ASTPP <-> FusionPBX with multiple DIDs => HOW-TO <=
55
Hello to everyone.
I would like to describe my scenario to know how manage it with best possible configuration.
Multiple incoming DIIDs -> ASTPP -> Device -> FusionPBX -> Gateway -> Extensions
In my scenario, ASTPP device is a number like 20250672. FusionPBX is registered to ASTPP creating a gateway, inserting ASTPP IP address into ACL to permit passing traffic.
Now my problem is:
calling number 1 -> astpp device 20250672. Into FusionPBX I need to create a Destination label identical to 20250672 to receive call and apply relative dial plan.
calling number 2 -> astpp device 20250672. Now I can't apply a different dialplan based on called number, because in FusionPBX I have only one match always to 20250672.
Is there a method to modify 20250672 with real called number to create a destination label to implement different call flow for each of them?
I wouldn't create multiple device under astpp and multiple gateway under FusionPBX to match every number if it is possible.
Any suggestion to do that?
Thank you.
