level) that you are used to. You can generally also access the view / zoom functions from th browser menu.
